alxdgr8 wrote:TDI swap it and use it as a commuter!
This.
the german wrote:Well crap. I found my answer. It's an 016 in this as well so it would need an 01a or maybe the 012 if I find a donor car. That means figuring out manual speedo conversion.
GTJeff wrote:the german wrote:Well crap. I found my answer. It's an 016 in this as well so it would need an 01a or maybe the 012 if I find a donor car. That means figuring out manual speedo conversion.
I guess it could be an 016 but I remember the shift linkage being completely different. Are you sure it isn't an 093?
The 016 came in two varieties Quattro and non..
all standard 5000's normally aspirated and turbo came with an 016 gearbox this
changed in 89 with the advent of the 100.
All quattros up to the 88 audi 90/80 used a version of an 016 gearbox.
Porsche used the 016 in the 944's and late 924s.
The 093 coupe box is different from an 016 in that just about everything is
smaller dimensionally. the ratios are better suited for economy type driving
and in my opinion cannot handle very much horsepower.
An 016 box WILL NOT fit in a 2wd coupe easily. you might be able to muscle it
in with a hammer and by using a subframe from a 4kq. the hammer is for the
floor pan. The shift linkage is entierly different as is the shift handle
mounts etc. The front axels are the same from a coupe to a 4kq. Other items
to think about is that some of the coupe boxes the clutch is cable operated
whereas all 016 have a hydro clutch.
The flywheels differ I believe not sure what the difference is but they aren't
the same part number.
IMG_20141207_192351291 by alxdgr8, on Flickr
IMG_20141218_195943637 by alxdgr8, on Flickr
