pkw
just throwing it out there but you were on the dyno and probably took measure to assure that is was not slightly over advanced timing causing some knock sometimes, hurting power. that is the knock prone area of the rev range but also the area that is the most demanding on coils. personally i did not have real great luck with different coils until i went with the 034 coils (knock on wood) but i never tried using the coils you speak of. BTW a couple of t28s or k24s would hit those numbers and spool up a lot quicker. not that the internet likes to ever hear talk of using small turbos. :wink: your turbos would be pretty nice on a 4.2 though.
p
p
pkw
electronic boost control for sure, boost controllers were set flat closed (80% duty) fully across the map so the only thing I could think of would be if the wastegate was creping open. I suspect 'round 3' might involve some stiffer wastegate actuators. Naaaaaaaaate?
dual N75s.
From my experimentation 80% duty is the same as 100% but I will do that and see if I notice any difference anyway.
Would be nice if these internal wastegate actuators offered a way to supply boost to the upper chamber
JasonAG
hmm, well before I go that route I'll try disconnecting the wastegate lines alltogether and see what difference that makes.
Now, onto some :pics: and :vids: from the dyno
Haydn checking in:
hard at 'work'
yeah, my car gives me wood. I hope thats normal. "If erection persists for more than 4 hours..."
and lastly, :vids:
http://www.theswansonfamily.us/modules/ ... 020310.MOV
This particular run is an example of the dip in action, you can actually see the car load and unload at the top of the powerband.
Haydn checking in:
hard at 'work'
and lastly, :vids:
bradyzq wrote:What ramp rate were you using? That can affect the boost curve.
Not sure, I'd have to ask the dyno guys.
pkw
more tailorable yes, if that is what you want to do but the best electronic compared to a simple check valve style MBC (not bleed) located in the right place is pretty much a neck and neck match for boost response and stability.newt wrote:MBC?? Why on earth would you want/need one? With a programmable setup you can ramp up the boost much faster and more tailorable than pretty much any MBC out there.
HT Motorsport
WAUG0806
RS
vwhammer
Could you give me a quick rundown on the specs of your engine and the turbos you are using.
If I am reading things correctly all you did (loosely speaking) was stack gaskets on a 3.6, add a pair of t3s and you are making 411hp.
Am I correct in assuming that most of the hard parts of the engine are otherwise stock?
You mentioned that you thought the turbos were a little off.
What would you run if you had it to do all over again?
Do you think there are any junk yard turbos out there that could get you similar results?
84urq20v
newt wrote:Ahh, yeah, the N75's bleed through even at 100%, you can't fully open or close them, so there's always some reference pressure to the wastegates. We've got some discrete switching valves that really need to be put on the website... :-P
No intention to threadjack , but more info please!!!
Brandon
vwhammer wrote:If I am reading things correctly all you did (loosely speaking) was stack gaskets on a 3.6, add a pair of t3s and you are making 411hp.
i wouldn't say that all he did was stack the gaskets and throw turbos on...
there's a ton of fab work on this job, more so than any 20vt or 20vt install, and it should be noted so that not just anyone reads this and thinks "hey, i'll do that this weekend"
vwhammer wrote:Could you give me a quick rundown on the specs of your engine and the turbos you are using.
bone stock 3.6, stacked head gaskets, head studs, 034 v8tt manifolds, T3 .60 A/R turbos.
Lots of other 'little' mods here and there.. intercoolers, oil coolers, oil/coolant supply and return, etc. But yeah, the motor internals are bone stock.
correct.
depends on who's paying the bill
cost no object I would probably setup a sequential turbo arrangement, something along the lines of a GT2871R as the larger turbo and a GT2860 as the smaller huffer.
Another approach would be for me to go with the 4.2 which would have the larger displacement necessary to spin these turbos up faster. Either way, ball bearing is the way to go, I just couldn't justify the $$.
I think a pair of K24s wouldn't be a bad choice, DEREK
WAUG0806 wrote:a_CQ wrote:Nice, very nice! I want that torque curve.
me too!
Nice pull... did you notice a similar dip in power on the track...?
On the track I was only running 15psi, and didn't notice any power dip.
a_CQ
