Page 5 of 6
Re: Nick's AAN into 4000Q thread. set backs.....set backs...
Posted: Thu Aug 02, 2012 3:53 pm
by TheArchitect
Rallyfreak202 wrote:Just asked The Architect what he thinks. We'll see.
Responded.
Posted: Thu Aug 02, 2012 7:21 pm
by TheArchitect
Curious, if you go back to one of my last attempts to help on this, I answered that you want a multi-windowed distributor.
You never specified one way or the other.
Are you running a 1 window distributor as a trigger?
Posted: Thu Aug 02, 2012 8:07 pm
by Rallyfreak202
I decided to post the PM here because The Architect put together a great diagnosis for weak spark for 1B users. I think we might have found my problem. I stuck a 1-window distributor in it while diagnosing why I was not getting enough spark.
I'm going to get a working multi-window distributor and try that out. Fingers crossed it was a failed distributor that caused the problem in the first place. If my good distributor turns out to not solve the problem, I'll continue answering the questions below.
Thanks Architect!
TheArchitect wrote:OK I cross referenced your build thread and the previous messages you have sent me.
Let me tell you what I think you have and you can comment.
I take it that the 1B ECU has its ignition 1 driver, driving a normal inductive coil and you are connected to a 5 window distributor (the 5 window item is critical).
Can you crank the engine and read RPM with the laptop software?
You say spark is weak, how do you know this and are you sure you have spark at all?
Is the ECU configured (built) for driving a normal 2 terminal coil (some units are built for a 3/4 terminal POS coil).
If you are sure the spark is weak, have you tried bumping the dwell time?
What is you dwell time and dwell degrees?
Any possibility you timing is way off?
Reading some of your thread was confusing WRT the 034 ECU, you mention removing a MAF line and the effecting the ECU running, whats this about?
Is there another "stock" ECU connected and partially in control of the engine?
Re: Nick's AAN into 4000Q thread. Long-term project.
Posted: Fri Aug 03, 2012 8:35 am
by savagerocco
Rallyfreak202 wrote:glibobbo21 wrote:AAN pan wont work
Thanks.
We have the AAN pan in out 4k turbo car. It works
Posted: Fri Aug 03, 2012 9:45 am
by my2000apb
savagerocco wrote:Rallyfreak202 wrote:glibobbo21 wrote:AAN pan wont work
Thanks.
the aan pan only fits if the rad is angled, there isnt a relief like 3b/7a for the side radiator
nick, pm me an address and ill get the dizzy out tomorrow am
Posted: Mon Aug 06, 2012 12:05 pm
by my2000apb
wrenching restarts, weds 10 am!
fedex express dizzy en route
Posted: Mon Aug 06, 2012 5:33 pm
by ShadyUrS4
my2000apb wrote:wrenching restarts, weds 10 am!
When you gonna be back in sylva? We should hang. Im back in sylva now!
Posted: Tue Aug 07, 2012 10:35 am
by my2000apb
ShadyUrS4 wrote:my2000apb wrote:wrenching restarts, weds 10 am!
huh? who are you
Posted: Tue Aug 07, 2012 10:52 am
by ShadyUrS4
my2000apb wrote:ShadyUrS4 wrote:my2000apb wrote:wrenching restarts, weds 10 am!
huh? who are you
Sorry seems my phone got the wrong quote XP thats one of the things i hate about my smart phone. Im a friend of Nick's
Posted: Tue Aug 07, 2012 11:08 am
by my2000apb
ah ok hahaa im in NH so i wont be there wrenching laterr, he prob will be
Posted: Thu Oct 18, 2012 8:40 am
by Rallyfreak202
I'm back home for a couple days. Been working on the GTi a bunch because it is my dd'er and needs attention. I pulled (err..pushed) the Audi into the garage. I'm going to test the Hall sender the way my Bentley manual says. Is this ok? I am using 034 IC for fuel and spark. Here is how I'd do it:
-Remove Hall sender connector, put voltmeter + on terminal 4 and - on terminal 12. Verify I have power with ignition on. I should see 5v right?
-If yes, do next step
-Plug Hall sender in, slide up boot, put negative probe into middle terminal and positive probe to + battery. Crank engine and watch for fluctuating voltage.
FYI here are my hall sender pin outs. They are wired per the 034 diagram. pin 4=5v. pin 11=hall trigger. pin 12= neg shielded.
If I do these tests, this will show if I have a bad hall sender right?
Posted: Thu Oct 18, 2012 7:26 pm
by savagerocco
my2000apb wrote:savagerocco wrote:Rallyfreak202 wrote:[quote="glibobbo21"]AAN pan wont work
Thanks.
nick, pm me an address and ill get the dizzy out tomorrow am[/quote]
The radiator in our 4k isn't angled it is mounted as factory and clears the oil pan no problem
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
Posted: Sat Oct 20, 2012 2:35 pm
by Rallyfreak202
Hall sender=good. Check out the video.
Posted: Sat Nov 24, 2012 2:55 pm
by Rallyfreak202
Home on Thanksgiving break. I coasted the 4000 in the garage.
-still no start. At best it stumbles.
-still weak (orange spark) with spark plug to ground
-orange/blue spark from coil to ground while cranking
-coil is getting 20v WHILE cranking
-All chassis and engine grounds checked over and sanded.
-Put new negative battery ground on
-same cap and rotor that the engine fired up with in May
-only 2 wires on my coil; ground trigger and positive 12v.
Why am I getting orange spark? Orange is too weak to start the car, correct? Anyone have any suggestions? I am having communication problems with my 034 IB controller which is my fault I believe. The tach signal touched the negative side of the coil and since then, communication has not very intermittent. Going to send the controller off soon to be inspected!
Posted: Tue Dec 11, 2012 4:03 pm
by my2000apb
Posted: Tue Dec 11, 2012 5:43 pm
2nd
Posted: Tue Dec 18, 2012 7:19 pm
by Rallyfreak202
my2000apb wrote:...
Sent the controller to 034, everything checked out fine. Still bad spark. I have no idea why. :frustrated:
Posted: Tue Dec 18, 2012 10:41 pm
by pilihp2
When I couldn't get my car to start due to ignition issues it I solved it by going to new coils, wires, and plugs.
Not sure how much that'll help. But are you sure your coil is good?
Posted: Wed Dec 19, 2012 3:17 am
by ShadyUrS4
pilihp2 wrote:When I couldn't get my car to start due to ignition issues it I solved it by going to new coils, wires, and plugs.
Im with philihp2 I'd check that next. Id love to come help ya nick but isnt the car back at your parents?
Posted: Wed Dec 19, 2012 8:32 pm
by Rallyfreak202
ShadyUrS4 wrote:pilihp2 wrote:When I couldn't get my car to start due to ignition issues it I solved it by going to new coils, wires, and plugs.
Lane: Yeah, the car is in VA with me. The car is timed correctly. Spoke with your Dad about it. Thanks!
Pilihp2 I am sure my coil is good. I just took it off my GTi that runs well and put it on the Audi. I have not changed my plugs. My ignition wires ohm out ok. I'll check them again.
Going to install new plugs/ohm plug wires and report back. I doubt it is those but I'll test anything at this point!!
Posted: Thu Dec 20, 2012 7:22 pm
This MAY have already been discussed, but are you 100% your getting fuel? If your getting spark and timing are correct, that pretty much leaves some kind of fuel issue. Just my 2 cents.
Re: Nick's AAN into 4000Q thread. Stuck.
Posted: Thu Dec 27, 2012 11:06 am
by Rallyfreak202
Almost sold it today. I can't figure out why the f*ck I'm not getting good spark.
extreme90path wrote:This MAY have already been discussed, but are you 100% your getting fuel? If your getting spark and timing are correct, that pretty much leaves some kind of fuel issue. Just my 2 cents.
Yep, I'm getting fuel. The problem is spark. It weak and infrequent.
Posted: Thu Dec 27, 2012 12:25 pm
Is your coil good? Try swapping it with another? Are you getting a full 12-14v @ the coil?
Posted: Thu Dec 27, 2012 1:31 pm
by Rallyfreak202
extreme90path wrote:Is your coil good? Try swapping it with another? Are you getting a full 12-14v @ the coil?
Coil is good and I'm getting 20v while cranking at the coil. I can take the dizzy out of the engine, turn it by hand and hear sparking at all 5 contact points of the rotor. But when it cranks, it doesn't fire frequently enough or bright enough.
:frustrated:
Posted: Thu Dec 27, 2012 4:02 pm
Try a hotter plug? Also, check timing? Honestly, if your getting some spark and fuel you should be able to get it to fire over at least.
