Page 167 of 171
Re: Loxxrider's 200 20v Revver Project
Posted: Fri Jan 25, 2013 6:58 pm
You'd be looking at these
http://www.compturbo.com/products/ct5" onclick="window.open(this.href);return false;
Posted: Sun Jan 27, 2013 9:27 am
by HT Motorsport
The Borg Warner EFR's we are running in the mega V8 project are UBER impressive BTW. I don't know if they make them up to the size you are looking for but I would run them again in a heartbeat!
Posted: Sun Jan 27, 2013 10:57 am
They don't unfortunately :( That would have been my top choice. At the moment, I'm leaning towards a a borg S476-ish thing, maybe with billet comp wheel. For some reason I'm finding that guys running the 4202 are running out of steam upwards of 35 psi and probably 100 lb/mim suggesting that the gtx comp wheel is just mismatched with its turbine wheel.
Posted: Sun Jan 27, 2013 1:16 pm
by glibobbo21
Check out "extreme tuners' for billet wheel stuff too.
Posted: Sun Jan 27, 2013 1:38 pm
by Jrod033
loxxrider wrote:They don't unfortunately :( That would have been my top choice. At the moment, I'm leaning towards a a borg S476-ish thing, maybe with billet comp wheel. For some reason I'm finding that guys running the 4202 are running out of steam upwards of 35 psi and probably 100 lb/mim suggesting that the gtx comp wheel is just mismatched with its turbine wheel.
Can't go wrong with bw...great turbos...and funny thing I know a guy that has a brand new s476 t6 you should look into! Haha
Posted: Sun Jan 27, 2013 1:46 pm
Damn... they make some impressive stuff. E-mail sent (to them).
ha, Jrod, I'd be interested, but I need something T4 :/
Posted: Sun Jan 27, 2013 5:06 pm
by 123quattro
You might want to look into the T6 housing. T4 housing will cost you 100hp at the levels you are talking about.
Posted: Sun Jan 27, 2013 5:14 pm
Hmm, you sure? I believe the T4 housing is available with 1.10 AR and an 83mm (exducer) turbine. Borg's match-bot thing says that should easily flow what I need it to. I'm still not any good at reading the turbine plots, but I'm pretty sure it should be OK. Have a look for yourself:
http://www.turbodriven.com//performance ... rsin=92044&
Posted: Sun Jan 27, 2013 5:23 pm
by glibobbo21
loxxrider wrote:Damn... they make some impressive stuff. E-mail sent (to them).
Dunno how they work out but theyve made even bigger wheels for the large frame EFR's. Check out their fb. They update alot on there.
Posted: Mon Jan 28, 2013 7:27 am
by 123quattro
loxxrider wrote:Hmm, you sure? I believe the T4 housing is available with 1.10 AR and an 83mm (exducer) turbine. Borg's match-bot thing says that should easily flow what I need it to.
My note wasn't based off compressor maps. It was from a friend that races a lot of Mustang 10.5 stuff in OH. He picked up 100hp changing turbine housing. A/R stayed the same.
Posted: Mon Jan 28, 2013 9:35 am
I hear ya man, but that depends on so much more than just A/R. I believe you, I am just curious if it carries over to this particular application. Also, I wasn't referring to the compressor map, I'm referring to the turbine maps.
Posted: Mon Jan 28, 2013 5:23 pm
NASCAR clutch incoming :D
Posted: Mon Jan 28, 2013 5:25 pm
by pilihp2
Uh.
Specify?
K thanks.
loxxrider wrote:NASCAR clutch incoming :D
Seriously? That's awesome! :dur:
Posted: Mon Jan 28, 2013 5:39 pm
Yep, Tilton 7.25" triple disk. They can be had for pretty good prices off of NASCAR cars used for one race.
Drive-ability is pure, absolute shit, but I don't mind. It kinda has to be that way to hold the POWAH!
Posted: Mon Jan 28, 2013 5:40 pm
loxxrider wrote:Yep, Tilton 7.25" triple disk. They can be had for pretty good prices off of NASCAR cars used for one race.
I approve. Dude, your car is going to be straight up NUTZOID. :P
Posted: Mon Jan 28, 2013 5:41 pm
by pilihp2
loxxrider wrote:Drive-ability is pure, absolute shit, but I don't mind. It kinda has to be that way to hold the POWAH!
:lol: :lol:
Friggin awesome.
Posted: Mon Jan 28, 2013 7:14 pm
That is the plan, I sure hope so! :)
Posted: Sun Feb 03, 2013 5:54 am
by Kieron_UK_20V
loxxrider wrote: by the way, does anyone want to buy an HX52 just rebuilt in the past 20 miles with v-band outlet already machined for 4" dp and flange modified to fit any T4 manifold? It is a nice 67mm (billet wheel) turbo! Make an offer I can't refuse 8)
What the spec on this Chris?
Im looking to import a Cheap HX52 to compliment my ABZ'd coupe.
I was going to buy a repairable core on ebay along with a rebuild kit and rebuild it myself over here, cant seem to find many cheap ones in the UK.
What would you be looking for, and any idea on shipping cost to uk?
Cheers.
Kieron.
Posted: Sun Feb 03, 2013 6:02 am
by Marc
not sure how much Chris wants for it, but shipping wise it sure as heck wont fit in a postal flat rate box. weight, I haven't put it on a scale but probably close too 50lbs, which is $150 to get to the UK.
Posted: Sun Feb 03, 2013 9:00 am
by Kieron_UK_20V
Ooooh, controversial. That sucks.
Posted: Sun Feb 03, 2013 9:05 am
Kieron, Marc is right about the shipping. It wont be cheap. I'd like $250 out of the turbo itself.
They are something like 88lb/min I believe. 16 cm^2 exhaust housing.
Posted: Mon Feb 04, 2013 3:09 am
by Kieron_UK_20V
£250 delivered still sounds pretty good to me.
Have you got pics of the modified flange, save me flicking through all the pages.
Posted: Mon Feb 04, 2013 4:56 am
I don't but it was done by Hank and you can't even tell it is modified. Fits nicely.
Posted: Sun Feb 17, 2013 11:18 pm
by amd is the best
Need moar picz, vidz and updates :)
