so my car sorta looks like.....a car now.
that spray foam stuff is genius to mount the bumper skin....its a shame i sprayed a bit too much of it though and the bumper literally bulged a bit in a few places. anyways, i designed it this way so that i can still bolt the bumper off of the main bar running across the front of the car relatively easily.
as far as the bumper lining up with the wheel wells...i think i did the best i could for a replica bumper...i just need to drill some holes in it and mount it to the fenders.
also got the hood pin setup done. and boy was that not the funnest thing ive done in a while. whomever has the nutsack to do this on a limited edition carbon fiber hood....is off their farking rocker. (aaron)
as it sits now i have about seven inches from the block to the bar across the front of the car. i still need to get the timing belt stuffs on the motor, and i need to fit a radiator with fans in there too....so i may chop the bar running from side to side and move it foward as much as i can and still fit the intercooler between the bumper supports.
