I ordered the parts specifically. And like I said I kinda had to redo everything and I ended up getting rid of that spherical bearing and the cup I welded in place.pilihp2 wrote:Did you happen to have the parts lying around or did you order them specifically?
But total for the parts that would make it right are the cost of the 3/8" bolt, nut and washer, the cost of a high misalignment rod end from McMaster Carr, part number 6960T1 and a 3/8" ID 1/2" OD sleeve which came to like $30.
I'll try and grab some pictures of how I did everything, not that it's rocket science.. But a picture is worth 1000 words sometimes.
