Re: Taco's 4KTQ 20vt Swap: The Red Baron - Hot Start...Fixed
Rod journals are different between 20v and 20v. I would basically put 20v internals in a 20v block
Also lighter and less rotating mass
After reading what Im doing, I might as well rename this car to "Ghetto 20vt Swap" LOL
for some reason i was thinking 20vt main journals are a different size too, not positive on that.
scratch that, mains appear to be the same.
Yeah the mains are the same. I need to figure chamber CC of an AAN piston or head chamber to figure what what combo will work. The 9:1 3B pistons may be better suited. If final compression resulted in 10.0 - 10.5:1 I would be happy
- themagellan
So going through with all of the hybrid 20v pieces to build the ultimate 20v is basically out of spite? Will be watching
3b and AAN pistons are identical from what I have seen.
Don't the 20V pistons have valve reliefs?
Cheers, Brady
72 240Z 123whp
www.dynodoc.ca
72 240Z 123whp
www.dynodoc.ca
Yes they do for the intake valves I believe.
But they won't line up on your 20v!
Cheers, Brady
72 240Z 123whp
www.dynodoc.ca
72 240Z 123whp
www.dynodoc.ca
PKW had the mc block and pistons shaved 4mm for a ghetto 20vt. Maybe you could have the mc block decked 8 mm and run the AAN pistons. You probably would have to machine some new valve reliefs and maybe you could get some wrist pin bushings to fit the MC rods but with a 20mm bore???
Wow this car hates me. I got a good 20vt MM hose from a friend that I'm borrowing for diagnostic purposes (current hose has a hole) and as soon as I went to drive it, I heard an electical "pop" and everything died. I lost ALL power completely. Nothing would reset, nothing worked, EXCEPT, the AMP lights were on meaning they were getting the signal from the head unit....even though it was off???????
This would have been fine if I wasnt at the bottom of a hill with a dead phone. I had to push the car back up the hill with the dodge and back into the garage......oh fun shit.
I think my power distribution block took a shit or something because the battery has plenty of power and if I hook jumpers up to the block, everything will work again until I take the jumpers off the power block
The good news is I now have a medium-duty drill press LOL
The battery cable exploded.....wtf
http://www.motorgeek.com/viewtopic.php?f=10&t=84
20v combustion chamber volume: 29cc
20v combustion chamber volume: 38cc
NG bore: 8.25cm
NG stroke: 8.64cm
NG CR: 10:1
NG bore: 8.25cm
NG stroke: 8.64cm
NG CR: 10:1
Oh hotdog! Guess I got some math to do tonight
Well small update. I had a set of fiberglass silicon ISV hoses made up which I'm test fitting tomorrow. Will update with pictures later
This car is going to land me in jail........seriously. Hell it almost did tonight. I think I'm going to hide....er.....park this thing for about a month before I drive it again.
AngryTaco wrote:This car is going to land me in jail........seriously. Hell it almost did tonight. I think I'm going to hide....er.....park this thing for about a month before I drive it again.
What did you do now? LOL
85oceanic wrote:AngryTaco wrote:This car is going to land me in jail........seriously. Hell it almost did tonight. I think I'm going to hide....er.....park this thing for about a month before I drive it again.
Ummmmmm.......I'd rather not post it all over the internet for the po po to see lol
Lol, you will have to text me what you did. I have had so many chances to go to jail in mine too. good thing I have to take it apart after BBQ and take all winter to fix it. now that its making big power, its way too hard to keep it in check. Im always being egged on for a race.
Then tell us what someone else did!
Lets just say it was a race for freedom and I won
LOL
Taco, a true American freedom fighter.
