Sooooo I was getting bored while working on my 200's rear suspension brakes and this happened.....
Do not know if anyone has done this before but you can use 034's adapters
http://store.034motorsport.com/caliper- ... grade.html" onclick="window.open(this.href);return false; made for b5 s4 (also allroad/c5 s6/c5 4.2) calipers and b7 s4 300MM brake rotors on your 200 20v (i'd assume 200 20v) too. So if anyone else knew about this cool, but as far I know I have not seen a single rear brake upgrade. I was pretty excited when the adapters bolted up.
You need to trim the rear spindle to allow the lower adapter bolt to be threaded in but nothing major (around 1/4 inch).
Also it looks like you can utilize the stock e-brake cable. I ordered new ones I will hook up when they come in.
