Page 95 of 106
Re: Tacos 4KTQ 20vt Swap: The Red Baron - Inspection Day
Posted: Sat Jun 21, 2014 12:08 pm
by AngryTaco
Ive been tuning the truck last couple days. Im moving into a house right now so ill finally have a garage to work out of again.
No more time excuses
Posted: Sat Jun 21, 2014 4:42 pm
You sure have done a lot of work without a garage!
Posted: Sun Jun 22, 2014 11:45 am
by AngryTaco
Re: Tacos 4KTQ 20vt Swap: The Red Baron - Moving
Posted: Sun Jun 22, 2014 6:27 pm
Hey did you pull the rear drive line before towing it like that? That center diff won't be too happy with you.
Posted: Sun Jun 22, 2014 7:19 pm
by AngryTaco
its an open differential you fools!
Posted: Sun Jun 22, 2014 9:59 pm
by AudiSport4000
But did you at least pull the driveshaft? Its only money, right?
Posted: Sun Jun 22, 2014 10:45 pm
You'll still burn that center diff up in that trans man.
Posted: Sun Jun 22, 2014 11:11 pm
by AngryTaco
Did no one read the 5 different posts where I said the trans is junk, Im putting a new one in, and I dont care?
Im finding the manual and posting a pic
Posted: Mon Jun 23, 2014 11:52 am
lol - we need to start showing taco some love and encouragement.
Hope the move went well dude, moving into a house will be a life changer for you.
Posted: Mon Jun 23, 2014 12:23 pm
by Noisy Cricket
It actually might not hurt anything because the center diff will be flooded with oil, and the trans gears will be turning which will splash lube up and around to things.
Lots different than towing a RWD without pulling the driveshaft, because then the only thing that turns is the output shaft... inside the gears which might be on needle bearings or they might be on bushings, and getting NO splash lube because the gears aren't turning.
Posted: Mon Jun 23, 2014 12:28 pm
by dana
themagellan wrote:lol - we need to start showing taco some love and encouragement.
is this a woman's forum? i thought we were 95% dudes here.
Dudes give each other shit when the other mess up or act weak. Thats how its done.
Posted: Mon Jun 23, 2014 1:26 pm
dana wrote:themagellan wrote:lol - we need to start showing taco some love and encouragement.
But we also encurage the stupid behavior that causes them to mess up!
I hope moving it to a new place was worth it. Post pics of the new work space when ready!
Posted: Mon Jun 23, 2014 1:48 pm
I did not know the preachings of the kingdom of brodum had reached this realm
this forum is slow… lately.
Posted: Mon Jun 23, 2014 5:10 pm
by AngryTaco
dana wrote:Dudes give each other shit when the other mess up or act weak. Thats how its done.
I think I receive about 95% of all the shit on this forum
Posted: Mon Jun 23, 2014 6:22 pm
by dana
i think its mainly in response to all the '20v is the best thing ever' comments
Posted: Mon Jun 23, 2014 7:10 pm
by carl
dana wrote:i think its mainly in response to all the '20v is the best thing ever' comments
too funny
Posted: Mon Jun 23, 2014 7:27 pm
by Noisy Cricket
You don't hear about 20vt people bending rods or breaking 016s do you?
Although at this point, I'm mainly going 20vt because I already cut the battery tray out... if I went 20vt then I'd have to find another battery tray and weld it in because there'd be no reason to give up all that cargo space. And yes, I'm dead serious. I think I'm at $4500 with the 20vt and still haven't bought a computer yet, and I plan on ditching the KKK turbo for a Precision PT5558 next spring...
There's a lesson in this. NEVER ADD UP WHAT YOU HAVE SPENT. And especially never do autotrader searches for 6-speed Allroads and realize that you could have just bought one of those AND fixed any suspension issues it probably had.
Posted: Tue Jun 24, 2014 8:52 am
by my2000apb
AngryTaco wrote:dana wrote:Dudes give each other shit when the other mess up or act weak. Thats how its done.
20v valves will get you half the shit of 10
Posted: Tue Jun 24, 2014 1:36 pm
by Colin2750
Has anybody ever actually had a problem with towing a car with two wheels on the ground? A coupe we had was towed like that probably 10 miles, was totally fine for the year+ we had it for... Just a myth?
Posted: Tue Jun 24, 2014 1:55 pm
by dana
Colin2750 wrote:Has anybody ever actually had a problem with towing a car with two wheels on the ground? A coupe we had was towed like that probably 10 miles, was totally fine for the year+ we had it for... Just a myth?
my friend towed a v8q that way and it sized something up and started dragging the arse end down the road. He sawzalled the driveshaft and continued.
But...that was also an automatic, a whole 'nother set of issues.
Posted: Tue Jun 24, 2014 2:04 pm
by vt10vt
dana wrote:Colin2750 wrote:Has anybody ever actually had a problem with towing a car with two wheels on the ground? A coupe we had was towed like that probably 10 miles, was totally fine for the year+ we had it for... Just a myth?
Has to have been Cyrus hahahaha
Posted: Tue Jun 24, 2014 4:50 pm
by AngryTaco
The automatics are torsion centers along with the later 016 trans. Those you can not tow like I did as they are technically limited slip differentials
Posted: Tue Jun 24, 2014 5:42 pm
by Noisy Cricket
They are technically open diffs, not limited slip... unless they have a preloading clutch/Belleville washer in them.
Posted: Tue Jun 24, 2014 5:55 pm
by scubagli
Either way torsion's do not like being towed like that.
Old and grumpy.
Posted: Tue Jun 24, 2014 8:57 pm
by pilihp2
Torsen center and rear on a v8. At least on all the other cars you've got an open rear and a torsen center, or open center. Torsen on both ends is the definition of NO
