Re: Marc's 1990 4.2L V8 Twin Turbo Coupe Quattro
timmmy wrote:Just kidding, bump
That was sick.
:lol:
WAUG0806
Post by WAUG0806 »
:bump: C'mon somebody give Marc $12k to spend on his old 4kq! :bump:
WAUG0806 wrote::bump: C'mon somebody give Marc $12k to spend on his old 4kq! :bump:
already got the driveline for it, built 200q20v motor, vems, etc. should be good :)
WAUG0806
Post by WAUG0806 »
Good... all the parts and $ from the sale are pretty much in elQUANTUMino, except for the ECU and some minor plumbing....
Attachment ( 31546 ) : s-elq power up 2012 Friday 038.jpg
well... whens it going in? :)
ralleyquattro
Post by ralleyquattro »
How did you manage to copy your entire project?? Very cool.
Martin Pajak
http://www.quattro.ca
82 Audi Ur-q, SQ project
83 Audi 80 q, Euro 2-Door
85 Audi Ur-q, Euro mit 3B
91 Coupe Quattro
Mark has magic fingers
ralleyquattro wrote:How did you manage to copy your entire project?? Very cool.
Marc wrote a script to import projects... shoot him a PM if you are interested.
Audilard
Post by Audilard »
I think as part of the import you at least have to provide an update of some sort! :)
Darin
1989 80 20vt
11 year bump?
Just picked up a c5 RS6 motor for the car. Going to pull the motor and swap to factory me7 (we tune these all the time). Turbos will likely change while I’m at it from what’s in there now.
Kinda excited to revive this thing. Needs a thorough interior cleanup and probably a vinyl wrap.
Post by alxdgr8 »
Nice!
I’m excited for updates!
got the nose pulled this weekend. Cooling system is going to get a major re-work. not enough fan area so i'm likely to add an additional auxillary radiator to the passenger fender area.
looking over the c5 motor my primary area of concern is clearance to the brake booster. the c5 has a lot going on back there in terms of coolant lines and EGR piping that will need dealing with. turbos i'm likely to get lazy and just use my existing manifolds with some better turbos. i just have to confirm the manifold flange is the same.
I tripped, fell, and decided a 4.0t was a better plan. Shorter better packaging and more efficient
What year 4.0t did you grab it from (does it matter all that much?) curious on the dimensions, that is going to be a wild package in a CQ!! Hope to see some build pics.
themagellan wrote:What year 4.0t did you grab it from (does it matter all that much?) curious on the dimensions, that is going to be a wild package in a CQ!! Hope to see some build pics.
2015 A8 from copart. wreck didn't even break the cooling system.
donor 2015 a8
donor 2015 a8
