Taco's 2001 Dakota R/T: TRANNY TIME
Re: Taco's 2001 Dakota R/T: The American Witch: Engine Rebui
Woohoo! Looks like fun. I'm sure that was one hell of a noise when that went.
AngryTaco
Post by AngryTaco »
not really. Noticed loss of power suddenly on a joy ride when getting back onto the freeway. Really surprised it lasted as long as it did. Hell it still fired right up and ran afterwards
AngryTaco
Post by AngryTaco »
All torn down. Mains were pretty hammered as well
dana
Post by dana »
why did this happen? oil pump not able to deal with revs? or...?
AngryTaco
Post by AngryTaco »
I think it was a combination of high mileage (180k) and way higher prolonged revs than the oil pump and pan was designed for.
I went from a nice 300hp setup to about a 375hp setup with a cam/head work/intake/ and fresh tune so the extra power certainly didnt help the already beaten on bearings
Adding that kind of HP to an engine that "mature" will cause some issues quick. Hopefully you aren't looking at having to replace too much, just repair what you have.
Get this done so you can start on the Baron again. Need more 20v love around here.
AngryTaco
Post by AngryTaco »
I just bought the flywheel for it!!!!
Well I decided on this rebuild that I am going to throw some main studs in, a girdle, line hone, possibly scat h-beams, new heads, rings, king bearings with .003" mains and .0025-.003" rods. This way when the 408 rotating assembly is bought, I just need to throw it in essentially
Namreg Rac
Post by Namreg Rac »
20v turbo. Get on it already
Sean Haynes
Anchorage Alaska
AngryTaco
Post by AngryTaco »
Motor finally got done from the machine shop.
The following is what was done
Decks were squared up
Line Hone
Main Studs (ARP 2000)
Main Girdle
ARP Rod Bolts
All rods were reconned with the new ARP Rod Bolts
3/4 Hardened Main Bearings
No groove Hardened Race Rod Bearings (Kings Extremes)
Hardened Cam Bearings
New Brass Freeze Plugs
All 8 Cylinders Honed
Crank was turned to support 7000 rpms
The reassembly begins this week of the short block. Ordering a comp cam soon (http://www.compcams.com/Company/CC/cam- ... d=648&sb=2) The cam is the 2nd biggest one Comp offers so should be much more aggressive than the last one at idle ;)
I'm predicting a solid 425-450 HP N/A. I still need to order the heads but I am ordering a set of Aluminum Edelbrocks with 2.02/1.62 valves. After some mild porting, they should easily flow over 300 cfm. Now add in the 150 shot and we should be having a good time :police:
Well its about time!
AngryTaco
Post by AngryTaco »
I just need to have it running reliably and tuned by the first of April. I'm driving it down to California for a wedding and plan to do some showing off. I usually drive it on my Birthday (Halloween) and then park it for the rest of the season.
AngryTaco
Post by AngryTaco »
Some goodies have started to show up now that the shop is running smooth
AngryTaco
Re: Taco's 2001 Dakota R/T: The American Witch: ITS HERE!!!!
Post by AngryTaco »
ITS HERE BITCHES ITS HERE!!!!! OMGOMGOMGOMGOMGOMGOMGOMGOMGOMGOMGOMGOMGOMGOMGOMG.
Now i KNow what it's like to receive HPR parts
Specs can be found here: http://www.compcams.com/Company/CC/cam- ... d=648&sb=2
AngryTaco
Post by AngryTaco »
More goodies showed up 8-)
Already ported and set up for a .600 lift cam
These things weigh about 41 lbs each. Far cry from the 90ish pounds of the stockers
GANGSTER
AngryTaco
Post by AngryTaco »
These showed up on Friday
Getting super excited. Just need some damn time to start putting the damn motor back together :bangshead:
AngryTaco
Re: Taco's 2001 Dakota R/T: The American Witch: Engine Parts
Post by AngryTaco »
Got the crank installed.
.0025" - .003" clearance on the mains
[youtube]http://www.youtube.com/watch?v=I0KUEfuRuBE[/youtube]
Re: Taco's 2001 Dakota R/T: Fresh Video
Nice! Now get the rest of it together!
AngryTaco
Post by AngryTaco »
Should have pistons and rings on it some time this week. We became insanely busy this week so looks like I may not get to it again until this weekend. Good thing that lube is thick
AngryTaco wrote:Good thing that lube is thick
:rofl:
Hows the shop doing? Busy is good as long as it is turning a profit. General repair ain't easy on so many levels.
AngryTaco
Post by AngryTaco »
ringbearer wrote:Hows the shop doing? Busy is good as long as it is turning a profit. General repair ain't easy on so many levels.
Stressful but profitable right now. We got hit with a 30 pound bag of bricks in repair work over the last week. Summer arrived 2 weeks early for us. Between here and school, I barely have time to work on any of my own shit anymore.
AngryTaco
Post by AngryTaco »
Almost got the short block reassembled. Buggered up a rod bolt so waiting on the replacement. Very small chance of having this thing in the truck this weekend but I seriously doubt it.
AngryTaco
Post by AngryTaco »
Ordered my Kevko oil pan earlier this week. Looks like they are going to make me a custom pan for the Dakota that has baffles, windage tray, trap doors, and 7qt capacity. Comes with the pickup meant for a HV pump. All that for a price of$405 + shipping. Not bad in my opinion. Should see it in about 2ish weeks. Super excited
AngryTaco
Re: Taco's 2001 Dakota R/T: Rebuilding
Post by AngryTaco »
