So I'm nearing completion of my 3b swap into my 80q, running on a VEMS plug and play which ran the engine in my 200. I got the car to a point where it would start and idle nicely, but hadn't taken it for a test drive yet. In an attempt to turn the car around in the driveway, I started it and backed up, drove it about 10 feet, then it died suddenly and wouldn't restart. I assumed I flooded it or something, but it continued to not start, and never started again. Turns out it's not firing injectors or coils. I pulled out my laptop and did an output test on coils and injectors, both of which worked correctly. I tried to take a trigger log, but I'm not positive I trust the results. I hadn't really used the trigger log much, but the first time I tried(before this incident) it gave me what looks like a nice clean log with spark events.
Currently, I am usually getting absolutely nothing in my logs, or occasionally just the primary trigger alone, no secondary showing. Never sparks, never squirts.
I verified I have power and ground at my cam position sensor. (cam position is secondary, correct?) I verified the cam position sensor is functioning properly, and I verified it is getting a clean strong signal all the way to the connector at the ecu. Why would my VEMS be showing zero trigger action when my cam sensor is most definitely functioning? And why is it showing no signal from either most of the time? I verified my engine speed sensor is generating a nice AC voltage at the back of the ecu connector as well. Pretty frustrated at the moment and could really use any advice about the trigger logs from anyone with some experience.
