90q IMSA GTO (wanna-be) build
DFrosty
Re: 90q IMSA GTO (wanna-be) build
Post by DFrosty »
TopherGrace wrote:
DFrosty wrote:
TopherGrace wrote:^^Looks very good! where does the bottom line on the expansion tank go/come from?
Thanks. The hose that goes into the back of the Rad...on the fan side?[/quote
My bad I worded that wrong, I was referring to the lower hose on the expansion tank, I see the top hose comes from the rad, where does the bottom one come from
No worries man. The only other hose attached to the expansion tank is at the bottom of it with a check valve and that hose runs down along the strut tower/inner wing, and does a switch-back around the motor mount and connects to the port at bottom right corner of Rad under the fan. This the one you mean?
Attachment ( 39476 ) : 90q_expansion tank hose_no fan.JPG
Attachment ( 39477 ) : 90q_expansion tank hose_with fan.JPG
Attachment ( 39478 ) : Screen Shot 2014-03-28 at 7.47.22 AM.png
"I've been thinking about this, Mr. Hand...If I'm here and you're here, doesn't that make it our time?"
TopherGrace
Post by TopherGrace »
D'Frosty!!!!!
Thanks for the pictures sir, I am putting an engine where it doesn't belong so to speak and was hoping that the expansion tank upper and lower could be tied to the radiator
Twintowers
Post by Twintowers »
Fire that thing up!
Updates?
DFrosty
Post by DFrosty »
PRY4SNO wrote:Updates?
Thanks for asking dood. Unfortunately, only an update of the ugly kind...
The car was up on the dyno ready to be properly broken in and tuned :woowoo: !!
But...and a big but it is. During the warm up cycle, a sound of something breaking loose inside the motor was heard and promptly shutdown. The #2 cylinder rod bearing gave way due to oil starvation and after a bit of investigation, turns out that the machine shop that did the rebuild on the block installed all of the main bearings backwards :dur:
The machine shop has since completed all of the rebuild work part deux, the engine and gearbox have been reinstalled and now awaiting a new oil pan extension after the original, plus the replacement, have perplexingly broke at the exact same spot during installation.
I should rename my file for this project to 'Project Setback'
What a bummer! But, you're getting ever closer... when do you estimate being on the road again, ripping up pavement?
DFrosty
Post by DFrosty »
PRY4SNO wrote:What a bummer! But, you're getting ever closer... when do you estimate being on the road again, ripping up pavement?
Indeed. As of now, the plan was to have her back up on the dyno by end of this month...which is this week. If the 2nd replacement pan extension breaks again, we'll have to punt it out another couple weeks.
I'll shoot some video when it finally happens. I've seen posts with youtube clips imbedded in the body of the post...not just a link. How do we do that?
JonathanL
Post by JonathanL »
You've got to put the vid onto photo bucket or something like that first, then put it in between the video things from "full editor" preview before posting, viola!
[youtube]Just copy the youtube link between the youtube tags.[/youtube]
DFrosty
Post by DFrosty »
Am in need of oil pan extension (p/n 034 103 627 or 034 103 627 D) for 7A, 3B, AAN, ADU or ABY if anyone has one available...original 7A motor to my build. This is holding up motor break-in and tune
Has anyone else experienced this when installing with new o-ring gasket? Appears to be too thick as extension original to motor (seen in pics) and a replacement have both broken at exactly same upper left hand corner.
Attachment ( 68586 ) : Oil pan extension_front.JPG
Attachment ( 68594 ) : Oil pan extension_side broken.JPG
TopherGrace
Cheapest one by a long shot
https://www.ecstuning.com/Search/SiteSe ... /ES272998/" onclick="window.open(this.href);return false; ... /ES272998/
DFrosty
Post by DFrosty »
It's finally happening!! Major progress to the point where I'll be bringing her back home!!
:bashtard:
Attachment ( 84097 ) : 90q_dyno day_1.JPG
Attachment ( 84105 ) : 90q_dyno day_2.JPG
DFrosty
Post by DFrosty »
Finally got her back! Next steps...Bodywork
1st time ever towing a car on a trailer...No less on the hottest day so far of this year 8)
Attachment ( 84313 ) : 90q_tow_1.JPG
Attachment ( 84321 ) : 90q_tow_2.JPG
DFrosty
Post by DFrosty »
Cleaned up some main harness wiring between block and firewall this past weekend and slipped these slippers on...
Attachment ( 85681 ) : 90q_RS2brakeducts_front_wide.JPG
Attachment ( 85689 ) : 90q_RS2brakeducts_left_front_med.JPG
Attachment ( 85697 ) : 90q_RS2brakeducts_left_cu.JPG
Twintowers
Are those gravel guards?
Hybrid_Hatch
Post by Hybrid_Hatch »
Look like the RS2 air ducts for brakes
DFrosty
Post by DFrosty »
Hybrid_Hatch wrote:Look like the RS2 air ducts for brakes
RS2 Brake cooling ducts indeed
Twintowers
Wings..lol
DFrosty
Post by DFrosty »
Twintowers wrote:Wings..lol
...and that's no Red Bull :D
Nice to see you've migrated :)
I think any of the pics you'd uploaded to MG have to be either hosted elsewhere or hosted here.
DFrosty
Post by DFrosty »
PRY4SNO wrote:Nice to see you've migrated :)
Nice to be here, thank you for having me. :thumbsup:
PM reply from Marc says a fix to reference pix is currently in the works.
DFrosty
Post by DFrosty »
S2 front bumper mock up
90q_S2 front bumper mockup.JPG (1.9 MiB) Viewed 45323 times
Ohhhhh yeah... that's the stuff.
DFrosty
Post by DFrosty »
Would any of you have a suggestion for a better solution to this clearance issue between the backside of the right headlight and the Turbo Inlet hose?? Kinda not liking the stress it will put on the headlight connector and the way it forces the light to be aimed down and in.
Thanks
90q_TIP_cu copy.jpg (594.02 KiB) Viewed 45222 times
Cobra head style hose may help.
