Mcstiff wrote:No AC comments eh?
Anyway, Thinking about compression numbers...
12psi+6psi=18*10.3=185.4psi
185.4psi/9.3=19.3-12=6.3psi
7a stock sea level cyl pressures are like 151psi and the stock 3b is about 244psi.
Would it really be dumb to bolt this to the stock 7a longblock? :bashtard:
If not, the worst thing to do would be the oil feed and return (the wiring is time consuming but fairly clean and quiet).
The difference between 10.3:1 and 9.3:1 is something like 10hp at that displacement/air pressure, which equates to something like 1-2psi boost needed to make up the power loss. That said, peak cylinder pressures under load are hundreds of psi lower, reducing the knock risk.
Pavel's car is fast as shit for what it is, I think you'd have a lot more trouble getting there reliably with stock compression. 9.3:1 is really not that low, but so much more friendly to boost on pump gas. It's nicer to your rods, too.
Sam
