Page 9 of 76
Posted: Mon Apr 17, 2006 4:40 pm
by yodasfro
Yeah I may end trying to find a cheapy aluminum rad.
Posted: Mon Apr 17, 2006 4:44 pm
by Wizard-of-OD
Looking good marc! :woowoo:
Posted: Mon Apr 17, 2006 6:02 pm
by JShadzi
Should have a nice shipment ready for you tomorow
Posted: Tue Apr 25, 2006 6:13 pm
by Marc
JShadzi wrote:Should have a nice shipment ready for you tomorow
:woowoo:
The Spec stage 3+ clutch and PP arrived today, now all I need is the pilot adapter and I can finally bolt up the motor for the final(? lol, yeah right) time.
:pics:
Posted: Tue Apr 25, 2006 6:22 pm
by owdlvr
Hey Marc,
Can I get a better photo of your brake line set-up at the MC?
-Dave
Posted: Tue Apr 25, 2006 6:38 pm
by Marc
owdlvr wrote:Hey Marc,
-Dave
Hmm, not really, especially since I've done zero line routing yet. If you're trying to determine stock routing this (obnoxiously large) photo _might_ help:
Posted: Tue Apr 25, 2006 6:39 pm
by Marc
I've also got the bentley right in front of me, whaddya need to know?
Posted: Wed Apr 26, 2006 9:02 am
by owdlvr
I'm still trying to wrap my head around the routing for eliminating the ABS module.
Not sure why I can't picture this in my head...
-Dave
Posted: Wed Apr 26, 2006 9:59 am
by Marc
owdlvr wrote:I'm still trying to wrap my head around the routing for eliminating the ABS module.
-Dave
ETKA helps out here..
looks like the fender side of the proportioning valve needs to go to both rear wheels, while the opposite end goes to the right front wheel and the other two ports are connected to the master cylinder. The furthest out port on the fender side of the master cylinder goes to the left front wheel.
Corrections anyone? Looks right from the diagrams I'm looking at.
Attachment ( 4325 ) : brake_routing_front.jpg
Attachment ( 4324 ) : rear_brake_lines.jpg
Posted: Wed Apr 26, 2006 10:40 am
Here's a few pics that I made when I deleted my ABS
Stock 80q without ABS
Posted: Wed Apr 26, 2006 11:54 am
by Marc
hey, I guessed right! (well, got front right/left swapped, but I dont think that matters).
Nope.
Posted: Tue May 02, 2006 6:38 am
by Marc
A few more 034 boxes arrived yesterday
Last weekend I mounted the battery in the trunk. I think I'd prefer an under-seat mounting much like Myke did on his 90 but this will work fine for now:
:pics:
Plus I pulled the stock 7A engine harness out. Now to put all those connections back onto the fusebox....
Posted: Tue May 02, 2006 6:39 am
by yodasfro
Looking better and better Marc!!!!
Posted: Tue May 02, 2006 6:55 am
by Shawn M.
marc, what rad is that? Is that a summit piece if so what pn and will it fit a 4kq?
Posted: Tue May 02, 2006 7:13 am
by Marc
Shawn M. wrote:[/quote]marc, what rad is that?[/quote]
Summit Racing PN SUM-380331
No idea on 4kq fitment... What application? V8? Probably yes. 5 Cylinder? Probably no.
Posted: Tue May 02, 2006 7:38 am
by Shawn M.
for a 5 cyl..
Posted: Thu May 04, 2006 5:40 pm
by Marc
034 motorsports pilot bearing arrived today
:thanks:
Just in time to take Friday off and spend the day at the shop, and Saturday, and Sunday.
:woowoo:
Posted: Thu May 04, 2006 7:58 pm
by Alloutofdonuts
a4kquattro wrote: I think I'd prefer an under-seat mounting much like Myke did on his 90 but this will work fine for now:
You don't happen to have any pix of his do you? I was going to do that but seems like it is too tight(ground clearence, Clarence), even though the Urq get's away with it... :?
At this rate you'll be done with this car before I finish mine!
8)
Posted: Fri May 05, 2006 3:59 am
by Marc
Alloutofdonuts wrote:a4kquattro wrote: I think I'd prefer an under-seat mounting much like Myke did on his 90 but this will work fine for now:
No, dont think so. I'll snap a few at the shop today.
8)
There is actually plenty of room. His battery box goes plenty deep yet still stays above the bottom of the frame.
Posted: Fri May 05, 2006 5:51 am
by WAUG0806
git er done! :woowoo:
Posted: Fri May 05, 2006 11:09 am
by Alloutofdonuts
Is Tox's battery box on the passenger or drivers side? I guess I should wait to see the :pics: instead of asking all kinds of questions on your project thread
Posted: Fri May 05, 2006 11:16 am
by Shawn M.
should be on the pass side for weight distribution
Posted: Fri May 05, 2006 11:37 am
Posted: Fri May 05, 2006 2:54 pm
by Marc
Thanks for the link Jim, I forgot to take pictures while I was at the shop today..
Update! Finally making some progress here, installed clutch and pressure plate:
And now that the important bits between the engine and transmission are all set I can start putting stuff together :woowoo:
Things are VERY tight around the brake master cylinder. I'm thinking I'll need to tweak that upward a bit.
