07K Exocet
carwerks101
07K Exocet
hello all, i am not sure how busy this site is, but i wanted somewhere i could post this and get actual good feedback from people who have done projects. My build is a Exocet and im running a T5 transmission with a RWDmotorsports bellhousing, will be turbo running on stock ecu with a flash tune, most likely dialed down because the car only weighs 1500lbs and will be running 91 octane, currently i am in the proccess of waiting on some parts so that i can throw the transmission in the car, the intake manifold is an IE manifold that i cut and flipped, also using a ECS S4 flywheel for the bigger disc diameter with a RS4 pressure plate here are some pictures
- 40485989_243413636367646_6398200553500566264_n(1).jpg (152.82 KiB) Viewed 31273 times
Last edited by carwerks101 on Fri Jul 12, 2019 12:09 pm, edited 10 times in total.
- themagellan
Re: 07K Exocet
Cool.
There are a lot of members here that run the 07K - This is a good thread : http://theprojectpad.com/viewtopic.php? ... ead#unread
Search some of their threads - or maybe they'll post here.
Hope to see videos
and goodluck.
Hope to see videos
Re: 07K Exocet
Welcome! People around here are always up for another 07k Project, excited to see this come together, I auto-x with a couple guys who run Exocets, all of which are Miata powered, so cool to see something a bit different
Re: 07K Exocet
Damn, this is going to be cool.
Look forward to updates!
Re: 07K Exocet
Nice oil pan solution, cool project
Re: 07K Exocet
This will be interesting!
Re: 07K Exocet
I saw 07K Exocet and thought: this is going to be good. Welcome.
carwerks101
Re: 07K Exocet
just got my throw out bearing spacer. it was too big and the hydraluic throw out bearing was bottoming out before the bell housing could mate to the engine
carwerks101
Re: 07K Exocet
got the radiator mounted, turbo manifold is welded up, also got an alternator and going to start plumbing the oil cooler and radiator hoses
carwerks101
carwerks101
- themagellan
Re: 07K Exocet
looking awesome! so many goodies on that chassis
should be insanely fast!
