Fingers crossed. Will report back…just need some shop time.DE80q wrote:Nice to see someone took the plunge and ordered a set. I look forward to hearing what you think of them.
Thanks! They are 17's. 17x7 et 42 with 15mm spacers.benznotmercedes wrote:Looks so mean at that height. I forget, are those 17s or 18s?
Thanks. WIll definitely check on that.ringbearer wrote:Looks great, congrats!
Make sure you are returning the master/booster all the way to the internal stop.
Is the best way to adjust for that to shorten the overall length between the brake pedal and the servo?ringbearer wrote:You are welcome.
The piston at the stop uncovers a hole that lets the brake fluid flow back into the master cylinder as it heats up and expands.
When I removed the clevis pin, I could tell the master cylinder was pushing a little on the rod. So, I shortened the rod by 3 full turns of the clevis. The brake pedal now has a very slight amount of play between where the MC is at rest and the brake light and cruise control switches. And it gets taken up by the return spring. I went for a lengthy drive on a warm day and the brakes never did lock up. Hoping this is a good sign.ringbearer wrote:Yes, that’s a good adjustment location. You will want to confirm the setup between the servo and master is the correct length if this doesn’t work.
So nothing documented on my end but the compressor is slightly different for the manual AC. Compressor clutch is different I believe since it doesn’t have the can-bus output. You’ll need to wire in control relays for the fan and compressor clutch. Control relays should be triggered on/off by the switch but also by high pressure cutout and low pressure cutout switches should trigger the system to off. High/low pressure cutouts should also be auto reset style. I don’t know part numbers but I do have some manual AC bits and pieces depending on what you need.jbrentd wrote:Was able to get out in the shop last weekend to adjust the ride height on the BC coilovers. Not quite as easy of a task as the more traditional style coilovers, but not hard at all, especially with the QuickJack there to help. Just had to loosen the top nut and lower strut body ring, then rotate the strut body by the desired amount. Now to get her in for an alignment.
Next thing on my list is to get the AC working. I hope to drive the coupe a lot this Summer and working AC would be really nice. Has anyone ever documented the wiring side of a manual airbox swap with working AC? I can't seem to find much info on this, so I am taking a stab at it.
Swapping the manual airbox and control panel is fairly straightforward, once you have the dash all torn apart. It's the wiring that I am looking at currently. The blower motor controls are plug and play, but AC controls...not so much. I don't think it'll be a ton of work, but just wanted to know if there any good resources out there already.
I appreciate the reply and I agree with what you are saying, but I do not see why I can't utilize the existing AC, low speed fan, HP and LP relays...if I tie things in at the correct places. Unless I am missing something?? I don't claim to be an expert in this area, by any means.JH87 wrote:So nothing documented on my end but the compressor is slightly different for the manual AC. Compressor clutch is different I believe since it doesn’t have the can-bus output. You’ll need to wire in control relays for the fan and compressor clutch. Control relays should be triggered on/off by the switch but also by high pressure cutout and low pressure cutout switches should trigger the system to off. High/low pressure cutouts should also be auto reset style. I don’t know part numbers but I do have some manual AC bits and pieces depending on what you need.
I guess I assumed you didn’t have any of the AC parts but if you have the switches and relays you should be good there. Still not quite sure if pump is cross compatible. Hopefully someone has done the swap before and can chime in. I think the can-bus terminal on the ac pump is pwm for idle control but that shouldn’t matter if you have vems and use one of the spare inputs and program an idle map switch.jbrentd wrote:I appreciate the reply and I agree with what you are saying, but I do not see why I can't utilize the existing AC, low speed fan, HP and LP relays...if I tie things in at the correct places. Unless I am missing something?? I don't claim to be an expert in this area, by any means.JH87 wrote:So nothing documented on my end but the compressor is slightly different for the manual AC. Compressor clutch is different I believe since it doesn’t have the can-bus output. You’ll need to wire in control relays for the fan and compressor clutch. Control relays should be triggered on/off by the switch but also by high pressure cutout and low pressure cutout switches should trigger the system to off. High/low pressure cutouts should also be auto reset style. I don’t know part numbers but I do have some manual AC bits and pieces depending on what you need.
Here's what I have found so far for where I should tie in the wires on the AC/Recirc switch on the from of the manual control panel. Most of them can go to the plug for the old auto CC programmer.
- #3 is 12v coming into the switch from programmer plug #4 (comes from Fuse S17)
- #1 is 12v going to programmer plug #5 (trigger to the AC relay) and programmer plug #3 (trigger to the fan low speed relay)
Yeah, everything else is still there from the old AC wiring harness. My compressor only has a single wire going to it to trigger the clutch. And I already tied in the compressor status and idle speed increase signal into my 3B ECU harness, when I did the wiring for the engine swap. Hoping it will work properly, but I should be able to tweak it if needed.JH87 wrote:I guess I assumed you didn’t have any of the AC parts but if you have the switches and relays you should be good there. Still not quite sure if pump is cross compatible. Hopefully someone has done the swap before and can chime in. I think the can-bus terminal on the ac pump is pwm for idle control but that shouldn’t matter if you have vems and use one of the spare inputs and program an idle map switch.
Do you have the manual box and controls? if not, I can send you mine, I’d just have you cover shipping. I only kept it in case I couldn’t get the auto stuff to work.jbrentd wrote:Yeah, everything else is still there from the old AC wiring harness. My compressor only has a single wire going to it to trigger the clutch. And I already tied in the compressor status and idle speed increase signal into my 3B ECU harness, when I did the wiring for the engine swap. Hoping it will work properly, but I should be able to tweak it if needed.JH87 wrote:I guess I assumed you didn’t have any of the AC parts but if you have the switches and relays you should be good there. Still not quite sure if pump is cross compatible. Hopefully someone has done the swap before and can chime in. I think the can-bus terminal on the ac pump is pwm for idle control but that shouldn’t matter if you have vems and use one of the spare inputs and program an idle map switch.
I have one that came with the manual airbox. It seems to be working fine, as I can control all of the flaps and the fan speed, currently. I wouldn't mind to have a spare though. I'll send you a PM.JH87 wrote:Do you have the manual box and controls? if not, I can send you mine, I’d just have you cover shipping. I only kept it in case I couldn’t get the auto stuff to work.
Sounds good!!jbrentd wrote:I have one that came with the manual airbox. It seems to be working fine, as I can control all of the flaps and the fan speed, currently. I wouldn't mind to have a spare though. I'll send you a PM.JH87 wrote:Do you have the manual box and controls? if not, I can send you mine, I’d just have you cover shipping. I only kept it in case I couldn’t get the auto stuff to work.
