Page 2 of 119
some color sample for the car
Posted: Sun Nov 16, 2008 10:41 am
by speeding-g60
did a little bit of stuff..... got the front fenders on, and front bumper. the color is alot different than i imagined, but it looks pretty cool. if it is alot of $$$ to get the required paint to paint the rest, i am just going to get a different color, though. it should be ok, and it WILL look pretty good with the gold rims that will end up on it. and i have decided to just get 15's as there is more choices for tires....
also, tossed in the newly painted, seam-welded rear subframe. with nice shiny 034 solid aluminum bushings..... i have to get the LCA bushings changed out to the 034 units as well, but the front end is all ready to go. i will clean up the rear diff, and put it back in soon. mount up the 4kq propshaft, and that will give me my starting point for the 01E trans.
on to some pixorz.... the color is more cinnamon or root-beer colored than i originally thought, but ts all good.
Posted: Sun Nov 16, 2008 11:12 am
by Belgarion115
Needs daytime pics, but nice color.
Posted: Sun Nov 16, 2008 11:32 am
by speeding-g60
ya i know. but its foggy out, and has dew on the car... maybe i go spray it down.....
Posted: Sun Nov 16, 2008 12:26 pm
by zerb
just curious as to what you did to get those stock rubber subframe bushings out?
i personally cut the tops, rubber section, off with a knife, then took a mini 2lb sledge and beat the ever livig schit out of it... :bashtard:
Posted: Sun Nov 16, 2008 12:50 pm
by speeding-g60
torch mostly. start melting them, and then they kinda just loosen up to fall right out. and sawzall. and hammer and punch.
by the time i was done, i had learned a decently fast method.
but the torch, did good.
Posted: Sun Nov 16, 2008 1:38 pm
by 123quattro
Last time I changed out a set on a 5000, we used a torch and an arbor press.
Posted: Sun Nov 16, 2008 2:18 pm
by zerb
my method of slicing the tops off then just hammering worked out pretty well, i just wanted to see what other methods there were out there is all. subframe looks good man, i painted mine as well. any thought of rolling/pulling those fenders so you can get some seriuz rubba under there on all four corners?
Posted: Sun Nov 16, 2008 2:39 pm
by speeding-g60
nah..... i inquired multiple times RE: the wide fenders, but i did not want the rears. craziest thing, they will not sell just the front fenders. period. no way in hell. i guess, whatever.
my thought was; if i bought a full set, and hit a wall or something destroying a front fender, i would then (following the idea that they cannot get them made in parts) have to buy a complete kit again. but i was informed that they would sell me a single fender. but they will not sell me two single front fenders. i do not want to get into the complexity of bodywork concerning the rears. the rabbit fronts were enough of a pain in the ass.
so i was lost at that point. but oh well, whatever. i do not think i could use them now anyways, due to the Rieger side skirts.
i have done lots of FG work, and i know that the molds for the widebody kit is a separate one for each corner. and had they really wanted to sell me a pair of fronts, they could have.
and to get back to the question at hand: no plans on it. i am not gonna run the car any lower than i need to for clearance of whatever slicks i choose. and if i am going to go for the wide body, i will just have a Rieger Evo 1 kit sent from Europe. or do a little something else to cover the tires if i need to.... involving Miata aftermarket flair kit maybe. will know when i get there....
oh yeah, and the subframes are more than just painted, they are seam-welded out as well. every surface that could be, was. and additional welding done on mount portions as well. i want no breakage here haha.
Posted: Sun Nov 16, 2008 3:56 pm
by vagrant_mugen
zerb wrote:just curious as to what you did to get those stock rubber subframe bushings out?
as did I. worked aight, and onl took like 20mins per SF.
Posted: Sun Nov 16, 2008 4:12 pm
by zerb
miata flairs eh? i was thinking about trying to get a set of 'g60' flares on there, but i havent found a set yet to play with. my boy has them on his mk2 thats just sitting for the winter, so i may steal them off of that and see what i can get to work.
Posted: Sun Nov 16, 2008 4:17 pm
by speeding-g60
hmmm. i wonder do i still have a set of those lying around. no, these miata flares were way big, and trimmable. go back to the tex, and look up in the drag forum Art (Lbsohk) FS post for his rado. he had them on there..... did not look all that bad.
Posted: Sun Nov 16, 2008 4:40 pm
by speeding-g60
i got a couple pixorz... sun not full out. but it looks ok. if i do not get a good deal on the paint, i am just gonna buy a gallon of the dark green VW metallic. thats ~85-90 a gallon for it.
Posted: Sun Nov 16, 2008 4:51 pm
by speeding-g60
and i got some little goodstuffs in the mail thruout the week....
the goods to make my rear tie rods and front steering arms....
and the DOM tube to make them with as well......
Posted: Sun Nov 16, 2008 5:07 pm
by zerb
ah. i see them on there. im still curious to what g60 flares will look like as well...
Posted: Sun Nov 16, 2008 5:21 pm
by Belgarion115
Those pics are great.
Does he get to help daddy much?
btw, Krylon and Rustoleum are cheap. :bashtard:
Posted: Sun Nov 16, 2008 5:32 pm
by speeding-g60
for priming stuff i imagine you mean. lets see, i get ~1.5 days at home every two weeks. so i think any progress at all is pretty good for the car. when i am off this job, i am gonna put the two VW's into a storage, and pull the coupe into the garage and have some time inside. all the work done so far has been outside, on the trailer or in the yard. so its coming along.....
i do have to spend time with chubby and his mom (my wife), right? if i didnt, you think she would dig me having two drag cars?
Posted: Sun Nov 16, 2008 5:38 pm
by RSCoupe
I like the maroon color. :-)
Posted: Sun Nov 16, 2008 5:57 pm
by speeding-g60
thanks Mark..... it looks good in person, especially for a track-only car.
and i forgot, aside from life, wife, son, two dogs, i also have one other hobby that requires a bit of attention. and chubby hangs out and helps with it, too.
by the_wide_stance
Maroon 5......valves per cylinder that is
Posted: Sun Nov 16, 2008 6:58 pm
by Wizard-of-OD
Salt water tank!? Jeez!
you really should come with me to Barbados next summer and we can catch all of the exotic fish you want
Posted: Sun Nov 16, 2008 7:24 pm
by vagrant_mugen
speeding-g60 wrote:and i got some little goodstuffs in the mail thruout the week....
hey, you wanna make me a set of rear tie rods??? ill pay you! or at least source the parts for me? i couldnt find the right rod-ends for the 034 rear tierod assmblys on the link they have on the page. i need a new rear assm. and at $100+ for each side, thats close to knockin on the 034 spherical rear set. i was just worried about dirt an shit, but i could mke some dust boots.
Posted: Fri Nov 21, 2008 11:05 pm
by speeding-g60
the link on their page worked for me.... and i have seen covers for the heims that are supposed to keep dirt out.
http://www.hrpworld.com/index.cfm?tpc=A ... on=product ... on=product
Posted: Sat Nov 22, 2008 1:09 am
by s2 on the way
lookin good
I'm likin the euro cabby bumper.....it makes for a very clean lookin front end
can your kiddo grab you tools and help a bit yet? Mine looks to be about the same age, its kinda fun having him help a bit
Posted: Sat Nov 22, 2008 4:47 am
by vagrant_mugen
the link worked just fine. but i couldnt find the heims that
they had posted on the page.
i thought the numbers were wrong.
apparently i was reading it incorrectly.
Posted: Sat Nov 22, 2008 7:04 am
by speeding-g60
vagrant - gotcha....
Dustin - he grabs and pokes around and stuff, yeah, lots. whenever i go to the garage, hes right on my ass saying "go fix cars" all the time..... its funny....
