i just have one small set of numbers to throw at you, for some AWIC tech info.
i ran yesterday, and i looked at the IATs and boost, etc. figured you might want to have a looksee at the temps and such.
here is what i got for IAT and boost.
this is starting temp in F, low point, end point, and boost, for each gear. 9.41 @ 167.31 mph.
just ice and water in a reservoir, no external heat exchanger. Rule 1100 bilge pump, 1100 GPH. 3" piping throughout.
1st - 68 down to 65.6 up to 66.2 with peak 29.73 psi / 305 kpa
2nd - 66.2 down to 63.5 up to 68 with peak 42 psi / 389.8 kpa
3rd - 68 down to 65.6 up to 73.58 with peak 46.7 psi / 422.2 kpa
4th - 73.58 down to 72.5 up to 78.7 with peak 46.47 psi / 420.4 kpa
thats all
just some data on AWIC.
