reckless1
reckless1
Is it possible to control two different sets of injectors with a stand alone system? I know this would be budget limiting and sorry for the nube question but I would think you could get a second set to kick in for extra fuel and still be able to meter fuel acurately at low levels with the first set.
Toxcheap
yes as long as you have enough drivers in your ecu like a IIC can run 4 coil and 8 injectors because it has 12 drivers. the 5 cylinder is tricky you can run 5 ignition coils and your left with 7 for fuel so you could run 5 independent then put two on one driver and three on another they would be batch instead of sequential. And you have to watch the injector independence's on the drivers with multiple injectors so not to burn up a driver
fasterthenrs2
speeding-g60 wrote:reckless1 wrote:wow? I gotta start slipping into high power thinking mode one of these days I guess. Why does it have to idle so rich?just cause of the injectors?but the 1600cc injectors dont like to run under 1.7ms....
thus why i am already contemplating the ID 2200's. they have better controlability down low. its inherent in the Bosch injector that it is harder to control down low. in everything, there is give and take. so they give up some low down, but take things higher up top? make sense? this is, also, how i understand it to be. some cars are different than others, too. but idle is not a sacrifice i want to make.... thus injectors @ $235 apiece are in my sights.
the FWD VW Corrado they run, 934 WHP and 8.9X 1/4 mile, runs two rails with 1600cc injectors in each rail, on Methanol.
Im was thinking about those but 235$ a pop set me back instead went with 1600cc ones
reckless1
Huh, how would the batch injectors work out to add additional fuel at high power levels? Accurate enough?
is there pretty much a constant blue flame coming from the exhaust?
thats awesome.
thats awesome.
- speeding-g60
- speeding-g60
well, goals were all met.
show some restraint, and do not get BUCK WILD!!!!
made 615 AWHP and 439 AWTQ on low boost @ 30 psi in 3rd gear. we called it, as we had a specific set thing we were going to run tonight and we did it. funny, Kevin says on the second to last run; "we are at that point. wanna run 550 AWHP and sleep well tonight?" my reply was "lets do the 30 psi pull, and call it good."...... and >600 we went.
the last vid is my favorite.... its gonna be something else to drive i am certain. notice fireball shift? and the 4th gear cut fireballs under the car....
Link to video
Link to video
Link to video
and a pic of the last video in the dyno perspective.
Link to video
Link to video
Link to video
Link to video
Link to video
:woowoo: :woowoo: :woowoo:
Longitudinal
Alloutofdonuts
That last video made me giggle a little, even after the 8th time hah ....friggen awesome. I just need a good job now so I can buy stuff for my car! And BTW I was behind all those hate threads on Vortex...all of 'em.
LOL j/k I only use vooorhex to sell stuff, well mostly have people tell me they want something then never show up or show up without any $$ at all hahahaha
Toxcheap
fasterthenrs2 wrote:awsome dude no kabboooom finaly :woowoo: :woowoo:
BAHHAHHAHHA
Nice work man, you didn't notice but every time you brought some thing I thought, "I'm glad my car not done and I'm not dealing with that."
Well it goes both way I guess because seeing this makes me crazy and want to finish my car
Toxcheap wrote:Well it goes both way I guess because seeing this makes me crazy and want to finish my car
:slap: so do it!
my 16vT! will be done before yours!!!
and you have all the parts24v-VR6T-CQ BEAST http://www.theprojectpad.com/viewtopic.php?f=11&t=193#p37887
