First I have the 034 TTL single coil pack.
034 posted: 3B Specific Wiring:
Pin A: Green/White ECU Trigger
Pin B: Brown/Red Ground
Pin C: Brown/Red Ground
Pin D: Brown/Red Ground
Pin E: Blue/Black +12v
I know all 3 of the grounds can't go to the same location. I assume there would be a fuse block/block/head ground or some sort of combination.
I have 2 brand new 7A knock sensors that I planned to use of my old engine. I know the 3rd wire is the shield and I have the proper wiring for it.
Pin 1 Sig +
Pin 2 Sig -
Pin 3 Shield.
Where is the best place to ground the shield wire? The head?
3B TPS (I still need to source a TPS, I don't think my 7A will work correctly)
1 5v
2 Output
3 Ground
4 Unused
5 Idle Switch
6 Idle Switch
If anyone sees any errors please let me know. This is my first time using any form of standalone and I don't want to make any wiring mistakes.
