Page 5 of 9
Re: roortube's UrS6 Avant...billet 35r ish driving impressio
Posted: Mon May 13, 2013 2:30 pm
I hate to be the bearer of bad news Ed, but that turbo will not spool at 3850 rpm on Marc's dyno, or on any other dyno I have ever been on. The dyno plot I posted above and the log I show was taken on the asme day/tune on a Mustang Dyno with 15 second sweeps on the pull through 4th gear. That should emulate a street pull, but it doesn't. I'd be prepared for a graph similar to mine above, as we are sharing 95% of the same components, with the last 5% being very similar mods.
I just went through the same headache with my billet k26s. Dyno says 4000 spool, people freak and want refunds, and then the car gets on the road and is actually spooling closer to 3500 on the street via log and actual life. If you go by the boost chart on the dyno, it is a different story.
Posted: Mon May 13, 2013 2:41 pm
by EDIGREG
I know it's not going to show the same spool as the street... my point for making the comparison was only to show that it should be significantly earlier
Posted: Mon May 13, 2013 3:03 pm
by Marc
Hank is 100% right on the dyno showing a bit later spool than "real life". I can confirm, Rob's RPM calibration on the dyno is right on the money, I checked it three times at varying rpms. If I slow down the pull the spool times do improve. this dyno plot was a 10 second 3rd gear. running a 20 second pull shows rpm about 400rpm earlier. if I do a steady state hold I'll get 27psi on this turbo around 5400. still late, IMO (for whatever reason, again, my guess is related to cam timing, Rob claims its bang on but I'd like to see perhaps 1 tooth advanced and 1 tooth retarded to see the effect while I have my logging hooked up. I'll be able to tell if its making more power just from what load numbers he hits.
Posted: Mon May 13, 2013 3:05 pm
by Marc
loxxrider wrote:Ah, that shows how out of touch I am with this project. I gotta get used to the idea of these cars getting motronic tunes now! See you at Carlisle
yeah, pretty cool you'll be there again this year. see you there!
Posted: Mon May 13, 2013 3:48 pm
Rob, are you on a adjustable cam gear and on 7a cams?
Posted: Mon May 13, 2013 4:20 pm
Haha, didn't mean to be dramatic. It actually spools similarly to dad's without the qsv which is 64/82mm (can't forget stroker effect). But when we had his cam a tooth out and fixed it we saw 1k spool improvement.
Posted: Mon May 13, 2013 4:23 pm
Rob, how are you checking top to bottom end top dead zero? I assume the cam marks are lined up? How much did the head and block get decked on the engine building?
Posted: Mon May 13, 2013 4:30 pm
Rob, get a qsv
You need more suggestions to fix. Lol.
Seriously though when I think about it qsvs are freaking awesome. 3071 spool on a 35+r sized turbo.
Posted: Mon May 13, 2013 6:25 pm
by roortube
I've verified belt timing both by marks on the Pulleys and with an extension on the top of piston 1 while watching for the cam mark. I haven't pulled the valve cover to verify relative cam timing, but got a new gasket and will do that on my next day off. The car uses both 7A cams and stock cam gear.
The block and head were only decked a couple thou, just enough for fresh surfaces on each.
Posted: Mon May 13, 2013 6:41 pm
Since I don't drink, maybe i'll be the designated timing checker at Carlisle?
Posted: Mon May 13, 2013 7:27 pm
by roortube
Hey...whachoo sayin? We MAY have consumed some beer while putting this thing together...I would love for you to verify though, just in case my eyes were crossed or something.
In all seriousness, I'm either gonna check finite if bed time goes according to plan, or Wednesday after work.
Posted: Mon May 13, 2013 7:47 pm
hehe, I was just sayin i'd be the designated double checker
Posted: Mon May 13, 2013 8:03 pm
by Mcstiff
roortube wrote:I've verified belt timing both by marks on the Pulleys and with an extension on the top of piston 1 while watching for the cam mark. I haven't pulled the valve cover to verify relative cam timing, but got a new gasket and will do that on my next day off. The car uses both 7A cams and stock cam gear.
Flywheel mark?
Posted: Thu May 16, 2013 2:23 am
by roortube
Sean and I installed my Innovate LC1 tonite (thanks bud). It would have gone much faster than it did, but when I removed it from my old S4 I basically grabbed the wires and yanked them free from the car. This meant that we had to rewire the whole thing before installing. Now that it's in and I can actually see what's going on with AFR I feel much more comfortable. Warm up idle fluctuates between 14-16:1, warm idle is 14.2-14.8:1, cruise is about the same. There's a brief lean point of 16:1 on throttle tip in that's quickly recovered, then as boost reaches a few psi it richens up nicely to about 12:1. Full boost is a bit rich in the area of 10.7-11:1.
We ran out of steam around 2:45am and called it a night before pulling the valve cover to verify cam chain timing. I have off tomorrow, and if I finish my house/yard work in time I'll check it. If not, it's gonna have to wait till Friday when I get to Carlisle. I'm beat, so off to bed.
Posted: Mon May 20, 2013 6:34 am
by drwho
Rob, hank, marc, myself and a couple others verified cam chain and belt timing. next we need to check the flywheel for proper pin placement. Great show thanks again guys
Posted: Mon May 20, 2013 6:35 am
by drwho
Just the billet flywheel has no reference mark for top dead so May be pulling a flywheel out.
not a Murcie, but not bad
Posted: Tue Jun 04, 2013 9:48 pm
by roortube
I had the chance on Sat to run a friends dad down a stretch of Mexican highway. He was driving a Ferrari 360 convertible that he just traded up to from a C5 'Vette convertible. We were hanging out at a baby shower grilling while the ladies were down stairs being girly. One of the other guys there was a local Sheriff who had driven his 2013 Boxster. Those two started bench racing, and I offered to run spot while they had it out. I hadn't told them what was going on under hood. We got out to a long open stretch of hwy and lined up 3 abreast at 70mph all in 3rd. The Porsche had been chosen to honk it out. On the 3rd honk we all gunned it. They both got the initial lead...then boost hit. A solid pull through 3red had me at 110 where they had agreed to shut down just ahead of the Ferrari and quite a bit in front of the Porsche. They were both very confused. We did it 2x more with the same result. When we got back to the house they had to see what lay under hood, and although neither were turbo guys they could appreciate the work done. Beers on them that night! No vids unfortunately as this was totally off the cuff, but I'll try to arrange it again if I can.
Posted: Tue Jun 04, 2013 9:52 pm
lol that's awesome, you sly bastard!
Posted: Tue Jun 04, 2013 9:57 pm
I love it!
Posted: Tue Jun 04, 2013 10:28 pm
That is so awesome. I have underestimated the awesomeness of this car because there aren't any pics or vids
Posted: Wed Jun 05, 2013 8:31 am
by EDIGREG
nice!! lol their faces had to be priceless
make any progress on the late spool issue?
Posted: Wed Jun 05, 2013 10:44 am
by vt10vt
That's awesome Rob! A 360 is a pretty badass kill. Once my car is back up and running we gotta make a trip to 75/80 some weekend you're free.
Posted: Wed Jun 05, 2013 5:54 pm
by roortube
It was awesome, and yes, the look on their faces was priceless. No progress on late spool yet...its grads cutting season and my yard is 5 acres of nasty hills that I cut with an 18" push mower. Takes all of my car time just keeping up with that. I need a rainy day off work and I'll try retarding the can timing a tooth to see what that does. If it makes a significant improvement I'll have to get back north to EFIx for a retune.
Posted: Wed Jun 05, 2013 7:37 pm
Hmm. Too much grass bro, hehe.
Marc guaranteed already knows this but fattening up the fuel curve can help spool.
Posted: Sun Dec 15, 2013 7:13 pm
by roortube
Today I retarded cam timing by a tooth to see what effect that had on spool...it was huge. Hit full boost almost 2000 rpm sooner. The car was turd slow though and felt like it was pulling timing. Any body have thoughts? I may head up to see Marc for a retune but its a haul and time is short now. I don't wanna go if there's not a really good chance that things will improve significantly.
