Re: Taco's 4KTQ 20vt Swap: The Red Baron - Running Strong
Post by AngryTaco »
I'm getting compressor STALL Dan. I think you are thinking of the surge when the throttle plate shuts and the BOV/BPS is non-existant or fails to operate causing a massive spike in pressure in the intake. The sound that diesel turbos make is what it sounds like when you get off the throttle. Its the turbo spooling down due to the unequal pressures in front and behind the compressor. BAD
Stall is where the turbo is being overspun past it's capabilities and can't flow what the engine is demanding
40v4kq
Post by 40v4kq »
AngryTaco wrote: I'm getting insane surge that bounces between 13-16psi.
I must have read that wrong. Clearly it says "stall", not "surge". LOL
Dan
1984 Ur quattro
1987.5 Coupe GT Special Build
My k24 had no issues at 25psi and my k26 has none either...
Yeah... something is wrong here. I've never heard of or experienced any surging of any sort under load with a k24/k26, etc. Maybe its different on a 20v.
loxxrider wrote:Yeah... something is wrong here. I've never heard of or experienced any surging of any sort under load with a k24/k26, etc. Maybe its different on a 20v.
a surging k24 lmao
yeah somethign is wrong
Post by AngryTaco »
pilihp2 wrote:My k24 had no issues at 25psi and my k26 has none either...
Were you running a ginormous cam and ported head?
It may not be compressor stall but it sure feels like it and the boost gauge supports it with the fluctuation. Maybe its the wastegate going all funky? Or the WGFV?
Dave even said he was getting this kind of stall/surging with this K24/Cam/Head setup
I'm running a 20v head. Which I'd imagine flows more.
I ran my old 20v at about 20psi with a stock mc1 cam and didnt have the issue. Does it still happen without the cam?
Post by AngryTaco »
I never had an issue with the MC2 cam running 15psi. But the head wasnt as heavily ported as it is now when I was running it. I did a massive port job on the exhaust manifold too as shown in previous postings
40v4kq
Post by 40v4kq »
Very interesting. Try this if you have the time....swap back to the mc2 camshaft and see if the surge/stall goes away. Maybe "The Cam" is just too radical for a quick spooling turbo? Even if you lose top end power it would be nice to be able to just mash the go pedal into the carpet relentlessly without fear :)
Dan
1984 Ur quattro
i find it hard to believe a ported 20v head with stock valves is going to outflow a 20v head or cause any surge issue
Post by AngryTaco »
I have 34mm exhaust valves if it matters. All valves have had a valve job too
Post by AngryTaco »
TO DO List for today:
wire up CSV and wire in a push button switch for manual activation on WOT
Redrill and tap fuel pump to accept bosch check valve
Tune fuel dizzy
Change oil
Don't blow it up or die
AngryTaco wrote:Don't blow it up or die
:thumbsup: :thumbsup: :thumbsup:
Post by AngryTaco »
Trying to get my hands on a URq A/C setup. Dont need condensor or evaporator. Gotta survive the drive to BBQ somehow
Summer Wish List:
A/C setup and working
VEMS
Daves Volvo K24
URq front HD bilsteins
Level Car out (raise rear)
Buy a Diesel VW caddy or late 70s Ramcharger lol
Go to BBQ?? :)
Post by AngryTaco »
For sure. Ill be ready this year. You better be too. No more excuses like "I dont have an ECM, my car wont run without one", etc etc :)
AngryTaco wrote:For sure. Ill be ready this year. You better be too. No more excuses like "I dont have an ECM, my car wont run without one", etc etc :)
Well, don't go and blow yours up. :P BTW, we should discuss a caravan. :)
Post by AngryTaco »
Agreed. We need to discuss routes too on where were all going to meet up
Post by AngryTaco »
Ok update. Im still getting boost cut at 15psi. Gonna pick up a cheap inline reg from harbor freight or whatever and put it inline with the ecm and set it ir 14.9999 psi lol. All I have to say at this point is holy torque batman. At 14.9 psi the power is insane. 4th gear pulls like a bat outa hell. The torque really starts kicking in at 3600 and pulls all the way through 6700 where I am forced to shift :(
Post by AudiSport4000 »
Curious as to how much further past 15psi you want to venture. What "tuning" have you done to the fuel dizzy? What chip/wg spring are you using?
Post by AngryTaco »
I was thinking 17 total. Its a non-production Ben Swann 2.0+ superchip with a 1.8BAR spring and adjustable mod.
Im getting the holy grail of chips this week too. A MAC11c with a Natrix chip
scubadave
Post by scubadave »
Turbo wont help with the overboost issues. Like I said before, you need a standalone. The problem is with the stock computer and its inabillity to regulate above a certain level. With the standalone you will be able to go to 25-26ish psi. Thats where it gets fun.
Post by AngryTaco »
I agree dave. Thats why I was going to install an inline reg as a temporary solution to overcome the 15psi limit. Hang in there! School is out in about a month and I go back to 50-60 hour work weeks. And since my truck is now paid off and I have my car for driving, I should be able to grab that from you in no time. Unless I find a smokin deal on a 74-80 Ramcharger :). TWIN TURBO 505 CI stroker with NAWWWWZZZZ!!!! :rofl:
scubadave
Post by scubadave »
:roll: ......kids....... :we:
Finish it.
*facepalm*
