Page 83 of 119
Re: Aarons Drag CQ: 8-19 runs again WOOHOO!!!! dyno tomorro
Posted: Fri Aug 20, 2010 6:39 am
by my2000apb
good luck man, 9.87@141 wooooooot
hahahahah Aaron's had more startup vid's than ive had vehicles in total
Posted: Fri Aug 20, 2010 6:56 am
by speeding-g60
my2000apb wrote:good luck man, 9.87@141 wooooooot
dont forget, there were a couple with the rabbit, too
Posted: Fri Aug 20, 2010 6:59 am
by my2000apb
hahahh you need to make a top ten startup video list ahhahaahah
Posted: Fri Aug 20, 2010 7:19 am
by speeding-g60
i forgot that i was messin with my new video softwares..... i think this PIP vid is pretty close for sync.
Link to video
Posted: Fri Aug 20, 2010 7:22 am
by fasterthenrs2
Awsome dude good luck on a dyno tommorrow
Posted: Fri Aug 20, 2010 7:26 am
by speeding-g60
dyno tonight
all i need is 652 AWHP LOL..... i joke hahaha
Posted: Fri Aug 20, 2010 7:31 am
by fasterthenrs2
Just watched the vid, my there is true, you were tryng to get ower the line in third, ouch
Posted: Fri Aug 20, 2010 7:38 am
by speeding-g60
oh i got it in 3rd, for 10.7 @ 138.
9200 rpm, tap tap tap limiter a couple times and BOOM.
that motor was already down on power, it was fading.
each run before, i got closer and closer to the finish line in 3rd and the last pass before BOOM i barely shifted into 4th before crossing.
so i bumped it up, pushed 3rd to finish and finished it.
Posted: Fri Aug 20, 2010 8:25 am
PIP is freakin sweet. Are you going to try to sync the camera from your sunglasses too?
Posted: Fri Aug 20, 2010 10:50 am
by speeding-g60
haha... yeah eventually.
Posted: Fri Aug 20, 2010 12:11 pm
by iluvfastcarz
Greetings from Albania, keep up the good work Aaron.
Posted: Fri Aug 20, 2010 2:10 pm
by speeding-g60
hi Lido..... hurry back so you can finish your car. but find the mounts and stuff you need first. and bring some more cool Euro partz
Re: Aarons Drag CQ: 8-20 dyno in 1.5 hrs....
Posted: Fri Aug 20, 2010 5:56 pm
by Toxcheap
Did you dyno that thing already or what..
Some of us are impatiently waiting..
lol
Posted: Fri Aug 20, 2010 10:15 pm
by speeding-g60
meh.....
506/378 for the base pull, 23 psi and 17 degrees to 7k rpm in 3rd gear.
three more pulls, and then we want to turn it up. but there was a noise on shifts, a rattle sort of, so we pulled the plug.
better to quit early and save it instead of total waste like normal.
had alot of ears there this time, at least 4 people heard the noises....
but still, motor runs good other than what sounds like a rod knock or something. and without time to tear it down, oh well. car still goes to show anyhow.
i swear someone out there has a voodoo car doll on me. i just feel it. someone hates me and wishes ill will upon me....
Link to video
Re: Aarons Drag CQ: 8-20 dyno done. heard noise and stoppe
Posted: Fri Aug 20, 2010 11:02 pm
Aaron those are still numbers to be proud of!!! I hope the noise turns out to be somthing simple! Are you still going to run it at the show? Anyways, I gotta go to bed. We are out of here early tomarrow. So I will be seeing you at the show man! Even if you don't get to run, it will still be great to meet some fellow MGers in person!
Posted: Sat Aug 21, 2010 12:16 am
by quattro87
A rod knock? That loud that you could hear it above the dyno noise? Did it get louder with each pull and was it there on the first? I have to say you have had your trials with this car. Hang in there. It's still pretty impressive that you have it not only put together, but even have had it on the dyno, and all of this in time for the show. Awesome!!!!!
Posted: Sat Aug 21, 2010 3:19 am
by fasterthenrs2
That sucks man, did engine got blue printed this time??? If yes look thru it. 500+whp is still impressive lets hope you find the noise
Posted: Sat Aug 21, 2010 4:11 am
Thats weird. Hopefully its something little and stupid.
If you blow another 1.8t up I suggest you quit that ninny shit and go 5-cylinder
just kidding of course
Posted: Sat Aug 21, 2010 5:59 am
by speeding-g60
loxxrider wrote:Thats weird. Hopefully its something little and stupid.
actually. if i kill another IMPORT i will quit IMPORTS and make a DOMESTIC for under 5 grand and run 9's all damned day....
and yes Janis. everything is documented....
but one day to take it apart and put it all back together providing nothing major is wrong is not enough time anymore. i am tired.....
Posted: Sat Aug 21, 2010 6:37 am
by frostyflax17
uht oh, don't go to the dark side!
owning a domestic racecar is like doing a hooker. it's been done... a lot.
just swap the gameplan a little, maybe put a v8 in there with a s/c or something. make it interesting!
Posted: Sat Aug 21, 2010 6:57 am
by Noisy Cricket
speeding-g60 wrote:actually. if i kill another IMPORT i will quit IMPORTS and make a DOMESTIC for under 5 grand and run 9's all damned day....
I'd like to see it happen for under $5k, not starting from a garage full of two decades of leftover parts.
Posted: Sat Aug 21, 2010 7:04 am
by zerb
hopefully this motor will be fine man. fingers crossed here.
if not, vr6t.
Posted: Sat Aug 21, 2010 7:17 am
by speeding-g60
one last time wrote:[/quote]will not go to a VR6. PERIOD. manifolds, all the $$$ in the solid cams and lifters and head, new bottom end, mounts, clutch, injectors, rail, everything is 4cyl only.
turbo, wastegates, fuel pumps, fpr, lines, AWIC. that is it. thats all that i could use. and since that isnt but maybe 20-25% of the overall, its not worth it.
new harness.
manifolds.
exhaust.
motor build.
head build.
all new tuning yet again.
injectors.
fuel rail.
mounts made again.
clutch.
relocate radiator.
and on and on.....
no way at all i am doing that stuff. as i said from the beginning, i have too much 4cyl oriented stuff to even think about platform change. i already have at my disposal a full 12V OBD2 VR6 motor.... and if i wanted to do something other than 4cyl from the beginning, i would have. 5cyl probably would have been the choice....
sorry, not this kid. if this one is done for already, look for my 9 second Mustang next season[/quote]
and anyone else out there who wants to make a VR6, feel free..... but not me.
you guys have more chance of seeing me yank this stuff and doing a twin turbo SBC and 'glide in here RWD than a VR6. (now the wheels are turning..... AGAIN).
Posted: Sat Aug 21, 2010 7:19 am
by speeding-g60
Noisy Cricket wrote:[/quote]I'd like to see it happen for under $5k, not starting from a garage full of two decades of leftover parts.[/quote]
thats just it, thats the kind of Domestic support i would have.... tons and tons. car for free, that sort of thing. a few friends who are where i am at now with this car, but with their own stuff. or their past stuff when they went bigger, etc.
Posted: Sat Aug 21, 2010 7:44 am
by Noisy Cricket
Ah... access to OTHER PEOPLES' garages.
BTDT. Half of the rotary stuff (and, come to think of it, VW stuff) I have is from people who were cleaning house and said those fateful words: "Anything you don't take, I'm just going to throw out." (fade to: Dodge Durango dragging its reciever hitch on the ground)
PS - You can fit *six* rotaries in a Durango, along with a whole lot of iron housings and boxes of misc. crap.
PPS - I don't actually own a Durango, but you can only fit two rotaries in a Golf so I had to borrow a friend's.
PPPS - THIS IS WHY STATION WAGONS RULE, PEOPLE
