Re: Taco's 4KTQ 20vt Swap: The Red Baron - MOAR BOOST AND PI
Nice work Jared!
Thanks!!!
DOES ANYONE HAVE A GOOD DIVERTER VALVE THEY CAN SELL OR LEND ME AT BBQ?
Mine cant habdle the new turbo!!!!
AngryTaco wrote:Thanks!!!
I think I have a Bosch one I can bring and you can have. I also have a Baileys I could bring, but I'd need it back as it is for my Porsche.
If were to lend me the baily one Id be very obliged. I dont think the bosch will stand up. I have a 710n right now
- ringbearer
My 710n is holding up fine at 28psi with a GTX3071.
Are you sure the diaphragm is good?
I havent had the time to inspect it. It will hold a vacuum if I suck on it. Something is opening up and releasing pressure. The car will run at 1bar (0 psi) like an N/A car until I release pedal and get on it again
Well turns out theres a big boost leak too where the michelin man hose is. Anyone got a spare mm hose running around I can borrow
Give me your address, ill send you the one I said I had a while ago. When is BBQ?
I leave for la grande tomorrow :(
So I'm here again in La Grande. I now have 3 speeding tickets from this car as well
We discovered that the vacuum line going to the bpv had a few big holes in it. Threw a new line in and still getting the sudden boost lost issue. I know theres a hole in the MM hose but I just dont see how it would cause sudden boost lost. We'll try a diverter valve while I'm down at BBQ.
The hose might cause an issue where the rip only decides to open up at higher boost.
replace that hose and you might see an improvement.
You using a stock mc1 michelin man hose?
2nd. Weird, I thought I replied saying that. Must have been dreaming.
Well even with the boost leak, my 20vt has now joined the 150mph club!! That was on FLAT ground too!!
Re: Taco's 4KTQ 20vt Swap: The Red Baron - 150mph club
Be careful!
Kinda funny, the fastest I've ever been in my 200 was when it was almost completely stock. 145 was the number.
Dutchbroracer
loxxrider wrote:Be careful!
What will the 200's do top speed wise? With stock 016? I'm sure someone here has tested it.
BTW nice car taco! 150 mph in a old school audi must feel like 200 lol
Dutchbroracer wrote:loxxrider wrote:Be careful!
Thanks!
Theoretically, it can do about 165 with a 20vt as it has 3.89s and a rev limter at 6400. 20vt no idea what their limiters are
Dave why arent you here yet!?
hay now...I'm here somewhere. you'll have to find me.
- themagellan
162 here with TAP chip and Open DP - Had more in it... but yeah.... that was on stock suspension...
So it was like floating!
150+ in a properly sorted oldschool Audi felt as good to me as anything. MUCH more confidence-inspiring than anything Japanese or American that I've ever been in the triple digits with.
chaloux wrote:So it was like floating!
You guys have nooo idea. LOL
- themagellan
lol floating would absolutely be the word. The scariest part was realizing how useless stock g60 brakes are over anything 130+.... well lets say MORE useless at those speeds
taco when are we going to see some 200mph runs?
Your 150 mph club thing got me thinking about my car so I did some calculating...for you to hit 150mph with 411 gearing, 205/55/15 tires, and a .81 5th gear you would have to hit just over 7000 rpm. at 6k rpm you are doing about 130.
Dan
1984 Ur quattro
1987.5 Coupe GT Special Build
1984 Ur quattro
