Marc's 95 S6 Avant (daily driver)
GTIVR62801 wrote:Ouch Marc, that sucks. At least its not all that hard to do. Going to throw some ARP studs in there while you're at it right?
yep, browsing summitracing.com right now. Gotta love ground shipping showing up in 2 days anyway.
nerdhotrod@epl
Post by nerdhotrod@epl »
a4kquattro wrote:
nerdhotrod@epl wrote:Yikes...
I'll have it buttoned up for the 29th, no problem.
Stock (paper) headgasket, stock head bolts... it was time.
It had a good run 200k .... :-)
3B'dB3
Post by 3B'dB3 »
that stinks,
oh well, time to upgrade! 8)
I'm just glad I pulled the plugs before trying to start it after I replaced the heater core. that coulda gotten ugly in a hurry.
Toxcheap
Post by Toxcheap »
WOW sad to see that!! sorry man, glad you found that after I left I wouldn't have been able to bare your expression :(
I though S6's had metal headgaskets???? :? :?
Toxcheap wrote:WOW sad to see that!! sorry man, glad you found that after I left I wouldn't have been able to bare your expression :(
there were more than a few explitives muttered...
the replacement parts are spec'd as metal, but I know of at least one other 95.5 that I know for sure had a paper HG in place.
HT Motorsport
Post by HT Motorsport »
Arse!!!!!!
Sorry about that Mark, LMK if I can do anythign to help....
H
SilverCQ
Post by SilverCQ »
damn, that sucks marc. guess its time to get the v8TTCq finished up ;-)
wish i was closer, i'd come give ya a hand.
quattrofrog
Post by quattrofrog »
oh crap... thats never any good.
Wizard-of-OD
Post by Wizard-of-OD »
a4kquattro wrote:that coulda gotten ugly in a hurry.
Couldve easily bent that rod :o
Audilard
Post by Audilard »
Glad you caught that! One big repair job after another. :(
Darin
1989 80 20vt
JShadzi
Post by JShadzi »
Parts on the way :D
Toxcheap
Post by Toxcheap »
JShadzi wrote:Parts on the way :D
Marc did you go 2-day?
:thanks:
lots of goodies on the way, got around to pulling the head tonight. Just as I suspected, blown gasket at #4 into the water jacket:
On the positive side of things, the head looks undamaged so I should be able to get away with just having the head decked and be good to go.
#4 got a free steam cleaning ;)
while I was in there I discovered a couple of interesting things.. When I went to take off the downpipe I noticed a little motion between the turbo and EM..
missing bottom inside stud...
and as a result the gasket gave up the ghost
wonder if it was like that on the dyno?
Glad to hear it's ok, is that rusty manifold coming off while you're at it :-)
audifreakjim wrote:Glad to hear it's ok, is that rusty manifold coming off while you're at it :-)
why yes, yes it is ;)
:-D
birdmanmt
Post by birdmanmt »
So are you going with the CR dropping HG, or the standard one? Nice dyno numbers!! How much timing are you seeing at the torque peak?
birdmanmt wrote:So are you going with the CR dropping HG, or the standard one?
slight CR reduction, going for around 8.8:1
Nice dyno numbers!!
Will be interesting to see if the power changes after the head work, compression drop, and EM change with no changes to the tuning....
about 10-11 degrees.
w00t, 034 parts are here
:thanks: :thanks:
Head is off at the machine shop for resurfacing, new guides, and a 5 angle seat grind.
cars in a few pieces at the moment..
and just for fun, a nice "while I'm in there" project :-D
Wizard-of-OD
are you welding a V-band to that KKK hot side?
SilverCQ
Post by SilverCQ »
SWEET :thumbsup:
Toxcheap
Post by Toxcheap »
You better be ready for monday mofo!
Toxcheap
Post by Toxcheap »
Wizard-of-OD wrote:are you welding a V-band to that KKK hot side?
:stupid: :wtf:
