What did you do today? *Sticky?*
Dan McBoost
Re: What did you do today? *Sticky?*
Post by Dan McBoost »
Went to 40's and had a great time as always on Saturday. Today cooked every meal for the wife and dealt with the daughter all day. When they napped, I had some time to work on installing OEM JD headlights on my lawn tractor and crossing a few small things off the MR2 list.
Dan McBoost
speeding-g60
Post by speeding-g60 »
today...... hmmm.
got momma breakfast in bed, flowers, balloon and cake.
sat in the hot tub a couple times, took a nap, mowed the whole yard, unloaded the car and dissected the shifter linkage to repair/improve it. it was having a hard time staying put when testing friday, did run 10.73 @ 97 and coasting from before the 1/8th mile though, which is pretty good for a soft launch. the shifter portion made all the shifts perfectly, but when it over threw going 1-2 it loosened the set screw on the linkage to rod, and when it went from 3-4 it went on the shifter but not the linkage at the trans. a fix is in the works, just gotta wait til i get down to the shop and hit the mill. i should just buy myself a small mill now, been looking at them lately......
and yesterday we finally put the new car on the ground after being on the chassis jig for the last 26 months minus one day to show it at the car show in 2014. ProMod car needs to be on the chassis jig so off I go.
but leaving the rear quarters in place in relation to the rear of the car and opening them 4" forward makes the rear look proportional. the fronts, look way better (IMHO) with the arches moved forward. makes it look more even with closer to equal space in front of and behind the wheel well / arch. and lengthening the wheelbase as well. makes it have more of a BMW look on the front end without so much body out in front of the arch.
Current one and new one, showing body changes. Specifically wheel arches and location of arches.
Sent from my SCH-I545 using Tapatalk
loxxrider wrote:Well that's not cool at all. Did a hose clamp come loose or something? I was actually sent an UrS4 catch can kit from 034 by accident (when I requested the crank case breather hoses for a 200 20v). I haven't had the time to do anything about it. Want it?
Let me guess, they're blaming the shipping department...
I have a Mann Provent somewhere in the trunk which I can't open at the moment... So I might need to actually take you up on that offer if I can't figure out how to open my trunk using an alternate way...
Sent from my SM-N900V using Tapatalk
Post by alxdgr8 »
Got the Ducati put back together and fired up...sounds great so I guess that means I didn't screw up the timing belt or valve adjustment :D Thankfully all of the rockers were in spec so I didn't have to swap shims or anything.
managed to make a catch can for my catch can yesterday.
As an FYI
the mann provent should never be used without a drain back to the block, or without a drain to another can. Not sure how I managed this long without one.
Also, I hate the stock PCV routing on these cars. Fills a provent on 2 pulls, and I dont even have bad rings.
All_Euro
Post by All_Euro »
speeding-g60 wrote: Image
Good to see the wheels on the ground again... needs more tire tho ;)
Work - Houzz / linkedin
Play - Haldex Swap
speeding-g60
yeah but that 30" x 13.50 drag radial tire, 315/60-15 (which happens to be the LARGEST tire on a CQ BTW) is my training tire. i will go up to a 32 x 14 on a 14" wheel or maybe even 33 x 10.5W when i learn how to drive.
this is 32 x 14.
which looks like this if it isnt tucked under the body. if that aint enough nothing ever will be.
Those tires look like crankshaft twisters!
This thread is awesome today
Dan McBoost
audifreakjim wrote:This thread is awesome today
Yes it was. :D
Last night I drove an hour to pick up volvo load bars from a guy that did not list them correctly. They were a smooth top V70. Ugh. Time I cannot get back :hammer:
Dan McBoost
kieron_32v
Post by kieron_32v »
Dropped this mother f......Image
Whoa, cool
Juizer
Post by Juizer »
Spent yet again one 500€ for 200.. Yet again.
frostyflax17
Post by frostyflax17 »
got my care package for the touareg tdi, glad they're making us happy. I'm a tad worried about losing performance.
I've worked the most this week in years (a whopping 64hrs this week and 46hrs last week) so next paycheck will be helpful.
Took out a big loan to consolidate a couple small loans plus some extra so i can buy some car parts. If i can pay it off quickly there's another car in my future with some flare.
tomorrow shall be a good day filled with updates i hope. :)
Cory
11 Touareg TDI - Daily
91 CQ - Lifted Rallyx Mudder
90 CQ - 3.0T Rombotis
90 CQ - Wannabe S2
91 200 3b - restore and sell
86 Yamaha Fazer - Cafe Conversion
speeding-g60
got the shifter revamped and tested on the lift. now for the track.
frostyflax17 wrote: I've worked the most this week in years (a whopping 64hrs this week and 46hrs last week)
Part timer!
PLANETARY4
Post by PLANETARY4 »
This weekend I got my removed the cylinder head from the broken engine. painted my valve cover. put together the blower box and installed it. Weeeeeeeeeeee
Alex
'90 V8q
'95 S6
Dan McBoost
finally washed my A8L. Man it needed it. Wish I had the time (and energy) to detail the whole thing. I did not even get it to summer mode yet.
Also spent a bunch of time working towards getting my new server PC to match my carbonite back up (hard drive locations matching what needs to be there to not upload thousands of images that are already there...).
I was supposed to get all of the leaves off of my pool cover, but meh. I will struggle with that tomorrow. Was very humid and hot this weekend.
Dan McBoost
Post by alxdgr8 »
Probably won't be able to work on any cars for a few weeks since I have a new attention hog.
Picked up our Great Dane pup Lola on Monday. 7.5 weeks old and 18lbs. First night was pretty rough as I had to sleep on the floor right next to her crate, but last night went much better with us playing a 12hr long heartbeat Youtube video on a tablet next to her crate. Won't be able to pick her up for much longer I'm sure. Her mom is 140lb and her dad 180lb.
ImageIMG_20160530_102552 by Vex Art, on Flickr
ImageIMG_20160531_182705 by Vex Art, on Flickr
ImageIMG_20160531_124103 by Vex Art, on Flickr
A1QSHIP
Post by A1QSHIP »
Finished readying the parts for a Torsen in a small chassis rear differential today. V8 diff flanges & S2 rear axles. Oversteer here I come.
Nulla tenaci invia est via
Nice pup! That thing is going to be huge :)
PLANETARY4
Cool pup!
Sweet diff!
Alex
'90 V8q
'95 S6
varia
Post by varia »
i went to Minneapolis and got this beast from Ben (secretly hoping that Jim Green will throw a bone like "hey you slow boy, you wanna join me, im going to the track" :drive:
¯\_(ツ)_/¯
project 2226
Badass!
varia wrote:i went to Minneapolis and got this beast from Ben (secretly hoping that Jim Green will throw a bone like "hey you slow boy, you wanna join me, im going to the track" :drive:
Buttonwillow the weekend before thanksgiving! That's probably the next time I will be out:) I'll see you at BBQ before that at least, but we should get together soon anyways.
