Andy's 91' 80q
mrdeye
Re: Andy's 91' 80q
Post by mrdeye »
Mr.
Previous cars:
Re: Andy's 91' 80q
rennenmsports
Re: Andy's 91' 80q
Post by rennenmsports »
rennenmsports
Re: Andy's 91' 80q
rennenmsports
Re: Andy's 91' 80q
rennenmsports
Re: Andy's 91' 80q
rennenmsports
Re: Andy's 91' 80q
rennenmsports
Re: Andy's 91' 80q
rennenmsports
Re: Andy's 91' 80q
I’ve got 3/4” clearance from the drive axle boot. Heat wrap and a custom heat shield
rennenmsports
Re: Andy's 91' 80q
Let’s see if 16ga 304ss amazon stuff holds up for the flex pipe back
rennenmsports
Re: Andy's 91' 80q
rennenmsports
Re: Andy's 91' 80q
Got the downpipes all welded up. Had to take a little off the subframe pinch weld. Doing the heat shields and secondary support bracket now
rennenmsports
Re: Andy's 91' 80q
1.9 bar / 13.5 psi or 2.2 bar / 17.5 psi?
That is the question
If I was to guess the intake hose at the throttle body popping off is its weakest link.
Bonding silicone to aluminum:
Permabond
Polyolefin primer
Permabond cyanoacrylate 105
rennenmsports
Re: Andy's 91' 80q
rennenmsports
Re: Andy's 91' 80q
:bangshead: there’s only 3 cat back exhaust mounting points
I’m gonna have to fix that. There’s not much room with a 3” pipe in a 2” ditch. I’m debating about just bolting the flex pipe back straight to the car with rubber isolators
dspl1236
Re: Andy's 91' 80q
Post by dspl1236 »
I bypassed going up and around the diff on mine. It is now the first thing that hits anything. I plan on redoing mine to snake around. Your image looks like what I had I mind. 45deg over the CV. I kinda gave up fitting it correctly. Even the same box of amazon pipe but in 2.5 :D Hanger situation sucks. My rear oem muffler broke at the welds, so it was my quick fix. :bangshead:
:hide: I am not happy with my setup.
'13 A6 3.2T + '90 Jetta - 2.0T 20v + '92 Corrado SLC + '90 90q 2.6 i5 20v + '90 GTI Plum 3.6 VR6 + '89 200 20vt + '01 A8 +'09 Passat Wagoon 07k
