Today's project, working on the PCV system trying to clean it up a bit. I'm working on replacing a bunch of stuff with JIC or AN fitting for use with stainless lines. It's probably overkill for the breather system but the stainless lines give me flexibility.
First I took the breather spider thing and cut it down a bit.
These fittings are designed to be brazed on I think. I had to use a die grinder to increase the ID a little because metric shit is all between sizes. Anyway got these to where they slip over after 30 minutes on the grinder , 48 bits later and three pounds of metal dust in my eyes and all my pockets.
[img][img]http://i1180.photobucket.com/albums/x413/02s4nogaro/1986%204000/2F759706-6212-431A-A9FB-896A4FB95D92_zpsfqrrisx8.jpg[/img][/img]
I retained the valve in here. So the next step is to figure out where I want to tie into the 7A valve cover .
I saw a post where Varia had some pics of tapping into the same spot where AAN covers have a breather, but on the the back of the 7A . My plan is to weld an aluminum JIC fitting here so my AN fitting can tie right to it. I don't know how to weld aluminum so it should be cool.
