'84 Audi Coupe Gt grp2
In the last month or 2 I purchased a used mig welder. Installed 220v outlet in the garage, been practicing my welding and accumulating tools for the rollcage build. I went to school for arc welding many moons ago. Looking forward to getting back into it!! Before tearing into it I'ld like to get out to the track one more time. I also got the accelerator pedal poly bushing so it should be good for the rest of its life.
Slow and steady wins the race.
More info and pics: http://theprojectpad.com/viewtopic.php? ... ead#unread
Pics:
Pics:
- Thick to thin
- IMG_4161.JPG (1.5 MiB) Viewed 125176 times
- Practicing thick to thin.
- IMG_4159.JPG (1.78 MiB) Viewed 125176 times
- Renting a cylinder of argon/co2
- IMG_4168.JPG (2.18 MiB) Viewed 125176 times
- Started with flux core
- IMG_4167.JPG (1.21 MiB) Viewed 125176 times
- IMG_4166.JPG (1.72 MiB) Viewed 125176 times
Mr.
Previous cars:
Previous cars:
Re: '84 Audi Coupe Gt grp 2
Burned through on some other pieces but getting it dialed in!
- Back side thick to thin
- IMG_4162.JPG (1.69 MiB) Viewed 125175 times
Mr.
Previous cars:
Previous cars:
I have been eyeing up these 2 tube benders. I've read reviews on the speedway motors bender and some say the bottle jack leaks after a number of bends, tube kinks while bending 1 3/4 tube and the dies crack. Other people say it works great! Has anyone had any experience with them? I have had experience with the JD Squared type benders. Your positive feed back is appreciated, thanks!
https://www.affordablebender.com/collec ... n-7-radius
http://www.speedwaymotors.com/3rd-Gen-H ... ,6614.html
Mr.
Previous cars:
Previous cars:
I read your thread on the other page!! Man that hurts my eyes (the page not your car), so please migrate this to the "Darkside" so I can save myself the anguish. I thought I was building a underdog for a car but yours has to frustrating to get parts for.
As far as welding goes looking at your ripple patterns, seems to me that you are whipping and not carrying the arc in a smooth manner. Since you stated that you stick welded many moons ago and you are teaching yourself a new process I can see you falling in that trap. Try just establishing the arc and than carry it in a smooth fashion Push Drag or go Parallel, depends on you preference and settings on your welding machine. Distance to work piece makes a huge diff. and should be held at the same distance for the length of the weld. Also when doing any type of innershield wire (flux core) reverse the polarity and that stuff lays down like its going to sleep. Your welds look good for someone who has not done this before. I have seen ALOT worse from people that are "certified".....
As for sheet metal, well lets just say I am in the same boat than you.
Now get that thread moved and more pics. of car please.
Mike
In my experience if you don't favor the thicker material you will burn through the thinner material. I'm practicing for the welding of roll cage base plates.
When I was flux core welding I didn't read up on the correct procedure and I had splatter all over the place!!! Switched ground and gun leads so my work piece was hot and the splatter calmed down a little.
What's wrong with the other thread? Are you the "build thread" police? Do I have bad build thread etiquette? I moved over because I was tired of all the spam and adds. They have seemed to fix that problem over there. Still a good site.
Mr.
Previous cars:
Previous cars:
Marc (curator of the project pad) has a way to migrate your entire build thread over so that it brings all existing posts, pictures, etc. here so that you don't lose anything. I think that's what he's sayingAudinut1984 wrote:What's wrong with the other thread? Are you the "build thread" police? Do I have bad build thread etiquette? I moved over because I was tired of all the spam and adds. They have seemed to fix that problem over there. Still a good site.
Love the project, seems like there's a lot of neat FWD track projects cropping up recently!
Ok, thanks! I pm'ed Marc.
Mr.
Previous cars:
Previous cars:
Wow, I like this thread
vt10vt wrote:Marc (curator of the project pad) has a way to migrate your entire build thread over so that it brings all existing posts, pictures, etc. here so that you don't lose anything. I think that's what he's saying
Sorry did not mean to offend in any shape or form.
Mike
None taken. Now come out from under that chair!Einbilden wrote:vt10vt wrote:Marc (curator of the project pad) has a way to migrate your entire build thread over so that it brings all existing posts, pictures, etc. here so that you don't lose anything. I think that's what he's saying![]()
Thanks!Foscora wrote:Wow, I like this thread
Mr.
Previous cars:
Previous cars:
Track day!! Tested out the tow rig as well.
- IMG_4817.JPG (3.76 MiB) Viewed 123748 times
Mr.
Previous cars:
Previous cars:
Mr.
Previous cars:
Previous cars:
Mr.
Previous cars:
Previous cars:
I was running on snow tires (crappy tires) so I got passed a lot. But I did pass a corvette, a turbo Supra and a gazelle!
Mr.
Previous cars:
Previous cars:
Hopefully the car will look similar to this some day.
- IMG_4938.JPG (74.01 KiB) Viewed 123508 times
- IMG_4240.JPG (140.03 KiB) Viewed 123516 times
- IMG_4865.JPG (46.54 KiB) Viewed 123516 times
- IMG_4867.JPG (45 KiB) Viewed 123545 times
Mr.
Previous cars:
Previous cars:
The old head quarters of LRG Racing and future driver
- IMG_4863.JPG (113.85 KiB) Viewed 123516 times
- IMG_4862.JPG (190.03 KiB) Viewed 123516 times
Mr.
Previous cars:
Previous cars:
Tear down begins.
- IMG_4864.JPG (206.45 KiB) Viewed 123514 times
- IMG_4858.JPG (185.34 KiB) Viewed 123514 times
- IMG_4853.JPG (199.17 KiB) Viewed 123514 times
- IMG_4852.JPG (146.92 KiB) Viewed 123514 times
Mr.
Previous cars:
Previous cars:
Engine assembly
- IMG_4850.JPG (132.36 KiB) Viewed 123511 times
- IMG_4851.JPG (107 KiB) Viewed 123511 times
Mr.
Previous cars:
Previous cars:
Head bolted on.
- IMG_4917.JPG (169.17 KiB) Viewed 123510 times
Mr.
Previous cars:
Previous cars:
Tranny to block.
- IMG_4918.JPG (164.72 KiB) Viewed 123509 times
- IMG_4920.JPG (192.74 KiB) Viewed 123509 times
- IMG_4919.JPG (173.41 KiB) Viewed 123509 times
Mr.
Previous cars:
Previous cars:
Engine going back in.
- IMG_4923.JPG (199.57 KiB) Viewed 123526 times
- IMG_4922.JPG (159.4 KiB) Viewed 123526 times
- IMG_4921.JPG (132.82 KiB) Viewed 123526 times
- IMG_4841.JPG (120.69 KiB) Viewed 123526 times
- IMG_4839.JPG (144.68 KiB) Viewed 123526 times
Mr.
Previous cars:
Previous cars:
Oil pan sorted.
- IMG_4925.JPG (158.3 KiB) Viewed 123525 times
- IMG_4926.JPG (200.03 KiB) Viewed 123525 times
- IMG_4924.JPG (175.26 KiB) Viewed 123525 times
Mr.
Previous cars:
Previous cars:
Oil cooler was hungry and thirsty!
- IMG_4928.JPG (176.3 KiB) Viewed 123524 times
- IMG_4929.JPG (176.39 KiB) Viewed 123524 times
- IMG_4930.JPG (204.19 KiB) Viewed 123524 times
- IMG_4931.JPG (189.46 KiB) Viewed 123524 times
- IMG_4932.JPG (149.02 KiB) Viewed 123524 times
Mr.
Previous cars:
Previous cars:
At the exhaust shop.
- IMG_4933.JPG (165.48 KiB) Viewed 123523 times
- IMG_4934.JPG (142.77 KiB) Viewed 123523 times
- IMG_4935.JPG (177.36 KiB) Viewed 123523 times
- IMG_4936.JPG (179.99 KiB) Viewed 123523 times
Mr.
Previous cars:
Previous cars:
My old Avant.
- IMG_4937.JPG (275.08 KiB) Viewed 123522 times
Mr.
Previous cars:
Previous cars:
