Ed's 1992 UrS4 "da fridge" - da movie
Re: Ed's 1992 UrS4 "da fridge"
I just rewatched your videos Ed... and ya, I seriously hope my 4k with the 5857 comes close to what your car does (-100hp + 4kq weight savings). Either way, I just had to say I love your car man.
Your car will be faster bcuz gears if you can shift quick enough...
Only chance will be 40-100 maybe. Useless 1-2 in the 4kq and poor aero hurt. Weight doesn't hurt quite so much at speed, as aero is far much more force to overcome.
yep, not to mention you're dropping out of boost when you shift. Unless you have something set up to overcome that, the longer gears are gonna be faster if all else is equal.
Hank wrote:Only chance will be 40-100 maybe. Useless 1-2 in the 4kq and poor aero hurt. Weight doesn't hurt quite so much at speed, as aero is far much more force to overcome.
Good call Hank, I wasn't thinking about aero, driving a box around doesn't help. :P
EDIGREG wrote:yep, not to mention you're dropping out of boost when you shift. Unless you have something set up to overcome that, the longer gears are gonna be faster if all else is equal.
Hmm, Maybe, later down the road I will get excited and play with anti-lag or something to help keep boost up between shifts.
Except Ed's a scaredy cat and won't launch
:P
Lol I've launched it a few times, just not on dry pavement :)
275's going on soon... more grippage = more breakage
Good Lord that will hook up like crazy. I launched the TDI... it was mediocre. Lol. The s is just too heavy for that crap
FRCFD5
Post by FRCFD5 »
EDIGREG wrote:Lol I've launched it a few times, just not on dry pavement :)
what kind of engine mounts and trans mounts are you running ?
FRCFD5 wrote:what kind of engine mounts and trans mounts are you running ?
Both stock at the moment! Much stiffer mounts are on the list. Rear end is already set with poly on the rear diff and rear subframe. Solid front subframe bushings as well.
Any plan to uh... make those subframe bushings a Member Product? Kinda like other certain camber plates? :D
pilihp2 wrote:Any plan to uh... make those subframe bushings a Member Product? Kinda like other certain camber plates? :D
No, but you may be able to convince Thuppu to make some more: http://www.s2forum.com/forum/showthread.php?t=56998
Fuel system build commencing soon... obligatory "on the bench" pic :) Not pictured is a Honeywell fuel pressure sensor which will feed a signal to VEMS.
Re: Ed's 1992 UrS4 "da fridge": Fuel system parts...
Some serious sexiness going on there...
:metoo:
Just when you thought this couldn't get any better, it gets more better. <hat tip>
MHCAudi200t
Post by MHCAudi200t »
:drool: beautiful car! Clean and simple. I love the contrast between the black wheels and the paint. :thumbsup: you from colorado? One of the videos the car had colorado plates.
Thx guys... I am in PA. Car previously lived in CO though
MHCAudi200t
EDIGREG wrote:Thx guys... I am in PA. Car previously lived in CO though
Oh i see, im just trying to find fellow audi fans out here in Colorado. Either way keep up the good work. Car looks great!
Very nice Ed, no short cuts for you.
Do it right once and move on :)
MHCAudi200t wrote:Oh i see, im just trying to find fellow audi fans out here in Colorado. Either way keep up the good work. Car looks great!
That should be easy... there are a TON of Audifans in CO!
ringbearer wrote:Very nice Ed, no short cuts for you.
Yessir - do it right or don't do it at all :)
highlander69
Post by highlander69 »
I like where this is going :D
One of my favourite cars :hail:
Cheers,
Craig
Booooooooooossst juuuuiiiiice
What! Where?
MHCAudi200t
What! Where?
Thats what im saying! Would be nice to know where.
