Page 2 of 6
Re: 86 Alpine white 4000's
Posted: Mon Sep 05, 2016 9:52 pm
by Afterthought
PRY4SNO wrote:Good pics.
Up until now, I've only ever read about that interference. From what I remember, the solution was a BFH and making some room.
On the tunnel It would not take much to fix.
The rubbing on the tail end is pretty bad. when putting in 3rd and 5th I can feel it jamming there and can hear the transmission noise translate through the body of the car so it makes it pretty loud.
Posted: Tue Sep 06, 2016 11:27 am
Yeah, it's tight. I adapted an 016 linkage for that part because it originally came in the small chassis. Just updated my thread here
viewtopic.php?f=11&t=73&p=83238#p83238
Posted: Tue Sep 06, 2016 12:09 pm
by Afterthought
Afterthought wrote:PRY4SNO wrote:Good pics.
Here are some pics, hopefully by the end of today i will have found a solution. I hate to use a hammer but that might be the only way,
For those working on a swap these pics may help give you an idea of where the clearance issue is.
The trans:
Result of rubbing:
This is the area in the tunnel that I may need to adjust.
Passenger side "spacer" installed.
I've read everywhere that the spacer should be 40MM but this one is 30mm and it seems to work
Spacer dimension:
Linkage arm
Going to replace this while I'm in there.
Posted: Tue Sep 06, 2016 10:00 pm
by Afterthought
Got the engine/trans/subframe set in place and bolted up.
These are the engine mounts. Energy suspension 1044 which I think is for a ford mustang 5-speed transmission.
Engine sitting in place. The AAN intake manifold will have to come off for a 3B.
Throwing some wheel studs in while I'm at it.
Got my brakes compressed and new pads in but not without some drama. Thanks harbor freight for another tool that literally didnt even last one use.
This is odd and doesn't make sense to me but the trans linkage seems to have more clearance in this car in the neutral position but I'll have to revisit this tomorrow and actually take a look at how it would shift.
Posted: Wed Sep 07, 2016 9:34 pm
by Afterthought
Posted: Thu Sep 08, 2016 6:53 pm
What rpm range, if any, does that Magnabro drone at? I'm curious as I've heard/read that they ought to be offset in/out and yours is offset in/centre out.
Have you considered POR15 for the paint instead of a rattle can? Reading up on their website it says the paint adheres better to rough surfaces or rusty metal.
Posted: Thu Sep 08, 2016 9:33 pm
by Afterthought
PRY4SNO wrote:What rpm range, if any, does that Magnabro drone at? I'm curious as I've heard/read that they ought to be offset in/out and yours is offset in/centre out.
I didn't notice any drone with this one actually. When I bought it , the system consisted of just a high flow 3" cat and that muffler and It seemed to be a bit quieter than the Borla I had on my '90 Coupe. In this car I'll be running just the muffler. As soon as I get it fired up I can let you know how or if it drones and/or get a video.
Posted: Thu Sep 08, 2016 9:43 pm
by Afterthought
Went out to the shop and decided to finish the suspension. Started by replacing the ball joints. Immediately first 20 minutes of being in the shop I snapped off a bolt doing something stupid.
So first I tried to take it out with a screwdriver...
Not that lucky... So I had to figure out how to weld on a bolt.
Finally got the car on the ground so thats nice to be done with one piece of the project.
Decided to take off the intake manifold so I can get the 3B manifold on, but realized with the damn AAN Manifold I need a super long allen.
I see that Snap on makes one, so I am going to get one of those. But in the meantime I got something to work.
Intake manifold off
Water Manifold off
So that's where she sits for the night. For those looking to do anything on the intake manifold , Snap on tool # T10197
Posted: Fri Sep 09, 2016 12:46 am
by the german
Making great progress, keep it up!
Posted: Sat Sep 10, 2016 10:18 pm
by Afterthought
Posted: Sat Sep 10, 2016 11:41 pm
by alxdgr8
Welding cable isn't the best choice for battery cables. Make sure to keep it away from heat.
My car has a similar piece from the AC getting removed. Thinking about adding it back though.
Posted: Sun Sep 11, 2016 12:33 am
by Afterthought
alxdgr8 wrote:Welding cable isn't the best choice for battery cables. Make sure to keep it away from heat.
Guess I could throw a sleeve over it to shield from the downpipe
Posted: Sun Sep 11, 2016 11:31 am
I would definitely put some sort of heat shielding on it. I used a bulkhead for my power cable because my megasquirt harnesses go through where the AC used to be on my B3.
Posted: Sun Sep 11, 2016 1:59 pm
by Afterthought
DE80q wrote:I would definitely put some sort of heat shielding on it. I used a bulkhead for my power cable because my megasquirt harnesses go through where the AC used to be on my B3.
I am going to use the AC holes for the engine harness and 02 sensor wires I think.
Did a little more today, realized I never did put in the proper tie rod when I had the engine out so I got that taken care of.
This is how everything has come apart on this car. Its been real nice that the PO used never seize everywhere but still most of the stuff has required a little but or coaxing to get out.
Finally. New tie rod end.
Also took of the P/S pump from it's location which wont work with the radiator.
The bracket for picking the head, that also holds the CPS , those bolts I can already tell aren't going to come out. So I don't know if I'll have to weld a nut to them or what.
Posted: Mon Sep 12, 2016 8:45 pm
by Afterthought
Wrestled with the car for a bit today, goal was to get this bracket off head, bolts were about to strip and couldn't find any reasonable way to get them out. I wasn't pretty. only had an hour and a half or so, unfortunately most of my time went into that
Anyway got that out. Ate up most of my time. This little piece I got from Hank is probably going to be the best looking part of this engine until it gets rebuilt with rods. I will be doing that eventually but I don't have time to give this car the same attention my coupe is getting if I ever want to finish the coupe.
3B water manifold on
3B intake manifold. I think I have to run the 7A or 3B cover for fitment with the throttle body.
on another note... What is the green stuff, just anodizing on the factory bolts? or some kind of coating that PO put on ?
Posted: Mon Sep 12, 2016 9:07 pm
Green is a factory coating of some sort.
Posted: Tue Sep 13, 2016 8:18 am
by Afterthought
DE80q wrote:Green is a factory coating of some sort.
I'm going to see if I can find out what it is or how to duplicate it because all of the bolts the engine that do have this coating come out so much easier than the ones that don't.
Posted: Tue Sep 13, 2016 12:29 pm
by A1QSHIP
Afterthought wrote:DE80q wrote:Green is a factory coating of some sort.
Did a google search & this is what I came up with:
http://greenkote.com/industries/Don't know how to duplicate it yet.
Chris
Posted: Thu Sep 15, 2016 10:45 pm
by Afterthought
Posted: Fri Sep 16, 2016 9:11 pm
by Afterthought
Posted: Sat Sep 17, 2016 1:47 am
by 90quattrocoupe
Nice welds.
Posted: Sat Sep 17, 2016 3:16 pm
by Afterthought
Hey thanks. Most of them I am afraid to show to anyone.
I have been spending more time on fit up and changed some other things. Got some smaller diameter rod which helped a ton. Because in all the spots where the fit-up is not perfect I am often finding myself needing a tiny little but of rod but the huge diameter shit I bought was too much. I am trying to teach myself so it's a steep curve.
Posted: Sat Sep 17, 2016 3:19 pm
by Afterthought
Today's project, working on the PCV system trying to clean it up a bit. I'm working on replacing a bunch of stuff with JIC or AN fitting for use with stainless lines. It's probably overkill for the breather system but the stainless lines give me flexibility.
First I took the breather spider thing and cut it down a bit.
These fittings are designed to be brazed on I think. I had to use a die grinder to increase the ID a little because metric shit is all between sizes. Anyway got these to where they slip over after 30 minutes on the grinder , 48 bits later and three pounds of metal dust in my eyes and all my pockets.
[img][img]http://i1180.photobucket.com/albums/x413/02s4nogaro/1986%204000/2F759706-6212-431A-A9FB-896A4FB95D92_zpsfqrrisx8.jpg[/img][/img]
I retained the valve in here. So the next step is to figure out where I want to tie into the 7A valve cover .
I saw a post where Varia had some pics of tapping into the same spot where AAN covers have a breather, but on the the back of the 7A . My plan is to weld an aluminum JIC fitting here so my AN fitting can tie right to it. I don't know how to weld aluminum so it should be cool.
Posted: Sat Sep 17, 2016 8:38 pm
by Dan McBoost
Very nice work. Looking forward to seeing this boosting
Posted: Sun Sep 18, 2016 9:51 am
by Afterthought
Dan me too! It is killing me currently not having an Audi to drive but I want to make it right.
