Justin (bangetek) 1996 UrS6
popdemonic
Re: Justin (bangetek) 1996 UrS6 - dead cyl3
Post by popdemonic »
Sorry for the TJ Justin and Matt. :hammer: :hammer:
JustinB_20vt
Post by JustinB_20vt »
Whelp the engine is back in my garage after a visit to FRP (Jeff Gerner) for a rebuild which included new pistons and another head. Need to order some harware before i put it back in
Justin aka banget3k
That's a good feeling for sure!
Out of curiosity, what was the turnaround time from Jeff?
Very nice, get it in and enjoy it!
JustinB_20vt
PRY4SNO wrote:That's a good feeling for sure!
It was a few months but i had told Jeff that there is not a big hurry... FWIW most of the time was spent waiting on pistons and other parts
Justin aka banget3k
That's all understandable, and still a deadly turnaround time.
Did he provide any photos of the build along the way?
JustinB_20vt
Yup plenty. here are just a few
Justin aka banget3k
JustinB_20vt
Whohoo it starts and sounds great :drive: !! And as a bonus i got my B8 back from the body shop today after someone drove into me in a parking lot :wah: :nuts:
Justin aka banget3k
2.5TYPE44
Post by 2.5TYPE44 »
Looking good. I like the stance and wheels. Can't beat the customer service from Jeff. :thumbsup:
JustinB_20vt
Whelp the after the freshly rebuilt engine got broke in and i started turning up the boost E85 here in arizona changed to e55 ethanol so i pulled timing/boost and fuel for a get around town tune and basically stopped driving the car. fast forward a few months and i took the time to relay the fuel pump using a relay bracket from a C5. Unfortunately the random smoking on startup has now become an every start thing and i am thinking valve seals or rings... leaning towards rings as i am dumping mass amounts of oil into my catch can and getting less power from the same boost and fuel :) FML.. ordering a leak down tester to see what i will need to tear out.
Justin aka banget3k
SEStone
Post by SEStone »
JustinB_20vt wrote:Whelp the after the freshly rebuilt engine got broke in and i started turning up the boost E85 here in arizona changed to e55 ethanol so i pulled timing/boost and fuel for a get around town tune and basically stopped driving the car. fast forward a few months and i took the time to relay the fuel pump using a relay bracket from a C5. Unfortunately the random smoking on startup has now become an every start thing and i am thinking valve seals or rings... leaning towards rings as i am dumping mass amounts of oil into my catch can and getting less power from the same boost and fuel :) FML.. ordering a leak down tester to see what i will need to tear out.
That sucks, Jim and I can relate though.
Sam
Sam Stone
JustinB_20vt
So my 044 pump gave up a month back and i decided to go with the Walbro 416 as i can do two if i ever need more fuel. For now i have modified my old basket to fit the walbro .. purchased a rubber sleeve to help keep it put and with the top piece snapped on its not going anywhere. I did a quick pressure and flow test but have not been able to actually test as it's 120 degrees in the day and lows are in the mid 90's :wah: In the back of the first pic is my prototype printed double pump basket.
Justin aka banget3k
Pics aren't visible...
You might be running into the same issue I was having if you're using Google Photos...
Here's a link on how to fix it...
http://www.rainsberger.ca/2016/02/19/direct-link-to-image-in-google-photos-for-html-image-tag/
