Page 79 of 125
Re: Jim Green's 90q 20vt - eats ZR1's
Posted: Thu Mar 01, 2012 8:37 am
by my2000apb
audifreakjim wrote: What we really need is new knuckles
paging haydn
paging 5 axis
and paging big block of alu
Posted: Thu Mar 01, 2012 12:15 pm
996tt Big reds, brackets and new MC are all on the way for Sat! So hopefully I have good news about fitment this weekend. Pads will be here next week.
Posted: Thu Mar 01, 2012 12:37 pm
by a_CQ
Nice. Are you going to LS on 3/16? I talked to Gordon and was very close to signing up for it...wish I did.
Posted: Thu Mar 01, 2012 12:38 pm
So did you get any video at the track? :vids:
Posted: Thu Mar 01, 2012 12:59 pm
by EDIGREG
chaloux wrote:So did you get any video at the track? :vids:
:stupid: :vids: :vids: :vids:
Posted: Thu Mar 01, 2012 4:25 pm
Yes, Laguna Seca is the modivating factor behind this fire drill. Just do it! Or spring mountain, either way you can't lose . I need to have this thing all sorted by the 15th which is like tomorrow with my schedule.. Looks like the carbotechs are out for a pad choice, waiting for them to make the pads is not going to happen when I am at the tiki bar in Costa Mesa and looking at Porterfield out the window.. So I walked over and grabbed some hawk Ht-10 pads for the track and R4s pads for the street.
Vids at Buttonwillow? I wish.. I didn't bother in the morning then forgot in the afternoon. Sorry, I wish I had them believe me!
Posted: Sun Mar 04, 2012 10:44 pm
Everything works with the Apikol "10A04132" bracket that is for the ur-s cars and 996tt. There is some very slight pad overhang on the outside of the rotor so I just hit them with an angle grinder, it's less than 1mm. I also used a .7mm shim to perfectly center the caliper on the rotor. I was hoping to try and run the 345mm rotors, but I only have about 5mm clearance between the caliper and inside of the wheel.
Attachment ( 29845 ) : IMG_1047.JPG
Attachment ( 29846 ) : IMG_1048.JPG
Attachment ( 29847 ) : IMG_1043.JPG
Posted: Mon Mar 05, 2012 12:40 am
Those look great. How do they fit to the spokes? Spacers needed?
Posted: Mon Mar 05, 2012 8:26 am
by Quattro v1.0
Jimmy got big boy brakes
Posted: Mon Mar 05, 2012 8:30 am
by a_CQ
Nice. What rotor is that, and are you on S2 or UrS hubs??
Posted: Mon Mar 05, 2012 8:40 am
by Mushasho!
So UrS components are compatible... this clears things up a bit, thanks... And I take it you ended up with Zimmerman A8/S8 323x30 rotors too...?
Posted: Mon Mar 05, 2012 9:10 am
Yep. These are vented on the outside which I am not thrilled about, has anyone found this rotor with vent intake on the inside of the rotor?
Hanks, I need an extra 4mm spacer on the RPF1's, but it's more like a 5mm spacer because the hat on these A8 rotors is much thicker than my old setup.
Posted: Mon Mar 05, 2012 9:15 am
a_CQ wrote:Nice. What rotor is that, and are you on S2 or UrS hubs??
D2 A8/S8 323x30mm rotors, S2 Hubs, 996tt/4S calipers, and Apikol 10A04132 brackets
Posted: Mon Mar 05, 2012 9:44 am
by a_CQ
Ahh, S2 hubs. There are rotors that are vented form inside the hub but they are 321x30. B5S4 should be equivalent to the hat offset you have.
Posted: Mon Mar 05, 2012 9:48 am
Cool, thanks. We'll see how this setup does, but I think the next rotors will be two-piece 1.25"x13.2"
Posted: Mon Mar 05, 2012 10:07 am
by a_CQ
Might as well
Posted: Mon Mar 05, 2012 10:59 am
by 123quattro
Just have Coleman make up some stuff for you.
Posted: Mon Mar 05, 2012 11:52 am
by Mcstiff
123quattro wrote:Just have Coleman make up some stuff for you.
They should have specs for the urS from BIRA; not sure if they are willing to sell them.
Posted: Mon Mar 05, 2012 11:59 am
Apikol has them, but Hank has a wheel of mine that that would be a good trade for some hats
Posted: Mon Mar 05, 2012 12:11 pm
by a_CQ
Do it, Hank. I'd be interested in a lighter rotor if I can stuff it under the regular 996 claiper.
Posted: Mon Mar 05, 2012 1:15 pm
I didn't think you could put 32mm rotors in a regular 996 caliper. Lots of shaving of the pins?
Posted: Mon Mar 05, 2012 1:22 pm
by Mushasho!
ShavedQuattro wrote:I didn't think you could put 32mm rotors in a regular 996 caliper. Lots of shaving of the pins?
Sizes are as follows:
996tt rotors are 330x34 & 330x28
996 rotors are 318x28 & 299x24
993tt rotors are 322x32 & 322x28
993 rotors are 304x32 & 299x24
930 rotors are 304x32 & 309x28
HTH
Posted: Mon Mar 05, 2012 1:51 pm
by a_CQ
Pins are not an issue, but fitting new pads might be, as well as upper edges where most outter diameter of the rotor spins... I'll have to measure up.
Re: Jim Green's 90q 20vt - The quest for 275's
Posted: Fri Mar 09, 2012 8:46 am
by nm_audi
RSCoupe wrote:audifreakjim wrote:...I ended up going with the Eastwood concours spray gun...
Good choice. Great price, and a good gun. It's the one I use.
What tip (1.2 or 1.4) are you all using on this gun? Any suggestions on gun set up? I just bought one to spray my engine compartment before installing the 3b swap.
Thanks in advance.
Posted: Fri Mar 09, 2012 9:05 am
1.2 for color and 1.4 for clear. It is made for water based paints hence the slightly smaller tips, but still works for normal paint. I am still figuring it out to be honest.. Put some water or something else to practice spraying with and go through the adjustments to get a grasp on what everything does. One of my issues is the amount of light in my garage, it was hard to tell what speed I needed to go to achieve a wet coat on the clear, so it ended up going on thicker than it should, which lead to quite a bit of wetsanding and it still isn't that smooth. It's a good gun, but make sure you have lots of light before you spray..
