If your tuner is clever enough, you can use 074906021XX MSA15 sw in 028906021XX MSA15 ecu hardware both will work. Or you can come to me (LV) and I'll do sw change for you. Also I can sell you already modified ecu with failsafe sw.
For wiring you just need to change ECU plugs + 1-2 spare wires. If you go MAFless and delete EGR it will be easy - 2hr comparing and 1-2h soldering.[/quote]
Thanks for you help. Wiring for me is not the problem and ecu fleshing, repairing... I do it every day. I see what this ecu's is the same hardware and i can put whatever software to this ecu. 074 xxx xxx xx is vans and 028 xxx xxx xx is passagers cars. One thins is make personal software tune
i contact with you. Thanks alllot and i going do wiring job.
my ecu is: 028 906 021 CE
I thinik make 074906021 M (111kw,151PS) need search for not modifed original soft.
Attachment ( 29686 ) : IMG_1042 (Large).JPG
