So, back in April 2021, I was in on a group buy for some aftermarket windshields that were to be imported from Europe (Finland if I remember correctly). About a year later, they showed up in the states and were being stored in Asheville, NC. Since it was proving impossible to find someone that would ship a windshield, my wife and drove out to pick it up and made a road trip out of it. That was in June 2022. And after sitting in the shop for 2 years, the windshield has been mounted to the car!
When I posted to some of the Facebook groups, there were several questions about how it went and how some of the trim pieces come off. So, here's a little rundown.
- For starters, the old windshield in my car was not the original OEM windshield. So, it's possible that you could come across something different that I did.
- The installer said the windshield is entirely glued in and the glue is the seal.
- Upper/Lower Trim - The upper and lower trim pieces were hard plastic and glued to the windshield. Both were destroyed in the removal process. I don't think there is any way to avoid it. The installer had various rolls of trim on his rig and he picked the best one to fit the glass. The replacement is actually rubber and it looks like it will do a better job of keeping water out of the channel between the glass and the front edge of the roofline.
- Side Trim Removal - The side trims consist of the painted metal piece that is on the exterior of the A pillar and a rubber strip that is glued to it that sits between the metal and the glass. Some might call the rubber piece a seal, but I think it just acts as a buffer between the metal and glass while also channeling water downward. In my opinion, it's not the primary seal for water ingress into the cabin.
- How they are mounted - The side trim is riveted to the car and there are clips holding onto a channel from underneath.
- Removal - You have to remove the door seal in the area of the A pillar. With it removed, the black plastic/rubber window trim will be exposed. This window trim is riveted to the car and there are holes in it that allow access to the painted side trim. The side trim is also riveted to the car. We were a little usure on how everything came apart, so we first removed some of the rivets on the black plastic trim so that it would separate from the body on the A pillar. However, it may be possible to remove the side trims by only removing the rivets that hold it on. Once the side trim rivets are drilled out, don't just start pulling and prying on the side trim. The side trim has to slide downward a few inches to align the notches in the channel with the clips that are mounted to the body. Once they are aligned, the side trim will come off easily.
- Glass Removal - The installer used a knife of some sort that has a 90 degree bend in it. It has to be run between the glass and body around the perimeter to cut the old glue. Lots of glass crunching in this step...no turning back now for sure!
- Clean Up - They scraped all of the old glue off and cleaned up the body so the new glue would have a clean surface. Luckily, we didn't run into any rust, but he did lay down a coat of sealer that has a rust converter in it.
- Glass Install - The upper rubber trim was glued to the glass prior to installation. They laid down a healthy bead of the black glue/sealer to the body and set the glass in place.
- Side Trim Install - Reverse of the removal steps with new rivets. I used 5/32" rivets.
- Miscellaneous - Immediately after the installer had set the new glass in place, we noticed there was no window for the VIN to show through. It's not like I could do anything about it (like return it for a new one). So, if/when the VIN is needed to be viewed by someone, hopefully the ones on the firewall or door jam will suffice.
Here are some pictures...
This shows the clips on the A pillar that hold the side trim. One of the clips fell out and was re-installed with a new rivet. This was before the cleaned up the old glue.
Side trims, showing the channel on the bottom side...notice the notches
Close up of the side trim showing how the rubber is oriented
New glass goin on
New glass in place
Close up of the new upper rubber trim
