N75H/N75J discussion
Namreg Rac
Post by Namreg Rac »
Has anybody ever done comparisons between these 2 valves on a bigger turbo/chip tuned AAN?
I guess the N75H (race valve as 034 calls it) is stock for the AAN while the N75J is stock on the 3B.
I have also read that in some circumstances people have swapped to the N75J to deal with boost onset spikes on bigger turbo/chip tuned Audi's? I haven't really read about any experiences with AAN's.
Anybody want to share their knowledge and experience with this?
Sean
Sean Haynes
Anchorage Alaska
varia
Re: N75H/N75J discussion
Post by varia »
"j spikes higher, h holds boost longer..."
¯\_(ツ)_/¯
project 2226
varia wrote:"j spikes higher, h holds boost longer..."
Now, that is totally dependent on whether you're running standalone engine management or stock. Sure, the valve has different properties which is why it reacts differently given the SAME control parameters by an ECU. But if you have something like VEMS where you can control those parameters, it doesn't matter which valve you have.
Namreg Rac
I have read that and I have read the exact opposite.
Was curious if anybody has tried doing a comparison on a chipped Motronic
Sean Haynes
Anchorage Alaska
varia
Post by varia »
http://forums.fourtitude.com/showthread ... -N75J-N75H
ive read it here few months ago
¯\_(ツ)_/¯
project 2226
booested4door
Post by booested4door »
I've only played with these on a 1.8t, but, in my experience the j is smoother and the h is spikey.
Namreg Rac
booested4door wrote:I've only played with these on a 1.8t, but, in my experience the j is smoother and the h is spikey.
Cool. Was the 1.8T stock?
Sean Haynes
Anchorage Alaska
booested4door
No. And I now run a k valve with a big turbo. Nice and smooth.
Namreg Rac
booested4door wrote:No. And I now run a k valve with a big turbo. Nice and smooth.
Right on, I have a GTX3071 with an N75H and get some boost spikage with high load.
I am going to try a J
Sean
Sean Haynes
Anchorage Alaska
booested4door
any smoother?
Namreg Rac
booested4door wrote:any smoother?
I haven't gotten home yet. I will test it our in a week or so when I return from work.
Sean Haynes
Anchorage Alaska
