finished it in matte black
suction line for the crank case breather system
nice tight fit...
still enough clearance to get access at the back of the light 8)
the downpipe also got wrapped
i bought some of HRP's "original" gold heat shielding... man, that stuff is cool! i pulled the no longer original emissions and vacuum routing stickers out from under the hood and prepped the area...
made some templates with cardstock
cut out and install
and i also wanted to do the AAN heat shield that i was planning on using. the finish on it was getting kind of tattered, so i prepped it and did the best i could. the foil is fiberglass reinforced, so it doesn't want to "stretch" much
once that was done i realized the underside of the hood hadn't been cleaned in quite a while and gave it a thorough once over, then waxed it. alllll good
the little teeny piece of heat foil was for a laugh
i think that's about it for this sunday. i'm beat from driving and pulling an engine and coming back. hopefully more this week
i need to get the flexible portion of fuel supply and feed lines figured out, work on wiring....
