Page 61 of 62
Re: 4 FOX SNAKES - Ross' 20vt 4kq
Posted: Fri May 29, 2015 9:37 am
by rossschnell
Those stock lil' 4k rotors are cute little buggers but I'm happy with 50mm more rotor and much more girth :thumbsup:
Posted: Fri May 29, 2015 9:42 am
by rossschnell
E30 M3 front caliper vs rear 4kq caliper
Posted: Fri May 29, 2015 9:47 am
by rossschnell
Conveniently, the brake lines all matched up no problem.
I also redrilled the 5x120mm BMW rotors to 5x112mm Audi. After taking 20 minutes one day to try and line up the non-hubcentric bmw rotor (bigger hub bore) and the non-hubcentric OZ's I decided I needed some centering rings for the rotors. What I REALLY need is to do wheel studs but I don't have time for that right now. I'll order some up next week.
For now, I had the local waterjet cutter make some rings for my BMW rotors. I welded them in place and whammo, hubcentric rotors!
Posted: Fri May 29, 2015 9:50 am
by rossschnell
I'm up against a deadline with track day tomorrow, but I'll eventually pull those calipers and paint them black to match the Porsche brakes up front.
Here's a pic of the finished product in the rear. Looks good and stops even better. Hells yeah.
Posted: Fri May 29, 2015 9:54 am
Looks great! I was starting to wonder what happened to this. So with useig front calipers on the rear, you have no ebrake. Are you planning to use a hydrolic ebrake?
Posted: Fri May 29, 2015 9:55 am
by rossschnell
And yes, I scored some OZ Ultraleggera's cheap. I was on the hunt for some 17" Avus wheels because I just love those things. Upon doing a bit of research I found out they're 28lbs a piece. Ouch. These OZ's are 16lbs each, winner.
Posted: Fri May 29, 2015 9:58 am
by rossschnell
Ya, I'll figure out an ebrake at some point. Probably go hydraulic but I don't know anything about it right now. Once I have time I'll start to do a bit of research on it. My E30 M3 has had ebrake delete since the day I bought it 4 yrs ago (it was a track car so P/O removed the ebrake so the pads wouldn't melt to the rotor) and its really not that big a deal. Plus now I drive around with harbor freight wheel chalks if I need something in a pinch.
Posted: Fri May 29, 2015 11:17 am
by ralleyquattro
Glad it got sorted out! Looking great!!!
Posted: Sat May 30, 2015 1:16 am
Holy crap. Race gas is nuts. There's so much fuel... I'm so glad I asked Ross to take a few logs. He probably gained 40hp just taking fuel out!
It's still rich at this point, his phone died and we only got 2 logs in. Still, much much better than before
Posted: Wed Jun 03, 2015 10:03 pm
Track day went good until the following photos happened. Ross was texting me the whole time updating me, the only hiccup being the ecu vacuum reference line popping off once. I'll admit I was pretty jealous of all the fun I never got to have. Until this happened.
Aeroquip socketless hose NEEDS clamps. I did not have them on under my ownership, but I'll never trust that stuff without clamps again. I didn't get cheap fittings or hose, it's all legit stuff. I feel pretty bad about that. Such a shitty way to kill an engine.
Posted: Wed Jun 03, 2015 10:38 pm
by Mcstiff
Fuuuuuuuuuuuuuu that! I don't know how they rate those for pressure.
Posted: Wed Jun 03, 2015 10:45 pm
Real bummer! Just curious if lube was used to assemble those? I have been running them for years but they must be assembled dry and can be a bitch to get all the way on.
Posted: Wed Jun 03, 2015 10:46 pm
by EDIGREG
that sucks. I've always been skeptical of those.
Posted: Wed Jun 03, 2015 10:55 pm
audifreakjim wrote:Real bummer! Just curious if lube was used to assemble those? I have been running them for years but they must be assembled dry and can be a bitch to get all the way on.
Yeah, assembled dry. They fit on so well and I tried pulling them off, no dice. I decided then not to put clamps on. I'm used to putting hoses on fittings (plumber) and they were definitely up there.
They're supposed to be rated for 300°F. Don't know about pressure, but man... Just shitty. It wouldn't have taken long to evacuate ~5l of oil at 60psi through a -10 hose.
Posted: Fri Jun 05, 2015 9:11 am
by rossschnell
That was the best and worst track session ever. My buddy (shifter kart champ) was driving behind me in my E30 M3 and we were having the time of our lives. I couldn't shake him, that car is so well sorted. We had a GoPro mounted on the M3 but for some reason it didn't work and shut off. That would've been so much fun to see.
So yeah, my first motor failure. Ever. I thought my right rear tire was flat because the car got a bit loose so I stopped hitting throttle almost immediately (or so it seemed??) and just coasted and pulled off the track. Then smoke everywhere. A pretty underwhelming way to blow up a motor. :bangshead: :bangshead:
So I'm in the process of getting the motor pulled for inspection.
Then the next morning this happened. The wife hit something in the TDI wagon and kept driving... Literally less than 12hrs after the Audi motor went south.
Posted: Fri Jun 05, 2015 9:46 am
Oh man, tough luck that day! Sorry to hear about that. At least you have an m3 to keep you happy! Life could be worse :)
Posted: Fri Jun 05, 2015 10:07 am
by dana
oh man, major bummer!!! I've never liked the idea of the push lok hose!
Did the TDI survive? i broke my TDI pan this year and it ran out of oil and it was totally fine. However, I shut it down the millisecond the oil buzzer went off. Those pans are horrible, so easy to hit and so damn flexible.
Posted: Fri Jun 05, 2015 10:31 am
2 for 1. Bummer on both. Losing the wife's dd is no good.
Posted: Fri Jun 05, 2015 10:44 am
Wow! 2 in less than 24hrs, bad luck.
Posted: Fri Jun 05, 2015 11:48 am
by deaner
Awe man! Talk about a rough day. Sorry to hear.
Posted: Sat Jun 06, 2015 1:35 pm
by rossschnell
New oil pan showed up yesterday afternoon for the TDI. Its fixed and the motor is all good. Finally some decent news :thumbsup:
Posted: Sat Jun 06, 2015 1:53 pm
I'm glad that was an "easy" fix. I can't imagine the AAN will be quite so lucky...
Posted: Sat Jun 06, 2015 9:28 pm
Very nice!
Posted: Sun Dec 27, 2015 11:38 am
Updates? :)
Posted: Mon Dec 28, 2015 4:07 pm
by rossschnell
Not a whole lot to report just yet. I sourced a low mileage donor block from Mcstiff (thx Ed!) for the rebuild. I placed a big order in mid-november for all the engine components, which I'm still waiting on...... I should have everything I need parts-wise once that box of shiny parts shows up from Iroz.
