Anybody see this from running E85?
type85
Post by type85 »
I get a frothy yellow goo, it looks like it eventually settles back down to oil (the goo is pre filter, the top of the separator is the intake).
What you see is from idling the engine and going on short drives, oil may have not reached operating temp.
I also often see a surprising amount of water in the separator, I wonder if E85 produces more water than gasoline
The Mann provent oil separator is working well, I have it under hi vacuum, feeding the intake manifold directly, I'm hoping keeping the crankcase under vacuum will make the rings seal better!
SEStone
Re: Anybody see this from running E85?
Post by SEStone »
That's common to see in a catch can, it's what you get when a lot of moisture mixes with a little oil vapor. The moisture is normal crankcase vapors.
Sam
Sam Stone
type85
Post by type85 »
SEStone wrote:That's common to see in a catch can, it's what you get when a lot of moisture mixes with a little oil vapor. The moisture is normal crankcase vapors.
Sam
Why yellow? looks like barf!!!
yep. thats not e85 doing that.
type85
Post by type85 »
Marc wrote:yep. thats not e85 doing that.
What's causing the yellow color?
the oil and water mixing. Put some oil and water in a blender if you want to reproduce it :)
type85
Post by type85 »
audifreakjim wrote:the oil and water mixing. Put some oil and water in a blender if you want to reproduce it :)
It's the color of yer car big fella!!!
Post by ChrisAudi80 »
If any discoloration from E85 it would be dark purple. Just look at your injectors in the runners.
