Page 70 of 106
Re: Taco's 4KTQ 20vt Swap: The Red Baron - VOLVO K24 ON THE
Posted: Tue Sep 17, 2013 5:17 pm
by AngryTaco
I needz moar efficient boost
Posted: Tue Sep 17, 2013 7:01 pm
scubadave wrote:Hey now, love the turbo...but don't loooovve the turbo. Mkay?
I was thinking the same thing!
Posted: Tue Sep 17, 2013 7:32 pm
by scubadave
I tried to put up the robot chicken humping robot gif but can't make it work on my phone.
Edit...nevermind, fixed it with my tablet.
Posted: Wed Sep 18, 2013 11:31 am
by scubadave
- ludicrous-speed1802781069.png (363.25 KiB) Viewed 27084 times
Posted: Wed Sep 18, 2013 4:48 pm
by AngryTaco
MAH TERBOZ HAZ ARRIVEZZZDDDD!!!!!!
Posted: Wed Sep 18, 2013 4:54 pm
by scubadave
Is it running yet!?
Posted: Wed Sep 18, 2013 6:45 pm
by AngryTaco
It depends on how I feel honestly. I might do it before I drive down to Bens place in a couple weeks for our epic pre-bbq weekend
Posted: Wed Sep 18, 2013 9:11 pm
Do it or... I dunno. I guess don't.
lol
DO IEEEET. I need another red 4ktq to look at. One that fakin works
Posted: Wed Sep 18, 2013 11:00 pm
by AngryTaco
Lol. I decided if I have all the parts by Friday, Ill do it this weekend
Posted: Thu Sep 19, 2013 10:20 am
by my2000apb
diff en route
Posted: Thu Sep 19, 2013 10:51 am
by AngryTaco
Yay!!! Going 3.89s beotches. Damn you Dan!
ERMAHGERD MAH PORSCHE TERBOZ PARTS ARRIVEZZZZ TODAYZ!!
Posted: Thu Sep 19, 2013 11:04 am
Good, now get them all put together and installed! Im sure it wont take you too long.
Posted: Thu Sep 19, 2013 1:12 pm
by GTJeff
Wouldnt the first thing be to take the wbo2 out of the truck and stick it in the 4k......?
Posted: Thu Sep 19, 2013 2:48 pm
by AngryTaco
Youve been talking to ben havent you?
Lol. Im working on it
Posted: Thu Sep 19, 2013 5:57 pm
GTJeff wrote:Wouldnt the first thing be to take the wbo2 out of the truck and stick it in the 4k......?
No freaking joke.
Posted: Thu Sep 19, 2013 11:15 pm
by AngryTaco
Who needs a wideband when you have a narrowband and a natrix chipped ecm?!
Re: Taco's 4KTQ 20vt Swap: The Red Baron - VOLVO K24 IS HERE
Posted: Thu Sep 19, 2013 11:40 pm
by AngryTaco
So finally got everything in. As requested, I have posted the following pictures showing the difference between the modified audi k24 housing and a stock porsche K26 #6 hotside. It's quite noticeable really.
Here it is in all its shiny glory after I mated it to the porsche K26 housing
Porsche K26 exit bore diameter
Porsche K26 entry diameter
Modified Audi K24 Exit Diameter
Modified Audi K24 entry diameter
Porsche K26 Entry Way
Audi K24 Entry Way
It's really hard to tell from the last 2 pictures, but the Porsche K26 has a much larger runner going into the turbo housing. Me and scubadave believe this is a good reason to his detonation issues. The exit diameter on the Porsche k26 is a MUCH better fit with its 50.00mm diameter. I'm honestly not sure what that will change over the 51.xx mm exit diameter of the modified Audi K24. Perhaps a reduction in turbulence????
All I know is I'm going to polish what I can on the inside of the porsche hotside and enjoy the hell out of this turbo.
Posted: Fri Sep 20, 2013 12:31 am
by scubadave
My name is Scubadave and I approve this message.
Posted: Fri Sep 20, 2013 11:09 pm
by AngryTaco
Ugh. Had a fight with the CIS tonight. Fired it uo after 2 weeks of sitting and it did NOT want to idle. After backing out the idle adjustment screw, it finally idled. I dont get it. 2 weeks ago it was fine. I do know there is something wrong with the fuel system. I hooked up a pressurr gauge between the WUR and the fuek distributor and measured the fuel psi after shutting the car off. It idl es at 55-60psi which is normal. Then upon shutdown it immediately drops to 15psi. Its only supposed to drop to 45psi after 10 minutes. Where the hell is my fuel going?! Ugh I am so ready for VEMS
Im highly suspecting the WUR committed suicide by boredom. I have a couple extras and all signs have been pointing to it, so Ill change it this weekend
Re: Taco's 4KTQ 20vt Swap: The Red Baron - DEATH TO CIS!!!
Posted: Sat Sep 21, 2013 11:52 am
Couldn't a bad FPR be the culprit too?
Posted: Sat Sep 21, 2013 12:03 pm
by AngryTaco
The WUR is a fpr. Its real name is control pressure reg
Posted: Sat Sep 21, 2013 1:33 pm
AngryTaco wrote:Ugh. Had a fight with the CIS tonight. Fired it uo after 2 weeks of sitting and it did NOT want to idle. After backing out the idle adjustment screw, it finally idled. I dont get it. 2 weeks ago it was fine. I do know there is something wrong with the fuel system. I hooked up a pressurr gauge between the WUR and the fuek distributor and measured the fuel psi after shutting the car off. It idl es at 55-60psi which is normal. Then upon shutdown it immediately drops to 15psi. Its only supposed to drop to 45psi after 10 minutes. Where the hell is my fuel going?! Ugh I am so ready for VEMS
Mr. Taco - I had a similar issue on my 87 Fox with CIS - I ended up ripping off the CIS for a 32/36 carb but I realized when I pulled the injectors off it was simply that the injectors had some crud in them (Most noticeably in the Cold Start Injector) Give those bad boys a nice brake cleaner batch and check those lines.
Posted: Sat Sep 21, 2013 5:27 pm
by AngryTaco
YeH thats a good idea. I was going to buy a harbor freight ultrasonic clearing machine and soak them in seafoam
Posted: Sat Sep 21, 2013 5:46 pm
Well, another CIS problem. Dont know about you, but I dont forsee the current fuel system keeping up the the Volvo K24. I could be wrong though.
Dont know if you noticed, but there is a set of 550cc injectors for sale in the swap meet. hint...hint...
Posted: Sat Sep 21, 2013 7:48 pm
DE80q wrote:Well, another CIS problem. Dont know about you, but I dont forsee the current fuel system keeping up the the Volvo K24. I could be wrong though.
A volvo CIS unit is very cheap as well with a one or two extra Injectors along the way:) - search alaincopter on vwvortex for some CIS inspiration.
