Re: Tacos 4KTQ 20vt Swap: The Red Baron - Inspection Day
Ive been tuning the truck last couple days. Im moving into a house right now so ill finally have a garage to work out of again.
No more time excuses
- ringbearer
You sure have done a lot of work without a garage!
I dont want to hear about the "did you pull your axles?" questions. Even the manual says this is ok to tow in this manner. Even if it wasnt, I dont care because the transmission is junk and it deserves to be destroyed.
Re: Tacos 4KTQ 20vt Swap: The Red Baron - Moving
Hey did you pull the rear drive line before towing it like that? That center diff won't be too happy with you.
its an open differential you fools!
But did you at least pull the driveshaft? Its only money, right?
You'll still burn that center diff up in that trans man.
Did no one read the 5 different posts where I said the trans is junk, Im putting a new one in, and I dont care?
Im finding the manual and posting a pic
- themagellan
lol - we need to start showing taco some love and encouragement.
Hope the move went well dude, moving into a house will be a life changer for you.
Noisy Cricket
It actually might not hurt anything because the center diff will be flooded with oil, and the trans gears will be turning which will splash lube up and around to things.
Lots different than towing a RWD without pulling the driveshaft, because then the only thing that turns is the output shaft... inside the gears which might be on needle bearings or they might be on bushings, and getting NO splash lube because the gears aren't turning.
Pete, that rallycross guy
'06 Volvo S60 R (Swedish GTR)
is this a woman's forum? i thought we were 95% dudes here.themagellan wrote:lol - we need to start showing taco some love and encouragement.
Dudes give each other shit when the other mess up or act weak. Thats how its done.
dana wrote:is this a woman's forum? i thought we were 95% dudes here.themagellan wrote:lol - we need to start showing taco some love and encouragement.
But we also encurage the stupid behavior that causes them to mess up!
I hope moving it to a new place was worth it. Post pics of the new work space when ready!
- themagellan
I did not know the preachings of the kingdom of brodum had reached this realmdana wrote:is this a woman's forum? i thought we were 95% dudes here.themagellan wrote:lol - we need to start showing taco some love and encouragement.
this forum is slow… lately.
dana wrote: Dudes give each other shit when the other mess up or act weak. Thats how its done.
I think I receive about 95% of all the shit on this forum
i think its mainly in response to all the '20v is the best thing ever' comments
dana wrote:i think its mainly in response to all the '20v is the best thing ever' comments
Noisy Cricket
You don't hear about 20vt people bending rods or breaking 016s do you?dana wrote:i think its mainly in response to all the '20v is the best thing ever' comments
Although at this point, I'm mainly going 20vt because I already cut the battery tray out... if I went 20vt then I'd have to find another battery tray and weld it in because there'd be no reason to give up all that cargo space. And yes, I'm dead serious. I think I'm at $4500 with the 20vt and still haven't bought a computer yet, and I plan on ditching the KKK turbo for a Precision PT5558 next spring...
There's a lesson in this. NEVER ADD UP WHAT YOU HAVE SPENT. And especially never do autotrader searches for 6-speed Allroads and realize that you could have just bought one of those AND fixed any suspension issues it probably had.
AngryTaco wrote:dana wrote: Dudes give each other shit when the other mess up or act weak. Thats how its done.
20v valves will get you half the shit of 10
Has anybody ever actually had a problem with towing a car with two wheels on the ground? A coupe we had was towed like that probably 10 miles, was totally fine for the year+ we had it for... Just a myth?
my friend towed a v8q that way and it sized something up and started dragging the arse end down the road. He sawzalled the driveshaft and continued.Colin2750 wrote:Has anybody ever actually had a problem with towing a car with two wheels on the ground? A coupe we had was towed like that probably 10 miles, was totally fine for the year+ we had it for... Just a myth?
But...that was also an automatic, a whole 'nother set of issues.
Has to have been Cyrus hahahahadana wrote:my friend towed a v8q that way and it sized something up and started dragging the arse end down the road. He sawzalled the driveshaft and continued.Colin2750 wrote:Has anybody ever actually had a problem with towing a car with two wheels on the ground? A coupe we had was towed like that probably 10 miles, was totally fine for the year+ we had it for... Just a myth?
Sent from my SCH-I535 using Tapatalk
The automatics are torsion centers along with the later 016 trans. Those you can not tow like I did as they are technically limited slip differentials
Noisy Cricket
They are technically open diffs, not limited slip... unless they have a preloading clutch/Belleville washer in them.
Either way torsion's do not like being towed like that.
Old and grumpy.
Old and grumpy.
Torsen center and rear on a v8. At least on all the other cars you've got an open rear and a torsen center, or open center. Torsen on both ends is the definition of NO
