Page 54 of 82
Posted: Wed Dec 04, 2013 12:35 pm
by WOMBAT
Ditto - I like the durable setup you're shooting for and am excited to see what your tuning powers can do
Posted: Wed Dec 04, 2013 12:53 pm
by amd is the best
Dutchbroracer wrote:
I like where this is going...Sounds like a sweet idea. I assume the motor will be pulled and at least rods will be done?
You know how I roll. This will be installed on the stock block...only temporarily and only low boost. I will be assembling my spare block in the meantime.
WOMBAT wrote:Ditto - I like the durable setup you're shooting for and am excited to see what your tuning powers can do
We'll see
Posted: Wed Dec 04, 2013 1:20 pm
by amd is the best
Manifold came today:
Better pics when I'm out of work. I had the girlfriend take some pics for me while she was there. And her subsequent Instagram post:
Posted: Wed Dec 04, 2013 6:01 pm
that last bit in the subject from her is a bit depressing haha - Nice piece
Posted: Wed Dec 04, 2013 6:08 pm
by Dutchbroracer
Build the wagon for her lol
Posted: Wed Dec 04, 2013 6:31 pm
by amd is the best
Dutchbroracer wrote:Build the wagon for her lol
She HATES the Avant, lol. She will gladly take the Golf.
themagellan wrote:that last bit in the subject from her is a bit depressing haha - Nice piece
lol. thanks man!
Posted: Wed Dec 04, 2013 11:36 pm
lol hashtags! Love it.
Posted: Thu Dec 05, 2013 9:57 am
by Justin517
amd is the best wrote:Dutchbroracer wrote:Build the wagon for her lol
lol. thanks man!
Lol, my fiance hated my '89 20v with no headliner and rediculously loud exhaust, she was OK with the wagon when I bought it, but now I think she actually prefers riding in the wagon over my 540i... which is on fairly stiff coils and has tints and black headliner/interior (it can feel a little claustrophobic, I like it, lol), plus I tend to be a bit more smooth with the clutch in the 200 (probably still more used to audi clutch than BMW clutch).
Posted: Thu Dec 05, 2013 3:36 pm
by amd is the best
Got the 3076 off and am working on removing the exhaust manifold. This is a first for me... Most of the nuts came off without an issue, three studs came out in good shape and one stud was broken. Now one nut/stud remains and for those of you who have removed the stock manifold probably know exactly which one is still on there. Ok enough suspense, the one right below the turbo flange! WTF...of course that one stripped because I couldn't get a socket on it.
What is the best plan of attack here? I removed the engine mount arm to make some more room but have no idea how I'm going to get at this thing. Calling it quits for today.
Posted: Fri Dec 06, 2013 8:33 am
by WOMBAT
Posted: Fri Dec 06, 2013 9:27 am
by 20VAvant
Have you looked into nut splitters? Its a carbide chisel attached to a nut that you tighten and will spit the nut. That would hopefully allow for you to remove the manifold and get at the stud.
I had this happen on the water manifold on the head. I eventually had to just use drills and slowly remove the material.
Posted: Fri Dec 06, 2013 9:53 am
by vt10vt
So excited for this next phase nick!
Those copper nuts are fairly soft, if you can get an angle might be able to hammer a smaller english socket onto it. if not I'm with the above, angle grinder or sawzall the nut off and throw a pipe wrench on te remaining stud when the mani is outta the way.
Posted: Fri Dec 06, 2013 1:42 pm
by Mcstiff
How stripped?
Posted: Fri Dec 06, 2013 1:48 pm
by amd is the best
Mcstiff wrote:How stripped?
a 12mm box wrench will not grab it at all. 11mm won't go on to it. It's in the most terrible location too, hard to get anything in there.
I'm probably going to cut it off with a small dremel cut wheel.
Posted: Fri Dec 06, 2013 2:05 pm
by amd is the best
Also just ordered two of these guys:
I'm planning on building a "double-pumper" as the EVO guys would call it. Look for updates coming soon
Posted: Fri Dec 06, 2013 4:34 pm
by Mcstiff
amd is the best wrote:Mcstiff wrote:How stripped?
How about jamming a 7/16ths or 15/32nds on?
Posted: Fri Dec 06, 2013 4:47 pm
by amd is the best
Mcstiff wrote:amd is the best wrote:Mcstiff wrote:How stripped?
I could try that though I have very few SAE tools, lol. I'll swing by my fathers shop and see what I can come up with.
Side note, anyone know the stock fuel line size? Is it 3/8's?
Posted: Fri Dec 06, 2013 7:11 pm
pretty damn sure it's 3/8th's I know I said this but I literally went through the same thing with a bolt in an equally hard place (Lower mounting bolt on g28/g4 bracket) I bought a mini dremel and used these sanding barrels. The cutting wheel is fine but the barrel eats way more material and you just need to hold it in one place and it will work its way down to where the head and bolt threads meet. The only annoying thing was the battery died pretty quick.... I probably would have used a plug in version had there been an outlet within 3000ft of my car.
Hope to have some more bathroom time reading from your thread soon
Posted: Sun Dec 08, 2013 7:55 am
by dana
i use an air hammer applied tangentially to the stripped nut to get it spinning. Works about 75% of the time in this situation. Its a bit of a challenge because its hard to finesse the air hammer. Might be worth a shot.
Posted: Mon Dec 09, 2013 2:56 pm
by Justin517
amd is the best wrote:Also just ordered two of these guys:
lol... double pumper...
Posted: Thu Dec 12, 2013 9:04 am
by amd is the best
Well, finally pulled the trigger on a bottom end through Hank. I will no longer be able to brag about my stock this and stock that, lol.
DM I-Beams
Wiesco 92mm 9.5:1 pistons w/rings
Calico coated main/rod bearings
An Iroz downpipe for my SQ manifold
Tial MVR gate and adapter kit (from stock WG flange)
The head stuff will come in phase two later this winter. It will consist of:
Ferrea +.5 valves
Ferrea springs/retainers/locators/etc
New seals
Cat Cams
Then fuel (FML)
Some 2000+CC (ID/FIC/FID/etc)
Some dual pump setup
Chipping away at it
So, some pics:
Finally got the stock exhaust manifold off (though now it doesn't matter too much as I am building my spare block anyway). Here's what I had to deal with:
Test fitting the Wagner:
And with my buddy's ancient looking GT35R:
More to come.
Posted: Thu Dec 12, 2013 11:57 am
by Justin517
NICE!... but thats um... close!.
Posted: Thu Dec 12, 2013 1:02 pm
by EDIGREG
niceee
Posted: Thu Dec 12, 2013 1:35 pm
by Mcstiff
Mo Powah!.
Posted: Thu Dec 12, 2013 2:01 pm
by 20VAvant
amd is the best wrote:Well, finally pulled the trigger on a bottom end through Hank. I will no longer be able to brag about my stock this and stock that, lol.
DM I-Beams
Ferrea +.5 valves
New seals
Cat Cams
Then fuel (FML)
Chipping away at it
So, some pics:
Dammit...
You were the last one here that didn't make me feel that I HAD to upgrade everything.
Excited to see what kind of numbers you get from this set-up.
