So I've been doing a combination of working on the 200 and driving it. The new motor is running pretty strong, I'm about at the 500mi mark and everything seems good. I'm in the process of getting my ECU modifications finished up to run coil on plug, which will mark a major step in the progress of this project. I'm going to be using the factory flywheel sensors and the factory shielded wire which is super beefy and well done. I am also using the factory knock sensor wiring so that I can set up knock phones per Marc's writeup on his website. This should make tuning much easier and better and hopefully drive-ability will massively improve.
Also finished fixing/modifying the exhaust. I moved the 3" glass pack back a bit and added a second $30 Summit muffler. It's still louder than I would like but I think it actually sounds WAY better than before.
Some modification necessary
Dual 2.5" outlets painted flat black
Ben aka AnotherBrick laying some sweet ass beads. Seriously, he picked it up quick even considering it's just flux core MIG
I've been on a spending spree
I need to save for spring time plans but I bought an MC2 camshaft from 'Taco, a ton of random stuff like window regs and tie rod adjusters from Phil, and a heater core from Kuma. I also bought this clutch disc from RX7Tuner on MG, it's definitely used and has limited life left but I'll save it for when my OEM clutch starts slipping and it will definitely buy me some time. For the price I couldn't pass it up
And we keep getting snow, it's almost like a real winter in Maryland
Thanks for reading along!
