Bill's 200 20v for sale
Re: Bill's 200 20v, ign tuning help needed
audios wrote:Thanks Sean, I appreciate the input and I'm probably a bit nervous since I really don't want to blow it up after all the hard work
Totally understand! If you're worried you could pull a degree or two from the whole map (except at idle) but honestly I bet it'll run just fine as is.
Good luck and keep the updates coming, good to see this car continuing to get the love it deserves :D
audios
Post by audios »
It's alive, I think there's a problem with the lifters somewhere. The head seems very loud
https://youtu.be/vNT8wVPXM7Y
audios wrote:It's alive, I think there's a problem with the lifters somewhere. The head seems very loud
That’s normal, it’s because they are not full of oil yet. They will quite down over time. Usually after some decent revs.
I am assuming you have good oil pressure. Above 3 bar when hot?
Yup - as long as there's good oil pressure, I wouldn't worry about that too much just yet.
audios
Post by audios »
Yea, it got quieter today when started, but the PS pump was leaking pretty bad still. I switched the high pressure ports over to copper washers this winter but it still leaks bad. Looks like it will be coming back out. Glad I got the 5l jug of 11s.
audios
Post by audios »
The serial to USB cable is way to short so i purchased a 5 ft well reviewed USb extension and finally was able to get the VEMS file off of the car. I have only ever used megasquirt in the past, VEMS seems to be great.
Here is the log file, i still need to learn a bit more about it.
origLCRsetup.vemscfg
OriginalTune
(12.97 KiB) Downloaded 2278 times
audios
Post by audios »
update time, today i put the car back on the ground. It is running, not leaking oil or coolant and hopefully no 'green gold' I had replaced 2 of the 8 washers with copper this past winter as it had developed a leak in the rebuilt pump and i had read that the copper washers were the best long term solution as the rubber ones always leak.....i should have replaced all of them as i had to take it back out and do the other six due to it still leaking. I ran it a bit tonite and it seems to have stopped, but only time will tell.... here are some photos of it w/o a bumper to go for a short ride up and down the street tomorrow just to make sure everything is good before i button everything up...... there are some log in problems on tapatalk but once i get on i will put up the photos
5.16.18 018.JPG (1.69 MiB) Viewed 60364 times
5.16.18 017.JPG (1.51 MiB) Viewed 60364 times
audios
Re: Bill's 200 20v, back on 4 wheels
Post by audios »
so after multiple coolant leaks to repair the car is finally running good, tuning will be next on that front. I did a oil change, its been probably 20min of run time, here is the magnetic drain plug. im glad i got it...
5.19.18 010.JPG (1.54 MiB) Viewed 60295 times
Tonight i tried to get the bumper back on, it is going to be a challenge. the metal brace for the IC didnt lign up that well when i put it back on this winter, it seemed to warp a bit, but it bolted on. Today the bumper shocks wont even fit into the holes, i had to use a ratchet strap to pull them in and then give it a good shove to get it started.
5.19.18 011.JPG (1.82 MiB) Viewed 60295 times
none of the bolts lign up well enough to bolt up and it seems to be shifted pretty far to the drivers side..
5.19.18 012.JPG (1.83 MiB) Viewed 60295 times
5.19.18 013.JPG (1.11 MiB) Viewed 60295 times
audios
Post by audios »
Well it is back on the road, had to open up a lot of holes to get bumper on but it is on
audios
Re: Bill's 200 20v,on the road again
Post by audios »
ok, been a while so another update:
car is running good, although it wasnt at first. as it turns out cyl #3's injector was not firing. when i pulled the plugs in an attempt to read them the #3 still looked brand new while the others looked normal. Tested for spark and it was a go, pulled the injector plug and the inner purpley thing that holds the wire pig tales apart was broken apart. There was another unused plug i noticed when i pulled the motor that i tracked down and removed to harvest the broken part from. it was difficult to remove the wires from the piece but they came out with minimal damage to the part it needed. Here is a photo of the doner plug with the broken piece from the injector plug.
6.8.18 028.JPG (1.63 MiB) Viewed 59895 times
now the car is running much better now that is on all 5 again :) pulls pretty well although i am not getting on it much as the bottom end is still in 'break in' mode.i changed the oil after the first 5 min or so of run time then again tonite after about 80 miles or so. All in all im glad to have it back on the road again, although it may be going up for sale soon as i need a new roof on my house, and the audi is the first on the list of things to be liquidated, id really rather not sell as soon as it is back on the road but time will tell.....
6.8.18 025.JPG (3.62 MiB) Viewed 59894 times
Good job & Congrats
audios
Post by audios »
Well I'll be taking it to get inspected soon, rear bushings and no alignment equal bald inner tires. Enter the tires/rims that came with my euro van. Really doesn't look as good with them but it is inspectable Image
audios
Post by audios »
Inspected
dana
Post by dana »
hows she running?
audios
Post by audios »
dana wrote:hows she running?
pretty well, had some oil leaking from near alternator, but seems to be better after tightening up the turbo return line. The pressure sender is still leaking but that will have to wait till next oil change. Overall runs great, still on break in for another few hundred miles then will try to tune it/ get on it a bit more.... :)
audios
Post by audios »
still tracking down this small oil leak. Trying to get a photo of it. Originally thought it was from the catch can return line which could be a small part, but every time I checked I see oil near where the head meets the block and there is oil in the bracket for the alternator. This is the photo Image
You can see the flat surface with the small Mark is the block, this is where the oil usually collects. And you can see the bracket for the alternator with the oil puddle. No oil in the coolant, only seems to be seeping slowly from there.....
audios
Post by audios »
Double post
Hey Bill, get a UV dye kit to help diagnose where it is coming from. My bet is the valve cover gasket. Give it a good clean, then add the dye and keep an eye on it.
inline560
Post by inline560 »
Sell me this allready!
inline560
Post by inline560 »
Car*
inline560
Post by inline560 »
Pm'ed you!
audios
Post by audios »
Been enjoying the car lately ImageImage
audios
Post by audios »
audios
Post by audios »
Well, a lot has changed in my life since i was blessed with this 200 20v, now that i am a father to 4 kids and own a house that needs a roof i was thinking if i would be able to keep the 200. I did not want to let it go. I prayed about it, then Paul called me (inline560) and wanted to fly out from texas and get it..... well i guess that is the answer to my prayer, not exactly the answer i was looking for but if it is God's will then I will pass it on....
Paul didnt want the S4 seats so tonite i took them out and put the stock comfort seats back in....I will definitely miss this car...
no front seats
no front seats
8.27.18 003.JPG (1.47 MiB) Viewed 57632 times
WOMBAT
Post by WOMBAT »
Well shoot, I’m sorry to hear it’s on its way out but happy to hear it’s headed to another enthusiast!
This just popped up - 6 years ago, it was logging its first miles! Miss this thing..
