Page 67 of 83
Posted: Tue Jan 12, 2010 7:05 pm
by nismo
Mark, I hadn't even thought about that reading it, but I sure have seen it rust before!
Eric
Posted: Tue Jan 12, 2010 7:10 pm
by derracuda
i'll check it out after a little while to see how things look and let ya know :) if i was just going to leave it open to atmosphere, i could see it rusting rather easy (the amount of moisture taken into my old breather can setup was rediculous!), but this will be closed loop, and should be pretty much oily vapor.
Posted: Wed Jan 13, 2010 7:06 pm
by derracuda
annnddd, a little more progress today.
i needed a support for the fuel line, and a little block with a tapped hole was the solution
the trimmed fenderwell needed something on the edge of the sheetmetal, and while at the wrecking yard i found some sweet small trim from the sunroof area of a 944.
the fuel lines needed construction as well. black ano. fittings and the black braided lines are teh zechsay
also had to make up the turbo oil return line
in order to consider the manifold "finished", i had to have the mounting surfaces checked, so the i took it over the machine shop, the checked it and said... "perfect!".. wow. good welding Nubz 8) after that i just needed to do a little touch up polishing with the steel wool and then clear coat it. i like how the clear makes it a little more satin finish 8)
mmm "big turbo kit" :D
Posted: Wed Jan 13, 2010 7:35 pm
by HT Motorsport
Enough with the progress already...sheesh I am trying to take a night off here and you are making em feel bad.
And as for the sexy..thats enough of that too!!
When does that exotic woman of yours get here again. Soon I hope or you are gonna be done with this thing and that just wont do!
Posted: Wed Jan 13, 2010 7:37 pm
by derracuda
thing is, i don't feel like i'm moving fast enough :( i am going to miss my next trip to CA to go get my fiancee (K1 fiancee Visa approved btw :D) and i won't be able to touch the car for about 5 weeks. so i'm trying to cram as much as possible, plus work on regular work, and then my buddy's 4kq v8 conversion tomorrow... and tonight i'm pulling the engine and trans from a passat. ARG~!
Posted: Wed Jan 13, 2010 8:16 pm
Looks good Derek. Those flanges are thick enough in the right spots and thin enough on the weld spots to ensure a flat flange after the welding is done.
Looks freaking fast. I cant wait.
Posted: Wed Jan 13, 2010 11:06 pm
by quattro87
Is this where we discuss the fire calling the kettle black? Between the two of you I'm about ready to take up lawn bowling or maybe curling.
The car is looking fast and very well sorted. It's going to be nice!!
Posted: Wed Jan 13, 2010 11:47 pm
by RSCoupe
quattro87 wrote:Is this where we discuss the fire calling the kettle black? Between the two of you I'm about ready to take up lawn bowling or maybe curling...
I thought it was the pot calling the kettle black? :wink:
But good point, those two set bad (good) examples for everyone.
Posted: Thu Jan 14, 2010 12:00 am
by quattro87
I knew that it didn't sound right, but for the life of me couldn't come up with anything other than the general idea. :bashtard: I'm not sure which Haydn would rather be called anyway...a fire or a pot.
Posted: Fri Jan 15, 2010 1:04 am
by derracuda
nothing today :( work kicked my butt today. 8:15am-11:30 tonight. blah. yesterday i was going until 12:15, got to bed at 1.. arg! too little sleep does weird things to the body and mind.. none of them pleasant
i should have a surfaced exhaust manifold tomorrow.... maybe i get time to pull the engine and gut it before i head out of town again.
Posted: Fri Jan 15, 2010 4:44 am
by quattrostyle
how about the steering rack is it on the car yet or is it meant for another car? :wink:
Posted: Fri Jan 15, 2010 10:22 am
mmm "big turbo kit"
Derric you make me SICK! Your car is going to be such a badass. Here I am planning on just buying all of my chiz prefabbed up (IE O34) and here you are making such killer custom toys. At least you give me plunty of motovation!!! I hope I get to see this beast in person somday (maybe at the show at woodburn).
welll, i have my car to put one on, and my buddies... we'll see how things go when i get there
If you get excited an make more, I will be in the market to buy for sure!!! :-D
Posted: Fri Jan 15, 2010 10:43 am
by 90Quattro
what is this spoiler you on about??
D i love your car btw makes me sick!!
Posted: Fri Jan 15, 2010 11:12 am
by derracuda
quattrostyle wrote:how about the steering rack is it on the car yet or is it meant for another car? :wink:
over two weeks and nothing yet :(
Posted: Fri Jan 15, 2010 1:14 pm
by 84urq20v
Looks cool. Looking forward to hearing about how it drives! Keep it up-
Posted: Fri Jan 15, 2010 2:30 pm
by a_CQ
Good progress. I like your repots, always substantial and informative.
One question, that hard fuel line running below the IM runners, is it going to interfere with the water manifold and are you going to be able to access the IM lower bolts without cracking that line open and moving it?
Posted: Fri Jan 15, 2010 2:42 pm
by derracuda
the line below comes close to the water manifold. as for access to the lower IM bolts, if the IM is coming off, the fuel system is going to be opened anyhow. these types of rails don't have retainers for the injectors and they will just pop out.
Posted: Fri Jan 15, 2010 2:52 pm
by a_CQ
Got ya...
Posted: Sat Jan 16, 2010 1:56 pm
by quattrostyle
derracuda wrote:over two weeks and nothing yet :(
you mean it is not there yet? I understood you got it already...
Posted: Sat Jan 16, 2010 2:40 pm
by derracuda
unless it shows up today, i'm not aware of it arriving yet. i hope it's there though!
Posted: Tue Jan 19, 2010 12:28 pm
by my2000apb
wow derek great progress, i cant wait for this thing to fire back up!!!!1 :woowoo: :woowoo:
Posted: Tue Jan 19, 2010 7:19 pm
by ChrisAudi80
You know what's funny? The trucks here in China have Holset turbos. I cannot read what types they are.
Should I try to scrounge a couple? hehehe
Every time I see them, I have to think of Derek awesome project.
Posted: Tue Jan 19, 2010 7:24 pm
by HT Motorsport
I think Derek needs an intervention. He clearly has a 'problem' with Aluminum welding :)
Posted: Wed Jan 20, 2010 12:03 am
by derracuda
*shakes violently*... i feel empty without the TIG... invalid if you will. i might not be a super awesome TIG welder, but man, it's sooo handy to have!
Posted: Mon Feb 08, 2010 2:39 pm
... Dang Derek, I just went through you thread once again and I have to say your work me a crap ton of inspiration. So clean and I just watched you exhaust videos on youtube again... and damn. I want that sound SOOOOOO bad. I swear I make the least amount of progress out of anyone on this board. I need to kick it up a gear! :bashtard:
