Page 48 of 84
Re: Ben's Oceanic H1C/K26 AAN 4kq - trans blew -Pics
Posted: Wed Apr 03, 2013 4:32 pm
by pilihp2
AngryTaco wrote:Quit being a little pansy and throw an auto in there!! Never break shit again!! Or miss a shift!!! And never have to put down your coffee to shift!!! DEATH TO MANUALS!!!
That is quite literally the worst thing i've ever read.
You. Stop it.
Just stop it.
Lol audi automatic...
Posted: Wed Apr 03, 2013 5:03 pm
You. Stop it.
Just stop it.
Don't give him too hard of a time Phil, he's from Idaho. :P
Posted: Wed Apr 03, 2013 5:12 pm
by 40v4kq
Wow ben, your tranny really let go in spectacular fassion. Hope you get it back together soon.
Posted: Wed Apr 03, 2013 5:32 pm
40v4kq wrote:Wow ben, your tranny really let go in spectacular fassion. Hope you get it back together soon.
Ya it was fun. :P I hope to be on the road before graduation. Fingers are crossed.
Posted: Thu Apr 04, 2013 12:36 am
by 40v4kq
Do you have all the parts you need? I know you had a big list of stuff you needed a while back.
Posted: Thu Apr 04, 2013 1:09 am
40v4kq wrote:Do you have all the parts you need? I know you had a big list of stuff you needed a while back.
Starting from scratch for the swap. I'm currently working on getting a trans and all the parts I need though.
Posted: Sat Apr 06, 2013 9:58 pm
So as everyone already probably knows, I'm going 01E. Today I pulled the trans and had a chance to really inspect the damage....
Yup...
SO added to my list of things to do is repair the trans tunnel and clean up the oily underside. Everything is soaked. I gotta say, I already miss this thing, I can't wait to get it back up on the road!!!
Re: Ben's Oceanic H1C/K26 AAN 4kq - trans blew - 01E time
Posted: Sat Apr 06, 2013 11:00 pm
by JT4k
Damn Ben when you go you go BIG!!!! Sorry for the setback but you have a great plan going. I love this car!!!!
Posted: Sat Apr 06, 2013 11:27 pm
JT4k wrote:Damn Ben when you go you go BIG!!!! Sorry for the setback but you have a great plan going. I love this car!!!!
Thanks man! Ya, it's a setback but I knew it was going to happen at some point. It's just an excuse to build it even more. ALSO this way I won't have to worry so much about running the 5857. :)
Posted: Sun Apr 07, 2013 6:54 am
So like... should I just expect my trans to blow up with the billet 30r? What if I don't launch it? It would not fly with the wife if it blew and I had to spend pretty much any money on a swap. although putting another 016 in would be a few hours and quite cheap. Maybe I should start searching for a spare 016 now...
Posted: Sun Apr 07, 2013 8:38 am
by pilihp2
Short answer? Yes it will blow up. It'll last longer if you don't launch it. That's for sure. Nick beat the Hell out of his 016 and he never blew it up though. So. Hit or miss maybe?
Posted: Sun Apr 07, 2013 9:07 am
Here are a couple things about mine, I launched maybe 6 times, I was boosting whenever I could and as far as I know this trans had over 300k on it. SO More than likely with all that, it just was not up to the task. PLUS I do believe my engine was making some pretty stellar torque after 3k rpms.
Posted: Sun Apr 07, 2013 1:17 pm
So hit or miss - last through hell or blow up at 15psi. Lol, awesome.
Iirc, mine was pretty nice and smooth last I recalled... launch control was never setup but it lived for who knows how long with an mc1 swap before the AAN. No idea on abuse levels. Guess I'll start hunting for a cheap/free replacement. Once hank has a kit price for 01e swap stuff together I'll consider that as well
Posted: Sun Apr 07, 2013 1:45 pm
chaloux wrote:So hit or miss - last through hell or blow up at 15psi. Lol, awesome.
Having a backup is not a bad idea. :)
SO I have just decided while I have this all apart, I'm going to (at the very least) install some front coil-overs. I have had it with all the fender rubbing, and until I can afford to wide body it I need to raise this front end up. SO I guess my question is, what springs should I pick up for the front and the rear end? How many pounds? Just so it's out there, I am running Bilstein HD rears and Koni internally adjustable fronts.
Re: Ben's Oceanic H1C/K26 AAN 4kq - 01E time - Coilovers -
Posted: Sun Apr 07, 2013 1:53 pm
I'm not sure what shocks my car is running, might be stock but I'll have to check Mike's thread on mg. Anyway my car's got 350lb all around and it's pretty stiff. A bit harsh for the family but fine for me to rip around in.
Posted: Sun Apr 07, 2013 2:02 pm
Found it, bilstein HDs.
Posted: Sun Apr 07, 2013 2:07 pm
chaloux wrote:I'm not sure what shocks my car is running, might be stock but I'll have to check Mike's thread on mg. Anyway my car's got 350lb all around and it's pretty stiff. A bit harsh for the family but fine for me to rip around in.
I would REALLY like to keep it comfortable and use a good swaybar setup for corning duty. Do you think 325 would be soft enough to keep the ride nice?
Posted: Sun Apr 07, 2013 2:59 pm
When I push down on my fenders nothing happens. 325 or even 300 would probably be better. Maybe 300 front, 325 rear.
Posted: Sun Apr 07, 2013 11:55 pm
by 40v4kq
Ben, I have 400lb springs all around and eventually i think im going to step up the front to 450 and the rear to 500. I say if you can just get away with just adding the weld on perches, the threaded collars and adjuster rings from ground control i could just sell you my 400 lb springs when i switch em for the stiffer ones. By doing that you would have the ability to raise up your front end for the time being, and you can come drive my car and see how you like the 400's. I have externally adjustable konis and when they are turned to a softer setting the car rides suprisingly soft and smooth, then just turn em up to "race" for hitting some corners. I gaurantee that with 300 or 325 lb springs if you ever go to a track or do autox you will wish you had stiffer springs. For reference, Marshalls ABZ race 4kq had 500 lb springs in the front and something crazy like 675 in the rear.
Forgot to say something... Just order the kit from ground control sans springs. You will need to tell them you have billsteins rear and konis front because i think the top hats are different.
Posted: Mon Apr 08, 2013 1:21 am
Just out or curiosity, what's your car weigh in at with the 40v?
Posted: Mon Apr 08, 2013 2:25 am
by 40v4kq
Im not sure what the actual weight is, but i do know its not much more than a 20vt epuipped 4kq.
Posted: Mon Apr 08, 2013 9:13 am
40v4kq wrote:Im not sure what the actual weight is, but i do know its not much more than a 20vt epuipped 4kq.
Ok, thanks Dan! I will definitely keep your advice in mind!
Posted: Mon Apr 08, 2013 1:53 pm
by pilihp2
Ben or Dan if either of you are interested in some 6" 450LB springs I'm looking to get some 7" springs. At my current setup the front has to be ALL the way up in order to clear the fender during daily duties.
Posted: Mon Apr 08, 2013 2:05 pm
pilihp2 wrote:Ben or Dan if either of you are interested in some 6" 450LB springs I'm looking to get some 7" springs. At my current setup the front has to be ALL the way up in order to clear the fender during daily duties.
What do they ride like? I imagine 450 is pretty rough isn't it?
Posted: Mon Apr 08, 2013 2:09 pm
by pilihp2
450 in the front 550 in the rear. It's kinda rough, but I also can blame that partially on the bilsteins being blown and HD's instead of sports.
I need Konis.....
