Wondered, if anyone had any recommendation for cutoff wheel for use on aluminum, not steel? 4 1/2" and 6" disc size.
Greg W.
A small cutoff wheel for aluminum
90quattrocoupe
Re: A small cutoff wheel for aluminum
In refineries around here, the industry standard is Walter. Anything else and you're skeptical that they've cheaped out. There are other good brands, but I typically default to these.
https://www.walter.com/products/-/produ ... ng/zip-alu
Metabo makes some for aluminum. I'll have to check what I have, I ordered a bunch a year or so ago when some website had a bunch of options for cheap. I got some Metabo and another brand and both have been working great.
90quattrocoupe wrote:Wondered, if anyone had any recommendation for cutoff wheel for use on aluminum, not steel? 4 1/2" and 6" disc size.
Greg W.
Whatchya doin?
90quattrocoupe
audifreakjim wrote:90quattrocoupe wrote:Wondered, if anyone had any recommendation for cutoff wheel for use on aluminum, not steel? 4 1/2" and 6" disc size.
Greg W.
Whatchya doin?
Oh, maybe fit some UrS4 seats into the coupe. Just in the planning stage.
Greg W.
90quattrocoupe
alxdgr8 wrote:Metabo makes some for aluminum. I'll have to check what I have, I ordered a bunch a year or so ago when some website had a bunch of options for cheap. I got some Metabo and another brand and both have been working great.
Thanks. Let me know, that way I have options.
Greg W.
90quattrocoupe
PRY4SNO wrote:In refineries around here, the industry standard is Walter. Anything else and you're skeptical that they've cheaped out. There are other good brands, but I typically default to these.
Nice. Thanks.
Greg W.
