Ronald G Wainwright+
Post by Ronald G Wainwright+ »
a4kquattro wrote:Aha! Thanks Ron (got your call by the way, I was watching Wayne Brady in Lowell when you called). As always a picture is worth a thousand words. The bit I missed was the eccentric idler roller. I never touched it during the belt procedure. Woops!
No problem Marc, I just did it cause I want a ride :woowoo:
RSCoupe
Post by RSCoupe »
Marc,
Metric & Multistandard Components Corp. has them:
http://www.metricmcc.com/catalog/Ch5/5-522.pdf
$60 for the tap, $102 for the die.
yowsa! I'm going for door #2, which is to take a stock filter union and re-thread the bottom half for a different thread spec ;) Thanks tho guys.
gidrew
Post by gidrew »
Good Deal. I guess snap-on doesnt make M22x2.0, he wanted me to double check with you to make sure it wasn't 7/8-14, but looks like you have the problem figured out.
Alright, I spent another day at the shop yesterday. The main goal was to get the oil bypass adapter threaded on. I ended up re-threading the oil union for 22x1.5mm thread.
To do this, I built a tool to grab the die from the bottom so I could spin it with a socket and 3/8 ratchet. Worked like a charm:
eventually, I finally got the adapter on there
The manifolds also came along. Purdy, aren't they??
And a quick test-fit shot on the radiator
yodasfro
Post by yodasfro »
So does it run yet? :P
does it look like it?
yodasfro
Post by yodasfro »
Nope :-D So where are your turbo's?
yodasfro wrote:Nope :-D So where are your turbo's?
Coming soon hopefully! There are still plenty of odds and ends to work on, but I really want to get those turbos plumbed in so I'm 100% sure where everything is going to sit in the engine bay.
3bAudios
Post by 3bAudios »
Marc, that car is looking awsome!!!! When is a good time to come down there and check it out in person??? I also got to return that tap.
yodasfro
Post by yodasfro »
Cool don't sell it before I can get ride in it. 8)
3bAudios wrote:Marc, that car is looking awsome!!!! When is a good time to come down there and check it out in person??? I also got to return that tap.
I was thinking about going today but then I remembered that I want to catch LeMans ;)
gidrew
Post by gidrew »
Marc, When you rethreaded the bypass adaptor, what was the thread pitch to start out? I'm kinda curious if its going to seal properly, everytime i try to rethread something to a different pitch, it never goes well. I hate having to go back in to fix stupid shit like that.
gidrew wrote:Marc, When you rethreaded the bypass adaptor, what was the thread pitch to start out?
22x2.0
It seems quite strong. I've got it threaded on pretty tight. Obviously I haven't run the car to check for leaks but I dont anticipate a problem.
yodasfro wrote:Cool don't sell it before I can get ride in it. 8)
Hey thats my line! But :stupid: as well
audiphile200
Post by audiphile200 »
audiphile200 wrote:http://www.turbotechnik-grossholz.de/002/bild01.jpeg http://www.turbotechnik-grossholz.de/ga ... di200.jpeg 8) ooooooooooooooo yeaaaaaaaaaaaaaaaa
Yep, I think thats the first v8tt swap I'd ever heard of. Custom intake manifold is definitely the way to go... That'll be part of 'v2' for my car.
more parts arrived while I was away in Montreal. Turbos are here :woowoo:
T3-60's
Tial BOV :drool:
And I decided I wanted to use all instant tube fittings from mcmaster for the vacuum lines on the car. I like the nice positive locking on the fittings and the ease of assembly/dissasembly.
I'll be flying into Dallas on Wednesday and wont be back until Sunday so that sorta shoots this weekend for working on the car. Sucks, cause' I cant wait to start making some serious progress now that most of the pieces are here :-D
SilverCQ
Post by SilverCQ »
mmmmmmmmmmmmmmmmmmmm sweet!
cant wait to see this one running! :-)
yodasfro
Post by yodasfro »
Nice VAC fittings. Whatcha doin en tehas?
JShadzi
Post by JShadzi »
a4kquattro wrote:more parts arrived while I was away in Montreal. Turbos are here :woowoo:
T3-60's
Nice turbos :D
JShadzi wrote:Nice turbos :D
Why thankyou ;)
Yours is.. ahem.. still bigger than mine :-o
yodasfro wrote:Nice VAC fittings. Whatcha doin en tehas?
mixing business and pleasure. I'm meeting up with a client and also my GF is at a conference so I'm basically travelling for free.
audiphile200
ya know after reading this forum and seeing all the v8 goodies i think im gonna forget about doing a 4ktq 20v project and go for the v8 turbo im sooo convinced....hmmmm id better start flagging some serious hours at wrok now... :D
alriiiight, update. Haven't been in the garage for 2 weeks, back at it this weekend for some proress!
Had to do a little tweaking on the exhaust manifolds, here's the angle I started with:
and this is where it ultimately needed to be:
So turbos are now hooked up :woowoo:
passenger side (notice funky WG orientation, had to modify the WG bracket a bit
drivers side:
60# fuel injectors installed. That should be good enough for some powah
had a little issue with the flare on the fuel supply side, had to re-do that to fix a leak
Comin' together :)
And a random bit, Dennis and Keleigh welcome these two new additions to their family
Tomorrow: downpipes, finish remote mount oil filter, and maybe... test fire? :-D
