Page 100 of 119
Re: Aarons 9 second Drag CQ: 2012 update!!!!
Posted: Fri Mar 30, 2012 7:23 am
:stupid:
Posted: Fri Mar 30, 2012 7:36 pm
by subvertdesign
Methanol. :D This car is so sick. Great work Aaron, can't wait to see more videos! Best of luck this season!
Posted: Fri Mar 30, 2012 8:14 pm
by quattro87
Looks great Aaron!! When did you add the intake manifold? Do you have the new dogbox in it yet? Once you have that in I think you are on the right path as far as thinking meth. Some more boost and timing could only help. :D
Posted: Fri Mar 30, 2012 9:26 pm
by 40v4kq
quattro87 wrote: Do you have the new dogbox in it yet?
Link to video
Posted: Sat Mar 31, 2012 5:29 am
by speeding-g60
John; i hadnt really been updating this thread. made a mini-series instead, though. here in order:
SEM mani and A2W changes viewtopic.php?f=6&t=42761
RS2 replica front end viewtopic.php?f=6&t=43816
Accusump incident viewtopic.php?f=1&t=44231
034 tubular control arms viewtopic.php?f=18&t=44664
dogbox building viewtopic.php?f=15&t=45105
lift viewtopic.php?f=6&t=45819
new turbo installed and new piping with new type of couplers viewtopic.php?f=6&t=46140
the SEM manifold was on the car at the last dyno, of ~740 AWHP and ~570 tq with 40 psi. with the OLD TURBO, as well.
i never really made a post on MG about the big power 40psi run? hmmm. i did everywhere else LOL
http://speeding-g60.com/?p=520
http://www.s2forum.com/forum/showthread.php?t=56143
http://www.audizine.com/forum/showthrea ... onight!!!!!
http://forums.vwvortex.com/showthread.p ... t=700+club
http://forums.vwvortex.com/showthread.p ... er-700AWHP
Posted: Sun Apr 01, 2012 7:40 am
by glibobbo21
This is one of the few cars Ive seen the feed on the "front" side of the fuel rail. Always thought about doing it too.
Posted: Sun Apr 01, 2012 10:54 am
by speeding-g60
i do that as my fuel cell is up front and the pumps are in the front as well.
Posted: Tue Apr 03, 2012 10:03 am
by fasterthenrs2
looks good man, get cople more sets of those ignition wires before you head out to dyno, youl need it
Posted: Sun Apr 15, 2012 6:18 am
by speeding-g60
lets see.... always doing stuff here, always.
new catch can and VC. the catch can is smaller as it never even got a drop in the prior configuration, so i took a couple ports off of it and shrunk it up some. here is a couple pics of the old one and then the new setup. i also separated the block breather from the end of the VC line, just something in my head says to do so....
i just love the way this guy makes my stuff, uses a brake to bend the parts perfect and then clamshells them together and the fit is great!
and the new setup..... people like me never leave well enough alone. always changing stuff.
Re: Aarons 9 second Drag CQ: 4-15-2012 update!!!!
Posted: Sun Apr 15, 2012 6:21 am
by speeding-g60
NHRA and my local track are stepping up the safety. and i dont want to deal with installing the diaper i got for the car.
sooooo, off to the welder i went.
oil retention catch pan....
Posted: Sun Apr 15, 2012 6:28 am
by speeding-g60
aaaaaand, i have been spending some time working on my shifter setup. and that is coming along just fine i think. at V-3.1 now, and i think i am going to stop as i like this setup the best out of the 3 versions. next up is to make the linkages for the trans end of things.
also, i have a new clutch flow control setup i will be using, it is fully adjustable and will provide the exact same amount of slip for launching, every time. no more will i need to try and remember how slowly to let the clutch out when launching. and the other neat thing? i only need to use it once as there is no more clutch use on the run.
i am anxious to run the car this year. really really anxious. but i will get to it when i get to it i guess. LOL
Posted: Sun Apr 15, 2012 6:47 am
by speeding-g60
also, did some light porting work to the hotside housing. these BW turbos, they leave a little to be desired in their casting with regards to inside finish. there is quite a bit of material to remove to make it match the flange even.
here is the old 1.00 after i ported it and the old 1.10 before and after porting. did that while in Vegas last year.
now on to the newer still hotside, and larger 67mm Billet turbo. this is 1.25 --> 1.10 --> 1.00
left is new 67mm, non-ported 1.25. right is old 63mm, ported 1.10.
some progress pix of the porting work and how much actually has to be removed. i havent really been in a documentary mode as of late, so i forgot to start from the beginning. but as you can tell, there is quite a bit of cleanup to be done, and just think of how much flow is gained by doing so. exhaust gases hit that big flat shelf/ledge/WALL and get slowed down. i bet i took the opening at least 18-20% larger overall. and yes, smooth is good on the exhaust side. it is the inlet side that has air/fuel mixture that a person doesnt want a polished finish on.
Posted: Sun Apr 15, 2012 8:46 am
by PRA4WX
Nice updates.
Aaron, i think you've posted previously, but don't remember where exactly plus i know you've been busy all the time-what is the car going to weigh in at this year ya think?
Posted: Sun Apr 15, 2012 9:02 am
Aaron, really nice work on the car lately. It is looking much cleaner and its got all the right goodies to get you really deep in the 9's! (at least)
Posted: Sun Apr 15, 2012 10:16 am
:stupid:
Lookin good Aaron!
Posted: Sun Apr 15, 2012 5:49 pm
by death 4kqt
i love the evolution of your engine bay. every time i check your thread the bay has gotten cleaner yet.
Posted: Mon Apr 16, 2012 11:40 am
by vr-vagman
Aaron, why you switched to wasted spark?
Posted: Fri May 11, 2012 5:50 pm
by speeding-g60
drove it up n down the street right quick. did a light launch and medium (clutchless) shift into 2nd. it grabbed and WENT! spooled up rather quickly and i let it out.
i cant wait to run it now.... LOL.
also, switched fuel to E-98. align tomorrow, do some AFR tuning on the new fuel and turbo on Tuesday, and then shakedowns next friday. THEN i will run IFO on May 27th.
Link to video
Re: Aarons Drag CQ: 5-11 update: first drive dogbox ;)
Posted: Fri May 11, 2012 6:25 pm
by mr_aj_johnson
From bike experience the easier you are on that dogbox the more frequently you'll be rebuilding it.
I cant wait to see a full run.
Posted: Fri May 11, 2012 7:39 pm
by JonathanL
Looks devilishly quick even in that "mini launch" there
Top notch stuff, as always
:thumbsup:
Posted: Fri May 11, 2012 8:24 pm
FREAKIN AWESOME MAN!
Posted: Fri May 11, 2012 8:33 pm
by bdcoombs
AWESOME
Posted: Fri May 11, 2012 9:54 pm
by HeartlessNomad12
oh wow
Posted: Fri May 11, 2012 11:38 pm
by fasterthenrs2
HOULY SHIFT
Posted: Sat May 12, 2012 7:57 pm
by my2000apb
track time, when?
